يعني بس تتشطر على الغلبان الي معاه باليو 80 حصان بالفرنا الي مبتقفش :grin54:
The net horsepower is actually the measured output of the car with the alternator, power steering, AC and other peripherals included as well as smog control. This is measured at the engine crankshaft. This was the standard rating used in the auto industry until 2005. Gross horsepower was the original measurement and tends to produce a higher horsepower rating. The gross horsepower rating is taken when the engine has yet to be put into the car, and all the different peripherals attached. There is no load attached to the engine so all of the energy can go into creating horsepower. The gross hp is normally measured using a dynamometer which tells how much horsepower gets to the wheel axles. So in reality these are 2 completely different measurements. In all cases the net horsepower should be less than the gross horsepower. Most vehicles that were built pre-1972 will have a gross rating. Anything after this point will have a net horsepower rating.
Taken
ههههههههههههههههه
شوفت بقي كل الاشاعات اللي بتتطلع علي السيراتو بتبتدي بمعلموة خطاء ويقولولك السيراتو 124 حصان
يا جدعان دي 248 حصان - 124 حصان لكل كامة :)))))
لما ستال عن معلومة خدها من مالك سيراتو زي انا كدة يقولك الحقيقة علي طول ولا لف ولا دوران
248 حصان ببساطة - واللي عند اعتراض نعملة خصم 50% :))))) علي الاحصنة
