could u pls tell us more about this superchip
where did u installed it inside the car?
from where u get it ?
how mush is the expenses for buying and installing this chip
thanks
regards
رقم العضوية : 543
السيارة: Daewoo Juliet
السيارة[2]: Brilliance FRV
nope ,the filter is not short ram ,w ana shelto 2aslan,,,,
and i am really surprised !!
ezay wa7ed zayek maye3rafsh el superchip??!!ana kont fakrak 3aref kol haga :D
the superchip raises the horsepower by 5-10 horse,and i don`t know its technique exactly but i think its
about the air/fuel ratio ,try to type superchip in a search engine -google or yahoo- and you will get what u need
w eih el chocochip deh mala2ethash 3al net wala la2et 7ad seme3t 3anha 7`ales.
mmm it's obvious that u didn`t get my problem ,the acceleration is fine but the problem is the top speed ,el 3arabya betegy ba3d el 140 w temoot !! and by the way ana shelt el filter w chip w garabt ,bardo nafs el moshkela
momkin ab2a ashoof mawdoo3 el rashashat deeh w 2a3`ayrha law el GM msh kowayesen bas 2aslan law feeh moshkela fel sparkplugs aw el rashashat ezay el acceleration is really fine!!!hwa dah el ana mesta3`rablo w msh 2ader 2afhamo!!
nefsy 7ad ye2oli haga mofeda w mokne3a te7`ali el 3arabya sa7betha gamda wel top speed ta3bana
w fel a5er i would like to say that i really got much knowledge from your posts and replies in this forum and i found alot of answers i needed bas i hope i get one f mawdoo3 el top speed dah , w search kda 3ala el superchip w 2oli eih el kalam , w kaman seme3t that u can install a turbo momkin tedeni a brief idea 3an el mawdoo3 dah kda , i read the other post bas feeh details kteer not mention and finally i hope that writing in english maykonsh moshkela le7ad ,bas 3ashan ana bat3azeb fe3lan f mawdoo3 el 3arabi dah
w motshakreen tany ya basha :D
nb:try this link for superchip http://www.superchips.co.uk
رقم العضوية : 162
السيارة: Opel Corsa 1998
السيارة[2]: KIA Carens 2011
thanks
regards
رقم العضوية : 102
السيارة: Daewoo Lanos I 1999
دراجة بخارية: N/A
i am asking for the super chip for one very good reason: if it is what i think it is then it is a peice of s#%t... i have tried it on a couple of acars and it gasve no HP gains hatsoever and the 15 to 20 HP gain is insainly overrated... can't gain 20 HP on a 86 HP car from a little chipالمشاركة الأصلية كتبت بواسطة bluestricker
BTW the chip is used to be sold at Alforsan market for 750LE and got a paper that clames the 20HP gain as well... i can get you 10 of those from Alne7'ely for 1LE and beleive me... if you know how a fuel injected engine works you will know that this thing won't do you any good.
you don't know whats a chocochip?? i thought you knew everything :lol: :lol: :lol:
a chocochip is simply a resistance put inline with the IAT sensor so that the ECU thinks it is cold as hell outside and accordingly dump more fuel into the engine...the ECU is smart enough to detect that their is too much fuel going into the engine and accordingly will cut back on the fuel and equalize the effect of the chip
also note that it is not how much fuel you burn... it is how effecently you burn it so you got to keep your air/fuel ratio at 14.7 for N/A applications... anything below or above that ratio is a waist of power
good thing you are not on RAM thease days... RAM in this hot weather kills the engine power specially if A/C is on
loss of power is one tricky problem as it involves too much variables and probably a combination of some so don't expect this to be solved that easy... we will keep on diagnosing till we get to the source(s) of trouble and fix it
did a compression test laitly?
