VW gol/pointer history
COPIED
The BX Platform cars were started in Brazil in 1980. The had the Voyage (Sedan & Coupe), Parati (Wagon), Gol (Hatchback), and the Saveiro (Pickup Truck)
http://img.photobucket.com/albums/v4...y/1980-Gol.jpg
1980 VW Gol. (MK I)
http://img.photobucket.com/albums/v4...-gol-motor.jpg
Even stranger under the hood. Spare tire mounted up front and that is an Air-cooled 1300 beetle motor. Came Stock on very early models.
http://img.photobucket.com/albums/v4...MK1-Voyage.jpg
1982 Voyage
http://img.photobucket.com/albums/v4...ry/MK1-Gol.jpg
1983 Gol
http://img.photobucket.com/albums/v4...MK1-Parati.jpg
1983 Parati
http://img.photobucket.com/albums/v4...k1-Saveiro.jpg
1982 Saveiro
Technically the MK I generation lasted until 1995(ish). The Voyage, Parati & Gol till 1995 and the Saveiro till 1997. (I've been seeing some conflicting info)
They did get a face lift in 1987 and again in 1991. These models look just like ours of the same years.
http://img.photobucket.com/albums/v4...istory/Mk1.jpg
Facelift 1 (1988 Voyage)
http://img.photobucket.com/albums/v4...88-Gol-GTI.jpg
Facelift 1 (1988 Gol GTi)
http://img.photobucket.com/albums/v4...ry/1994Gol.jpg
Facelift 2 (1994 Gol doing the "peeing stand")
http://img.photobucket.com/albums/v4...97-Saveiro.jpg
Facelift 2 (1997 Saveiro)
The MK II Generation Started in 1995 and looked kinda like our MKIII Jetta/Golf. Cars of this generation had a 1.0L 16v option, a 1.0L 8v, and a factory turbo option! There is no Brazillian MK II Voyage. Production on the second gen ended in 2002(ish)
http://img.photobucket.com/albums/v4...98-saveiro.jpg
MK II Saveiro (1998)
http://img.photobucket.com/albums/v4...996-Parati.jpg
MK II Parati (1996)
http://img.photobucket.com/albums/v4...-Gol-16v10.jpg
MK II Gol 1.0L 16v (2001)
The MK III Generation started in 2003 and continues on so far. The Gol, Parati, and Saveiro are all still made. There are 3 option/trim levels.
http://img.photobucket.com/albums/v4...arati_plus.jpg
MK III Parati 'Plus' (2006)
http://img.photobucket.com/albums/v4...y/2005-Gol.jpg
MK III Gol (2005)
http://img.photobucket.com/albums/v4...05-Saveiro.jpg
MK III Saveiro 'Crossover' (2005)
COPIED REVIEW
A practical, reliable and affordable is the main dignity Volkswagen Pointer, which he has won the markets 22 countries worldwide.
Long before the start of sales Volkswagen Pointer had set three-world record for endurance, successfully passing a test for durability and strength. This test involves test long-distance. Volkswagen Pointer easily and overcame breakdowns and 5000 km, and 10000 km or even 25000 km. The test was conducted under the strict supervision of the International Automobile Federation (FIA), which established and documented records. Volkswagen Pointer in less than 26 hours had overcome the distance which is nearly 2300 km.
In the cabin Volkswagen Pointer first positive impression produce new front chairs. They have become more comfortable but due to the possibility of adjustments with millimeter precision, you can easily choose the ideal position for driving.
Volkswagen Pointer instrument panel also has been completely refurbished and has nothing in common with previous models. From accomplished cast plastic, it has a soft coating, which gives a sense of comfort decor. Externally Volkswagen Pointer is a typical sample of the compact city car belonging to a segment of "B".
Referring to the exterior car, trying to find some reason many different parallel: breakwater, Volkswagen Pointer went to the rack of Passat B1, in profile looks Golf Third, some notice in novelties features Bora. But as a whole, this approach rather superficial. Volkswagen Pointer is self-model, which might, despite the apparent simplicity, boast original decisions.
Thus, the standard for all modifications Volkswagen Pointer became streamlined bumper in some equipment painted in the body color. With neither speak, but for V-class Volkswagen Pointer is still a rarity.
Hood Volkswagen Pointer stretched in a gentle smile, the two characteristic grooves, ran VW emblem. Special bar on top of the bonnet hides an orifice front windshield washers. New front headlamp Volkswagen Pointer made of the material.
Enhanced lining radiator Volkswagen Pointer, fog lamps with the half-lenses, completes the front of the car design.
Rear-view mirrors of new construction. They provide a Volkswagen Pointer Visibility good and equipped filter. Generally, the exterior Volkswagen Pointer noticeable attention to the little things illustrators.
Volkswagen Pointer looks quite modern and attractive, though not very original. However, it is clear at a glance: you exactly Volkswagen.
Content Relevant URLs by
vBSEO 3.6.0 PL2
