how much is the weight of 13" or 14" steel rims ??
رقم العضوية : 143
الاقامة : Nasr City
السيارة: Toyota Yaris 2007
السيارة[2]: Nissan Juke 2013
الف مبروك يا حسام
و ربنا يبارك لك فيه
رقم العضوية : 900
السيارة: 2car
السيارة[2]: 1car
رقم العضوية : 2504
الاقامة : gesr el swis
السيارة: la yogad
السيارة[2]: la yogad
مبروك يا حسام .. انت كده يقيت علي الجنط رسمي .. خصوصا ان مفيش كاوتش ... :)
عقبال ما نبارك علي الكاوتش قريبا جدا ان شاء الله
رقم العضوية : 102
السيارة: Daewoo Lanos I 1999
دراجة بخارية: N/A
i just realized that i lost the text file that got the weights but the good news is that i have the rim+tire weights for the 13 and 14 setups:
13" rim with 175/70/13 tire weights 14.00Kgm
14" rim with 185/60/14 tire weights 15.25Kgm
this means i'd have to harras Hossam and make him weight the rim with a fully inflated tire on it LOL
http://www.daewootech.com/forum/viewtopic.php?t=3631
رقم العضوية : 842
الاقامة : Cairo , Egypt
السيارة: Fiat Palio 1.2 FIRE - 2006
السيارة[2]: Hyundai Elantra GL 2012
دراجة بخارية: مكواة بخار
رقم العضوية : 102
دراجة بخارية: N/A
well... as far as lighter means volunrability to bending: it is not that simple... we are comparing a steel rim with aaloy rim so the material subject to comparison are different so weight can't be a judjment here
if we use weight for the steel rims only then you might be right but again... steel rims are not hard so even if they got bent they can be easly fixed
the case with alloys is different as weight means strenth and that is the most important thing you should be seeking in a rim when you are driving in this country
as far as weight and acceleration... it works a bit differently than just added weight to the weight of the overall car... you do force the engine to rotate that extra weight and thus it consumes more power than just adding the same weight to your cargo or so
this is exactly why their are performance flywheels where it is way lighter than OEM flywheels.
it is not just the lost weight that counts... it is the less weight the engine has to rotate and thus this mod makes the engine increase revs much faster than usual.
رقم العضوية : 842
I get it now
Thanks for clearing up
one more thing
My car has stock 14" steel , I 've done arround 40 and thinking of getting me some nice rims by the time I reach 50 ( new tires anyways )
I couldn't find anywhere on the car what is the maximum size I could get
Should Get a 14" rims with wider base like most ppl suggested or should I get 15 ?
The current one installed are 14 165x55
and excuse my stupidness but does alloys/rims affect bodyroll ? I mean my car has a huge gap between the wheel an the caritself well getting bigger wheels would reduce bodyroll ? Or Should I go the lame way by cutting the springs themselves ??
and the ride is a bit HARSH right now , with alloys would that get harsher or softer ( to the ppl inside the cabin that is )
Thanks again
رقم العضوية : 6814
السيارة: إسبرانزا A516
السيارة[2]: هيونداى إلنترا 2010
مبروك يا حسام وعقبال الكاوتش
رقم العضوية : 900
السيارة: 2car
السيارة[2]: 1car
you should notice that the extra 4kg is unsprung weight which is more effective than a regular weight in the trunk on the other hand it appears that the tyre width didn't have so much effect on weight ??
Cryptonx
i recommend you to leave the current rim size but install a wider tyres
195 or 185
رقم العضوية : 333
الاقامة : شرم الشيخ
السيارة: Optra 2010 A/T
السيارة[2]: Optra 2010 A/T
أنا كنت ناوى اوزنهولك عند اى فكهانى و انا رايح اركب الكاوتش :D، بس دلوقت مش عارف اتصرف ازاى؟ تخيل شكلى لما اركب الكاوتش و اقول للى هيركب انى هروح اوزنه و اجى ، كده الراجل يفتكرنى مخونه فى ميزان الهوا :p
عموما ان شاء الله انا استقريت على البريدجستون MY1 الأندونيسى، الفردة ب 363 جنيه فى توكيل بريدجستون و ربنا يسهل و اركب الأسبوع ده
أخوكم حسام حسن {أبو ليليا و سيليا}
