ان شاء الله هما دول لجين و الواجا
Brake Disc, Front Axle Part Number: BDC4805
- Brake Disc Thickness [mm]: 18
- Brake Disc Type: Internally Vented
- Diameter: 236 mm
- Height: 45 mm
- Hub Bore Ø: 64 mm
- Minimum Thickness: 16,4 mm
- Number of Holes: 4
- Brake System: Sumitomo
- Fitting Position: Front Axle
Brake Disc, Rear Axle Part Number: J3315019
- Brake Disc Thickness [mm]: 10
- Brake Disc Type: Full
- Diameter: 260 mm
- Height: 41 mm
- Hub Diameter [mm]: 90
- Inner Diameter: 154 mm
- Minimum Thickness: 8,4 mm
- No. of holes 1: 2
- Pitch Circle Ø: 114,3 mm
- Quality: ORIGINAL HERTH+BUSS
- Fitting Position: Rear Axle
