Thank you bro its very important
good luck
رقم العضوية : 43966
السيارة: non
السيارة[2]: 2001 seat ibiza
شباب دي أرقام فيوزات ابيزا 2000-2002
كل رقم قدامه اسم ورقم الفيوز
Fuse Layout
Fuse number: Amp
1. Engine / Engine Electronics 15
2. Engine / Engine Electronics 15
3. Engine Valves 10
4. Ignition Transformer 15
5. Automatic gearbox/ reverse
light / heated jets 20
6. Automatic gearbox 5
7. Injectors / Fuel pump 15
8. Lambda sensor 10
9. "S" signal * (see footer) 5
10. Control panel / Diagnostics /
Central locking alarm electronics 5
11. Horn / Heated Seats 20
12. Right hand main beam and
pilot light. 7,5
13. Left hand main beam 7,5
14. Right hand dipped beam / right
hand lamp adjuster 7,5
15. Left hand dipped beam / left
16. Right hand parking light 5
17. Left hand parking light 5
18. ABS / TCS / ESP 5
19. Fog light / Rear fog light 15
20. Brake lights 7,5
21. Hazard lights 15
22. Indicators 7,5
23. Windscreen washer and
pump / rear windscreen washer 15
24. Head lamp washer 20
25. Heated rear window 20
26. Control panel lighting /Control
panel display / Electric mirrors/
Dashboard lighting 5
27. Inside, boot lighting / Alarm
Siren 7,5
28. Lighter 10
29. Radio / CD 15
30. Heater 25
31. Number plate light 5
32. Engines central locking 30
Fuses above relay switchboard:
33. Electronic front windows 30
34. Sunroof 15
35. Electric font and / or rear
windows 20
36. Canvas Roof 20
37.Power socket in luggage
compartment 15
Fuse Box in the engine compartment on the battery:
Radiator Fan, 1st gear 30
ABS engine relay 30
ABS main relay 30
....l fuses (These fuses should only be changed at a SEAT Official Service Centre)
Alternator 150
Onboard network 110
Radiator fan, 2nd, 3rd level 40
Engine distribution system 50
Glow plugs 50
Fuse colour code:
Beige 5amp
Brown 7.5amp
Red 10amp
Blue 15amp
Yellow 20amp
White 25amp
Green 30amp
Fuse 9 on the main strip:
The "S" signal is a system which incorporates steering wheel lock and ignition. Once the ignition is switched off and without removing the key from the ignition, this function allows you to switch on some of the electrical equipment such as the car radio, the courtesy light, etc.
This function is deactivated once the key is removed from the ignition
رقم العضوية : 18603
السيارة: N/A
السيارة[2]: ibiza 2002
good luck
[fot1]the best site[/fot1]
رقم العضوية : 41651
الاقامة : alkanter al5ayreya
السيارة: new accent 06
السيارة[2]: IBIZA 94
شكرا علي مجهودك
