السيارات التي تم سحبها نتيجة لوجود عيوب فيها :-
ألفاروميو
A156,A147 10,2000 - 10,2003
hood lock
A159 07. - 08,2006 roof railing
أستون مارتن
Vanquish 2001 - 2005 accelerator pedal
أودي
A3 2006 Gas cartridge Head Airbag
A3 06,2003 - 06,2004 clutch
A3 04,2003 cooling exhausts
A4 2002 - 2003 emergency brake
A4, A6, A8 1994 - 1999 support arms front axle
A4, S4 Cabriole 2003 - 2004 xenon headlights
A6 02,2004 - 03,2005 software Airbag
A8 2002 - 03,2004 driver Airbag
ينتلي
Arnag 2005 and 2006 wheel nuts
Continental GT 2003 - 03,2004 brake hose
بي ام دبليو
118d, 120d, 318d, 320d 08,2004 - 03,2005, 12,2004 - 03,2005 generator screw connection
120d 03/2007 to 05/2007 injection
3er 01,1998 - 02,2001 rear axle suspension
5er 06,2003 - 07,2003 tears windshield
5er, 6er, 7er, X5 13.05.2004 - 12.07.2004 motor control
5er, 7er 02,2003 - 06,2004 seat heating
5er Touring 09,1995 - 06,1996 steering wheel lock
M3 09,2000 - 2004 oil pumps bearing failure approx
X3 3.0d 01,2004 - 06,2004 oil leakage of the power steering
X5 08,1999 - 12.04.2002 brake hose
X5 10,2003 - 04,2004 motor control
كاديلاك
CTS, SRX, XLR 2004 wheel suspension
سيتروين
C2, C3 to 11,2003 coil springs in front
C2, C3, C4, Xsara Picasso, Berlingo coolant temperature sensor
C3 15.09.2002 15.01.2003 short circuit ABS controller
C4 06,2005 09,2005 brake assembly rear wheel
C4 1,6 HDi 2005 starter cables
C4 1,6 HDI, C5 1,6 HDI, Xsara Picasso 1,6 HDI 07,2004 12,2004 Leakage fuel pipe
C8 06 Xsara Picasso combination instrument 2002 11,2004 lower hood cover, expiration of condensation air conditioning system
كرايسلر
300C 10/2006 11/2006 ABS controller
Grand Cherokee 2000 2001 Tie rod
PT Cruiser 2001 2004 Hydraulic hose
PT Cruiser 2005-2006 Triangle windows
Sebring 10,2004 11,2004 Seat belt attachment under
Sebring 10/2006 11/2006 ABS controller
Voyager 1996 2000 Driver airbag
فيراري
F360 2003 to 2004 hydraulic leakage servo pump
فورد
Explorer 04.1997 11.1998 Cruise control
focus, focus C-max OF 02.2004 03.2005, 02.02.2004 03.03.2004 leakage rear windshield wiper engines
Galaxy 11.2002 08.2003 clutch
Maverick 2001-2004 ABS
Maverick 2002 2004 gas course
Mondeo 06.2004 07.2004 chassis sensor
Mondeo 6.2. 8.9. 2006 damming material particle filters
S-max, Galaxy 10.04.2006 31.05.2006, 01.02.2006 11.06.2006 engine control software, fuel pipe
S-Max/Galaxy 12.2005 tons of 06.2006 bonding windshield heating
فيات
Multipla 1,9 multi-jet April 2005 until January 2007 fire risk of the thermic protection mat
Panda 09,2003 to 11,2006 engine equipment
Panda, Punto, Stilo, Idelo 08,2005 05,2006 w heel
Punto 1999 2003 break trailer coupling
Punto 1995 1999 brake hose
Scudo 2,0 JTD 01,2005 02,2005 negative pressure hose brake booster
Stilo 02,2001 12,2003 steering housings
Stilo 10,2001 07,2002 Airbag
Stilo autumn 2001 20.09.2006 front wheel springs
Ulysse 06,2002 11,2004 lower hood cover, condensation air conditioning system
Ulysse 08/2002 to 12/2004 brake booster
هيونداي
matrix, Accent 01,2001 10,2002 Diesel fuel line
جاجوار
S-type and XJ 2005 to 2007 particle filters
XJ 07,2005 01,2006 Sun roof
XJ, XK 1997 1999 butterfly valves k.A.S
جيب
COMM other 10/2006 12/2006 ABS controller
compass 09/2006 11/2006 ABS controller
Grand Cherokee 2003 2004 seat heating
Grand Cherokee 10/2006 12/2006 ABS controller
Wrangler 11,2005 02,2006 coupling rod
Wrangler 11/2006 12/2006 ABS controller
كيا
Rio 05,2000 03,2004 fuel pipe
Rio, Carens, Carnival 2003 ABS
Shuma, Sportage 1995 1998 seat harness release
Sorento 2002 2005 Generator
Sorento 12,2003 04,2004 automatic transmissions
Sorento before that 05.03.2004 oil cooler line
Sportage 03,2005 05,2005 emergency brake
لانشيا
Lybra 10,2000 10,2003 hood lock
Musa, Ypsilon 08,2005 05,2006 wheel 11,560 (see also Fiats)
Musa, Ypsilon 03,2005 welding seam front axle cross beam
Phedra 06,2002 11,2004 lower hood cover, expiration of condensation air conditioning system
Phedra 2003 brake hose approx.
