Technical specifications of 2004 Proton Wira Special Edition Carfolio.com ID 124223
bodywork
Type 4/5S SAL
Designer
Number of doors 4
Viewing specifications of 2004 Proton Wira Special Edition
dimensions & weight
Wheelbase 2500 mm 98.4 in
Track front 1450 mm 57.1 in
rear 1460 mm 57.5 in
Length 4270 mm 168.1 in
Width 1690 mm 66.5 in
Height 1385 mm 54.5 in
Length:wheelbase ratio 1.71
Ground clearance 135 mm 5.3 in
Kerb weight 1080 kg 2381 lb
Weight distribution
(Front)
Fuel capacity 50
litres 11
UK Gal 13.2
US Gal
Go to more manufacturers or other Proton models
aerodynamics
Drag coefficient
Frontal Area
Cx
engine
Code 4G15
Manufacturer Mitsubishi
Type S-4
SOHC
12 valves total
3 valves per cylinder
Main bearings
Construction
Bore × stroke 75.50mm × 82.00mm
2.97 in × 3.23 in
Bore/Stroke ratio 0.92
Displacement 1468 cc
(89.583 cu in)
Unitary capacity 367 cc/cylinder
Compression ratio 9.20:1
Fuel system MPFi
Aspiration Normal
Compressor type N/A
Intercooler None
Catalytic Converter Y
Max. output 94.3 PS (93.0 bhp) (69.4 kW)
@6000 rpm
Max. torque 125.0 Nm (92 lbft) (12.7 kgm)
@3000 rpm
Maximum rpm
Coolant Other
Specific output 63.4 bhp/litre
1.04 bhp/cu in
Specific torque 85.15 Nm/litre
performance
Note: A value of -1 means that
the car cannot attain that speed.
0-50mph (80 km/h)
0-60mph
0-100km/h
0-100mph
80-120km/h
(50-70mph)
in top
0-Quarter-mile
0-Kilometre
Top speed
Fuel Consumption
CO2 Emissions
Power-to-weight 86.11 bhp/ton
chassis
Engine location Front
Engine alignment Transverse
Steering rack & pinion PAS
Turns
lock-to-lock
Turning circle
Suspension Front I.MS.CS.ARB.
Rear MultiLi.ARB.
Wheels F/R 6.0JJ x 16/6.0JJ x 16
Tyres F 205/45 R 16
Tyres R 205/45 R 16
Brakes F/R VeDi/Di-S
Ve: Ventilated
Di: Disc (Disk)
Dr: Drum
S: Servo-assisted
ABS: Anti-lock Braking System
Brake ∅ F/R / mm
Braked area
Transmission 5M
Drive FWD
