حد جرب الطريقه ديه قبل كده بيقول انها ممكن تسمح بنقل البرامج اللي مش بتتنقل علي الميموري ايه رايكوا ؟ انا خفت اجربها عشان حاسس ان فيها لعب في السيستم
Force Applications to Permit Being Moved to the SD Card, Without Rooting
Android 2.2 allows applications to be moved to the SD card, but not all developers have enabled this option for their applications yet. In some cases, that’s for a very good reason (for instance, an application that’s installed on the SD card cannot run while the phone is plugged in to the computer as a hard drive), but in others it seems that the developer simply hasn’t got around to it.
Fortunately, it’s quite simple to override this for most applications, even on a phone that hasn’t been rooted:
Enable USB Debugging on your device and install the Android SDK on your computer, as in the instructions for taking screenshots above.
Plug your device in to your computer via USB.
On your computer, open a terminal window (in Windows, press Start > Run and type “cmd”, then press enter).
Navigate to the \tools\ directory inside the folder where you installed the Android SDK. (In Windows, type “cd\” and press enter to get to your main hard drive, then type “cd path\to\folder” to get to the correct folder. For example, “cd downloads\androidSDK\tools”, if the SDK is in C:\downloads\androidSDK.)
Type “adb ....l pm setInstallLocation 2″ and press enter.
Unplug your phone and you should be able to transfer almost all of your applications to the SD card!
