للبيع سى دى شينجر 8 اسطوانات باناسونك اصلى لم يستخدم
يا جماعة انا كنت جايب cd changer باناسونك من السعودية 8 اسطوانات اصلى بالكرتونة لم يستخدم وموش عاوزه دلوقتى وكنت عاوز ابيعه على 800 جنيه الجهاز سعره على الكرتونة 650 ريال يعنى اكتر من الف جنيه ..........
Manufacturer's De......ion
The CX-DP880 is extremely compact and will fit in many glove compartments or even under a seat, so you're not limited to using the trunk for installation as is the case with some less-compact CD changers. Installation is further simplified since you can mount it upright, horizontally, or at three more selectable angles.Thanks to this CD changer's floating suspension, there's no need to worry about annoying disc skipping.No more unnecessary pauses when you've got empty disc trays. Instead of trying to access a non-existent disc, this CD changer learns which slots are empty and will automatically skip over them, accessing only the CDs that are actually loaded.This CD changer lets you load up to 8 CDs so you can enjoy hours of uninterrupted music.