Ypsilon 11,2005 05,2006 air conditioning system
لاندروفر
Discovery, Defender 09,1998 12,2003 ABS
Rover sport model year 2005/2006 wires
Rover sport Discovery 08,2005 09,2005 seat stand
لكزس
LS of 430 29.07.2003 14.01.2004 transmissions
RX of 300 02,2003 12,2004 master brake cylinders stop light switches
RX 300, RX 400h 03,2003 05,2005 carpet tie-clips
مازدا
M3 06,2003 03,2004 Airbag sensor
323 12,2002 engine warning lamp
5,2,0 MRZ-CD 03.10.2005 29.12.2005 screw connection cam shaft sensor plate
6 11,2002 climatic compressor
6 14.2.2002 13.5.2003 brake control light
6, MPV, MX-5 2003 fog headlights
MPV 6, Premacy 04,2001 to 06,2002 Airbag control unit screw connection wheel
MPV 2,3 02,2002 12,2004 power steering
MX-5 12,2005 02,2006 Airbag control module
RX-8 07,2003 08,2003 heat shield
RX-8 08,2003 07,2005 thermal insulation above exhaust system
of tributes 05/2000 to 12/2003 abs controller
of tributes 05,2001 12,2003 gas course
of tributes 31.05.2001 seat harness release
مرسيدس
A, B, C-class 05 ,2005 05,2006 connecting cable of the combination switch
A-class, Vaneo 04,2002 04,2003, 04,2002 03,2003 wiper arms
all models with 6 and 8-zylinder 06,2001 11,2004 voltage regulators, generator
C-class, CLK class, E-class 08,2003 10,2003 seat harness release
CL-class, S-class 1998 10,2000 blowers for heating
E-class, CLS class 01,2002 01,2005 battery controller
E-class, CLS class, SL-class 06,2001 03,2005 brake assembly
E-class, SL-class 2002 2004, 2001 2004 SBC brake system
G-class 04,2006 11,2006 Differtiallock
M-class 05,1998 12,2002 clip at the steering element hose
R 350 07.08.2005 15.02.2006 wires
R-class 03.01.2006 04.03.2006 Seat belt lock in the back
SLR 1 0,2003 generator
Sprinter 2006 wheel flanges
Vito, Viano 09,2005 02,2006 software faults
Vito, Viano 10,2003 11,2005 gasoline line
Vito, Viano 11,2003 04,2004 software motor control
Vito, Viano 3,0 CDI 03,2006 09,2006 trunk circuit starter
ميني
Cooper, Cooper S 21.08. 14.11.2006 roof problem
Cooper S John Cooper Works GP kit 26.04.2006 27.06.2006 cracking in the rims
ميتسوبيشي
Galant 08,1996 03,2001 front wheel suspension
Grandis 2006 back seats
L200 03,2006 water sensor
Lancer 1992 1993 rear flap
Pajero automatic transmission 11/2006 03/2007 bell crank automatic transmission switching rope
نيسان
Almera Tino 11,2002 11,2003 attachment of coverings
Almera, X-Trail 07,1999 02,2001, 12,2000 12,2002 open-loop system tension adjusters
Micra 02,2004 09,2004 water entrance rear flap switch
Micra 11,2002 12,2004 I-key-system
Murano 04,2002 11,2005 tank
Murano 04,2002 07,2005 three point static belt in the back
Navara 05,2005 19.12.2005 wheel bearings rear axle
Navara 02,2005 09,2005 cardan shaft attachment note
Pathfinder 02,2005 09,2005 cardan shaft attachment
Qashqai 2007 Head Airbag holder
Qashqai to 2.3.2007 rear flap lock
Qashqai to 7.2.2007 wishbones front axle
Qashqai 12.2. 05.3.2007 wishbones rear axle
X-Trail 06,2000 11,2004 tank filler supports
X-Trail, Primera t o 09,2002 controller
X-Trail, Primera, Almera, Almera Tino 01,2003 09,2005 load pressure sensor motor control
