many thanx for the info my dear
رقم العضوية : 57134
السيارة: Tiggo
السيارة[2]: verna
I don't know the credibility as i am not an owner of a 516 but i just posted it for the benefit of all the owners
Spark Plugs
Dimension : Specs 14mm thread size, Reach 19mm Hex Size 16mm
Factory install : Bosch FR7DTC (Triple earth electrode)
Some alternatives
BOScH FR7DC, FR7DCX etc
Denso K20PRU-11,K20PBR etc (normal),IK20 (Iridium), VK20 (Iridium/Platinum)
NGK BKR6E-11
Oil Filter
Dimensions: Height 81.8mm, Outer Diameter 82mm, Thread M20mm X 1.5mm (most important)
Factory install : Fleetguard (Shanghai factory) LF3881 Chery part no. 481H-1012010
Compatible oil filter, many Honda( e.g. 15400-PR3-0050), Mazda, Subaru,
Hyundai Sonata oil filter
Izuzu Gemini
Osaka 8-94217272-0
K&N HP-1004
FRAM PH3593A
Air filter
shape Rectangular panel, Dimensions: Height: 40 mm, Outside Length: 245 mm Outside Width: 220 mm
Chery Part no. A21-1109111
K&N air filter 33-2658 * may fit
K&N air filter 33-2054 * most likely to fit
Simota, ESE and hurricane
TOYOTA 1780107020, 1780146060 (alternatives are non-exact fit)
Wiper Blade
Hook type, Right 550mm Left 500mm
Factory install : Valeo, Right c/w spoiler
Alternatives, NWB, RainX (reinstall spoiler if possible)
Alloy wheel
Chery Part No: A21-3100020AM
ET 46 (offset in mm), 15X6JJ (15 inch, width 6 inch), max load 600kg, Bolt pattern 4X 114.3mm (4.5inch)
Tyre 195/55R15 V(speed rating)
Possible upgrade for tyres (no inch up) 205/50R15
(inch up) 205/45R16
(2 inch up) 205/40R17
Front Brake pads
Chery Part No: A21-3501070 (for A5 1.6L w/o electronic wear sensor)
width 119mm, Height 69.5mm, Thickness 19.3mm
Friction coefficient FF (important DO NOT Downgrade)
Note : there is another part with electronic wear sensor that appears on earlier A5, Chery part no: A21-3501080
Same as old Audi front brake pads
Alternatives: FBK, Honeywell,Nbrake NDB211, Mintex MDB1190, AUDI 443698151, VW 431698151 (Please compare first)
Rear Brake pads
Chery Part No: A21-3501090
Width 107.6mm, Height 42.5mm, Thickness 16mm
Similar to Toyota Camry (V1,V10,V20,V30 etc), Toyota Corolla (E11)
Mintex MDB1994, Toyota 0446620070 etc (many different part numbers), Nbrake NDB8067, Akebono
Front Disc Rotors
Chery Part No: A21-3501075
Internally Ventilated (double layer)
Bolt pattern 4X114.3mm + single screwhole
Diameter 240mm, Brake Disc Thickness 22mm, Height 48mm, Pitch Circle 150mm, Centering Diameter 68mm (approximate measurements)
Rear Disc Rotors
Chery Part No: A21-3502075
Brake Disc Type solid