رقم العضوية : 543
well i asked my brother about the superchip cause he is the one who got it for me ,,,he told me exactly what u said about the chocochip - it forces the car to dump more fuel into the engine as if it is cold -he got ot from a website ,but what i remeber that it was kinda cheap around 100-200 but not for 750 at all!!!and for the installation it is very easy! and by the way i tried the car once more 2day it was very fine till 130-140 k.m per hour bas ba3d kda 7aset enaha 7`alas ! i asked alot of people but no one knew a good reason for it , ma3ada mekanenki kda shaklo msh fahem haga 2ali deeh moshkela fe kahrabet el 3arabya ya beeh w ana hazabatak bas sebhali , w tab3an 2oltelo la2 3ashan kan shaklo mabyefhamsh haga !
i had a couple of questions for you :
1-what do you exactly mean by a copmression test and how and where is it done?
2- you did not answer back about the turbo ,lets say i need around 30-40 extra hp
3- what do you think about installing a 6 cylinder air filter does it make a difference wala el shabab beyfto???
4-spiltfire sparkplugs and wires are totally useless!! at least in iur cars do u have another opinion
5- do you recommend eny 2a3`ayer el rashashat although the acceleration is fine and i cleaned them before?
6- what do you recommend to increase the performance of the car and as i said i got rid of the chip because i think it has drawbacks on the engine wat do u think??
7-one of my friends 3ando civic 2005 w 3ayz masora lel filter ,3andak fekra negebha menen ?
and finally i would like to know what do you do in real life ,i mean is ur job related to cars or ypur just an admin here??
thanks in advance
رقم العضوية : 102
دراجة بخارية: N/A
compression test is where you check for the compression of the pistons... this indicates how good your combustion chamber is sealed and how effecent is your engine... Caltex gas station at the corner of abbas elakkad and mostafa elnahas can do this test for you
for this amount of power you'd need a TD04 turbo or so...of corse you should get all the other goodies to complete the setup and tune it carefully
well... air filters has a limit in size beyond which it is usless... i mean you can use an air filter from a bus but your engine won't suck that much air anyways so it will be a waist of money
split fire spark plugs are not so good on 1.5 SOHC lanos... i tested it myself... they were good on the 1.6 and 2.0 engines, as for the wires... they were good on my car.
GM injectors are pron to leak so it will happen sooner or later but if you are really planning for turboing your car then don't get the injectors now as you will need bigger ones when you put the turbo on anyways
depensd on how much you wanna sped man... it could be as cheap as removing extra junk from the trunk to reduce weught (cost zero LE) up to a 1.6 DOHC swap including tranny and ECU and main harness and a full turbo kit, lowering springs, rims, tires , front and rear strut brace, front brake upgrade and rear disk brake kit... cost will be some 15to 20k LE so you gotta set a budget and identify your needs first
you can get the pipe from waleed 3awad in gam3et eldewal or high design in demesh2 street
i am an accountant working in the IT field
رقم العضوية : 40
الاقامة : Qatar
السيارة: Pajero 011
السيارة[2]: Octavia 09
Hey Moh.
I want the pipe for lanos do you know its price ??
"اللهم يا رب المسلمين والنصارى اجعلنا نحن المسلمين لك وللوطن أنصاراً، واجعلنا نحن نصارى لك، وللوطن مسلمين"
رقم العضوية : 543
thanks alot for your reply mr mamdouh anyway 15 - 20k is 2 much ,i was thinkin of 5k or so anyway i will decide what do i exactly need and tell u
thanks again
رقم العضوية : 102
دراجة بخارية: N/A
their is no pipe made spacificly for a lanos... get a pipe for a '92 civic and cut it a bit to be shorter and it will fitالمشاركة الأصلية كتبت بواسطة Abdallah
رقم العضوية : 102
دراجة بخارية: N/A
رقم العضوية : 543
el pipe beta3et el civic 240 L.E w 200 ba3d el fesal el kter w waga3 el 2alb w 7ases besra7a en dah nasb ,cause it is just a pipe !!! ,meen 3and high line design by the way!!!
