السلام عكليم كونت عايز اركب زينون فى الجين نوع اسمو hid عالى و واطى هو لازم اركب كتاوت ولا ايه والنوع كويس ولا فى انواع احسن فى الاضاءة
النوع دة كويس انا مركبة ومركبلة كتاوت ودة افضل كتير لان من غير كتاوت شفت عربية دراع النور ساح.فى نوع بيجى معاة كتاوت فى نفس العلبة.بس حاول ما تضايقش حد بالزينون لانة فعلا بيضايق الى قدامك وركب عدسات للفانوس.
بس لى واحد صحابى مركب الزينون من غير كتاوت وبيقول الكتاوت فى جهاز الزينون
الزينون بيجى معاه كتاوت Built-in
يعنى مش محتاج كتاوت hid دى نوع كويس ولا ايه
+++11111
+++111111
أي زينون بيبقى إسمه HID ....
يعني HID ده مش ماركه بعينها .... إنما هي إختصار لكلمة High-Intensity Discharge
الكلام ده من ويكيبيديا
اقتباس:
HID (xenon) light sources
Xenon projector low beam headlamp illuminated on a Lincoln MKS.
HID stands for high-intensity discharge, a term referring to the electric arc that produces the light. The high intensity of the arc comes from ....llic salts that are vapourised within the arc chamber. These lamps are formally known as gas-discharge burners, and produce more light for a given level of power consumption than ordinary tungsten and tungsten-halogen bulbs. Because of the increased amounts of light available from HID burners relative to halogen bulbs, HID headlamps producing a given beam pattern can be made smaller than halogen headlamps producing a comparable beam pattern. Alternatively, the larger size can be retained, in which case the xenon headlamp can produce a more robust beam pattern.
Automotive HID lamps are commonly called "xenon headlamps", though they are actually ....l halide lamps that contain xenon gas. The xenon gas allows the lamps to produce minimally adequate light immediately upon powerup, and accelerates the lamps' run-up time. If argon were used instead, as is commonly done in street lights and other stationary ....l halide lamp applications, it would take several minutes for the lamps to reach their full output. The light from HID headlamps exhibits a distinct bluish tint when compared with tungsten-filament headlamps.[25]