Diameter 260mm, Brake Disc Thickness 10mm, Height 60mm, Pitch Circle 182 mm, Centering Diameter 68 mm (approximate measurements)
Ignition coil
Factory Install Bosch 0 221 503 485 begin_of_the_skype_highlighting 0 221 503 485 end_of_the_skype_highlighting , Chery Part No: A11-3705110EA
Alternatives Valeo 245040, FIAT 9607405480, CITROEN 597060, PEUGEOT 597048 topline TIc 8040 (Malaysia)
Front Dampers
OEM Sachs (Shanghai)
chery part no. A21-2905010
Rear Dampers
Chery Part no. A21-2915010
Air flow sensor
4 Pins Terminal, 5V
Factory Install for 1.6L,made in Germany BOSCH 0 261 230 099 begin_of_the_skype_highlighting 0 261 230 099 end_of_the_skype_highlighting (intake manifold absolute pressure sensor), Chery part no: 480ED-108060
Alternatives FORD 2U1L 9F479 AA, OPEL 93 399 801, Honda Jazz 37830PWEG01
Note : for 2.0L, it is a different part from BoscH (also used in Audi A4 2006[])
منقول من إحدي المواقع الاجنية
رقم العضوية : 36962
الاقامة : Zaton
السيارة: ما قولنا كله من نعم الله و الحمد لله
السيارة[2]: كله من نعم الله
دراجة بخارية: never
البريبئ اتخرم و عايزيين بريبئ جديد
رقم العضوية : 27398
الاقامة : Egypt
السيارة: Sunny 2011
السيارة[2]: X - A 516
ياريت تنزل بالترجمة
رقم العضوية : 25254
الاقامة : القا هره
السيارة: شاهين 1400 /97
السيارة[2]: 516.2008 تيجو2013
دراجة بخارية: دايون 150
النبي عربي
عليه الصلاه والسلام
ياتقول كلام في محله يا تقول حلو ياحلو
http:///photos/a.879931698703941.107...370587/?type=1
رقم العضوية : 75386
السيارة[2]: A113
تحيا مصر ياعم
رقم العضوية : 55076
الاقامة : القاهره
السيارة: سبرانزا 516
السيارة[2]: فيات 128
أنا لا أعرف مصداقية وأنا لست صاحب 516 لكني أرسلت للتو لصالح جميع الملاك
شمعات الإشعال
البعد : المواصفات 14mm حجم الخيط ، وتصل إلى حجم الهيكس 16mm 19mm
مصنع تركيب : بوش FR7DTC (ثلاثية القطب الأرض)
بعض البدائل
بوش (FR7DC ، الخ FR7DCX
دينسو K20PRU - 11 ، K20PBR الخ (عادي) ، IK20 (ايريديوم) ، VK20 (ايريديوم / البلاتين)
NGK BKR6E - 11
مصفاة النفط
الأبعاد : الارتفاع 81.8mm ، 82mm القطر الخارجي ، خيوط M20mm العاشر 1.5mm (أهم)
مصنع تركيب : Fleetguard (شنغهاي المصنع) LF3881 جزء لا شيري. 481H - 1012010
النفط متوافق التصفية ، هوندا كثيرة (على سبيل المثال 15400 - PR3 - 0050) ، مازدا ، سوبارو ،
هيونداي سوناتا مصفاة النفط
Izuzu الجوزاء
أوساكا 8-94217272-0
ك و ن إتش بي - 1004
فرام PH3593A
فلتر الهواء
لوحة مستطيلة الشكل ، الأبعاد : الطول : 40 مم ، خارج المدة : 245 مم خارج الطول : 220 مم
شيري الجزء لا. A21 - 1109111
ك & ن فلتر الهواء 33-2658 * قد تناسب
ك & ن فلتر الهواء * 33-2054 الأرجح لتناسب
Simota ، جنوب شرقي والأعاصير
تويوتا 1780107020 ، 1780146060 (بدائل صالحة غير دقيق)
ممسحة بليد
نوع هوك ، بقي الحق 550mm 500mm
مصنع تركيب : فاليو ، الحق ج المفسد ث /
