ok fine bye f and wellcome !!!!!!!!!!!!!!? , names does not matter
multiple user accounts are prohibited as well... it seems you didn't read the forum's rules and regulations
why u are always referring that i do not know anything , no i know that its forbidden , but i do not think that u can control it
i didn't say that you don't know anything... i only said that it seems you didn't read the forum's rules... their is a great difference between both statements
and i said that because you were wondering why formulator was permanently banned even though it is clearly stated in the forum's rules that a third ban is a permanent ban
and also you said that the permanent ban is not an issue as the banned member can create a new account and log on to the forum... again it is clearly mentioned in the forum's rules that multiple accounts are prohibited
having mentioned that will logically lead to the conclusion that you didn't thoroughly read the forum's rules
and last but not least... we do have control over multiple accounts and it is very very hard for a member to have two accounts and get away with it
actually i did not read the forum rules , but these two rules i knew about them after i had been told about formulator , and i was just thinking that they are not fair in our case , i do not want Spam members here , i do not want any member doing or saying indecent things, but in formulator case its different mocking is not a sin sir
well... mocking is considered a sin only if the one being mocked didn't accept so
in such cases we - admins and moderators - do not take action unless a member is complaining... in many cases the members might be friends and accept mockery in between them so we can't interfere here as their is a consent to mockery... a penalty is applied only if mockery is unaccepted by the mocked member.
و الله يا جماعة انا شايف ان الموضوع كبر اوى و خد اكبر من حجمه
و فعلا فورميولاتور استنفز ايقافاته كلها و زياده عليها اتنين كمان و ده لان فى ناس معايرها فى الكلام صلبه شويه و صدقونى هو مش بيدور غير على الكواليتى
بس بما ان احنا شعب مالهوش فى الموضوع ده فهو ده السبب اللى هيخلينا عمرنا ما هنتغير للاحسن
و هندور على العربيات البياعه و الللى قطع غيرها ارخص و اللى واللى واللى
انما هنعمل ايه هو ده اللى احنا حطينا نفسنا فيه من الاول للاخر عمرنا ما هنبوص الا للبيرميهولنا غبور او منصور او eit لان هو ده المتاح لاسعار ايدينا و لحياتنا العمليه
شعبنا لسه شعب ناشئ و ثقافه ناشئه الناس فى اوروبا بيتبوص للامان فى العربيه اول حاجه و استهلاكها للبنزين و احنا هنا بنبوص على عداد rpm و تكييف تلاجه ولا لأ ( لاخونا اللى عايزين يجيبوا خضار فى العربيه)
ارجو ان محدش يزعل من كلامى بس ده حقيقه و لازم نغيرها مش نتعايش معاها
و الله احنا مش هنتغير فى كل حاجه الا مع رفع مستوى مواصفات حياتنا كلاها و البدايه من نفسنا
و شكرا
احمد الزقلة
هههههههههه . بس برضة مفيش مانع ان التكيف يبقى كويس انت شايف درجة الحرارة وصلت 45 و يعنى التكيف التلاجة يدوب يجبيب طراوة فى درجة حرارة زى كدة
و الله يا استاذ احمد الواحد بس حاسس ان خسر مشاركات فورميلاتور يعنى معظم االناس لما تتكلم على عربية تقولك مثلا دية ثاتبة اوى انما هو يتكلم على توزيع الوزن و نوع العفشة يخلى الواحد يفهم الثبات دة جاى منين بس
يا باشا هو انت هاتقولى انا بقولك معاه فى نفس الشركه و بنشتغل مع بعض ده عرفنى حاجات عمرى ما احلم بيها بس المشكله على المنتدى عدم رؤية الناس للبيتكلم بيتخليهم ميقتنعوش اوى
و بالنسبه للتلاجه خلاص يا عم شغلها براحتك
