رقم العضوية : 98411
الاقامة : egypt
السيارة: fiat tipo
السيارة[2]: fiat regata
Hyundai Scoupe: 1.5l 12 valve, direct-port fuel-injected engine, called "Alpha". The 1,495 cc Alpha, with a 75.5mm (2.97in) bore and an 83.5mm (3.29in) stroke115hp (86kW) at 5,500 rpm and 123lb·ft (167N·m) of torque at 4,500 rpm when turbocharged, with a 7.5:1 compression ratio. Turbos came only with 5-speed manual shift,