البدائل ، NWB ، RainX (إعادة تثبيت المفسد إذا كان ذلك ممكنا)
سبائك العجلات
شيري الجزء رقم : A21 - 3100020AM
تي 46 (الإزاحة في مم) ، 15X6JJ (15 بوصة ، وعرض 6 بوصة) ، تحميل 600kg ماكس ، بولت نمط 4X 114.3mm (4.5inch)
صور 195/55R15 الخامس (التصويت السرعة)
ممكن لرفع مستوى الإطارات (أي شبر متابعة) 205/50R15
(بوصة متابعة) 205/45R16
(2 بوصة متابعة) 205/40R17
الجبهة الفرامل منصات
شيري الجزء رقم : A21 - 3501070 (لواط 1.6L A5 / س ارتداء الاستشعار الالكترونية)
119mm العرض والارتفاع 69.5mm ، السماكة 19.3mm
معامل الاحتكاك فرنك فرنسي (هام لا الإنحدار)
ملاحظة : هناك جزء آخر مع جهاز استشعار ارتداء الإلكترونية التي تظهر على A5 في وقت سابق ، جزء لا شيري إلى A21 - 3501080
نفس القديمة منصات أودي الفرامل الأمامية
البدائل : الليتواني ، هانيويل ، Nbrake NDB211 ، Mintex MDB1190 ، أودي 443698151 ، 431698151 شركة فولكس فاجن (يرجى قارن الأولى)
الفرامل الخلفية منصات
شيري الجزء رقم : 3501090 - A21
عرض 107.6mm ، 42.5mm الارتفاع ، 16mm سمك
مماثلة لتويوتا كامري (V1) ، v10 ، V20 ، V30 الخ) ، وتويوتا كورولا (E11)
Mintex MDB1994 ، تويوتا 0446620070 الخ (وكثير من جانب أعداد مختلفة) ، Nbrake NDB8067 ، Akebono
الدوارات الجبهة القرص
شيري الجزء رقم : 3501075 - A21
داخليا مهواة (طبقة مزدوجة)
الترباس 4X114.3mm نمط واحد + screwhole
قطره 240mm ، أقراص الفرامل سمك 22mm ، 48mm الارتفاع ، الملعب الدائرة 150mm ، وتتمحور القطر 68mm (قياسات تقريبية)
المحرك الخلفي القرص
شيري الجزء رقم : 3502075 - A21
الفرامل القرص الصلب نوع
قطره 260mm ، 10mm سمك الفرامل القرصية ، 60mm الارتفاع ، الملعب الدائرة 182 ملم ، 68 ملم توسيط القطر (قياسات تقريبية)
ملف الإشعال
مصنع تثبيت بوش 0 221 503 485 221 503 0 begin_of_the_skype_highlighting 485 end_of_the_skype_highlighting ، شيري الجزء رقم A11 : - 3705110EA
بدائل فاليو 245040 ، 9607405480 فيات ، سيتروين 597060 ، 597048 بيجو تيك 8040 ذائع الصيت (ماليزيا)
الجبهة الموهنات
ساكس تصنيع المعدات الأصلية (شنغهاي)
شيري جزء لا. A21 - 2905010
الخلفية الموهنات
شيري الجزء لا. A21 - 2915010
تدفق الهواء الاستشعار
4 دبابيس الطرفية ، 5V
مصنع لتركيب 1.6L ، أدلى بوش (في ألمانيا 0 261 230 099 261 230 0 begin_of_the_skype_highlighting 099 end_of_the_skype_highlighting (مشعب السحب المطلق استشعار الضغط) ، شيري جزء لا : 480ED - 108060
فورد بدائل 2U1L 9F479 ألف وأوبل 93 هوندا جاز 399 801 ، 37830PWEG01
ملاحظة : للحصول على 2.0L ، بل هو جزء مختلف من بوش (التي تستخدم أيضا في أودي A4 2006 [])
منقول من احدى المواقع الاجنبية
تحياتى
رقم العضوية : 25254
الاقامة : القا هره
شكرا ليك انا ترجمت الموضوع وكان نفس الكلام
بس لو حد فاهم حاجه يفهمني
رقم العضوية : 57134
السيارة: Tiggo
السيارة[2]: verna
معلش يا جدعان اصلي ما كنتش فاضي عشان الترجمة وترجمة جوجل ما بتبقاش علي طول صح
فا بإذن الله اترجمه واكمل الموضوع