X-Trail, Primera, Almera, Almera Tino 2 001 30.09.2002 number of revolutions sensor
أوبل
Antara 2006 locking clip brake pedal
Astra 2004 2005 joint front axle
Corsa starting from 10.2006 wishbones front axle
Signum 2005 2006 disk wash nozzle
Sintra 1996 1998 Steering bolt
Vectra 2005 2006 disk wash nozzle
Vectra 2006 seat belt in the back
Vectra (B) 2002 exchange steering gears
Zafira 2005 2006 CNG system, air conditioning system ECC
بيجو
1007 k.A. combination instrument
206 SW 08,2003 02,2004 tail spoiler attachment
307 02,2002 09,2005 ABS controller
307 to 06,2003 corrosion servo-pump
307 03,2004 06,2004 support arm safety device
307. 406, 607, 807 06,2001 10,2002, 05,1999 10,2004, 10,1999 09,2004, 06,2001 06,2003 motor control
406 2002 electrical motor radiator fan
406,2,0 HDI, 406,2,2 HDI, 607,2,2 HDI 11,1999 09,2003 g low relays
of 407 10,2004 04,2005 coolant level givers
407,1,6 HDI 12,2004 07,2005 shift pipe
of 607 01,2001 11,2002 battery cables
of 607 05.03.2001 26.08.2001 wishbones in the back
807 06,2002 11,2004 lower hood cover, condensation air conditioning system
807 05/2001 11/2004 single solenoid valves brake booster
بورشه
P 911 Cabrio (993) 08,1993 01,1998 cover
Carrera S, Carrera 4S 04,2004 10,2005 exhaust of welding seams
Cayenne 01.10.2002 17.12.2003 rear seat harness releases
Cayenne 01.10.2002 19.07.2003 wiring harness
رينو
Clio 08.05.2003 18.10.2005 wires horn
Clio 07. 09.10.2002 front wheel suspension
Clio, Megane 10.11.2005 29.05.2006 controller of the automatic transmission
Espace 01.09.1996 11.12.1998 spare wheel mounting plate
Laguna 18.07.2001 15.05.2002 ABS, ESP
Laguna 01,2001 10,2002 fuel injection system
Laguna II, Vel Satis, Espace IV to 05.04.2005 recycling of exhaust gases valve
Laguna, Vel Satis, Espace 03,2001 03,2004, 10,2004 02,2005, 10,2002 02,2004, 10,2004 02,2005 clutch master cylinders;
Mégane CC 10,2003 07,2005 A-column-cover 14,550
Mégane CC 09,2003 06,2004 Hardtop
Mégane II 19.10.2002 30.12.2002 b rake
mode to 05.04.2005, 14.09.2004 24.10.2004 steering column, real axle springs
Scénic to 12,2005 seat harness releases
Scénic 2003 26.01.2004 brake pedal carriers
Scénic June 2006 steering column Vel Satis since commencement of production engine sensors
Vel Satis, Espace 0 1,2002 12,2005, 01,2002 11,2004 motor control, cooling agent header tank
رولزرويس
phantom 01,2006 03,2006 shock absorbers
روفر
ROVER 75 10,1999 02,2002 wheel suspension
ساب
SAAB 9-3 11,2005 wheel bearings
9-3 1.8t, 9-3 2.0t, 9-3 2.0T 2003 2005 master brake cylinders
9-3, 9-5 2000 2002 ignition system
9-5 1998 2003 wheel bolts Seat
Alhambra 2002 2003 clutch
Cordoba, Ibiza 2004 head and side airbags
سمارت
Forfour 04,2005 09,2005 attachment rear seat surface
Fortwo 01,2006 04,2006 seat attachment
Fortwo 1998 2000 support arms front axle
سوبارو
Outback, Forester 2001 to 2003, 2003 to 2004 cruise control
Swift 05,2005 04,2006 clutch
سوزوكي
Grand Vitara 1,9 DDiS JT 12,2005 08,2006 load air tube
Grand Vitara XL7 2 2.11.2000 25.02.2004 wiring glow relay
Ignis 2003 2006 p assenger airbag
Swift 2005 to 2006 parking brake rope
Swift 2005 master brake cylinders
SX4 2 006-2007 emergency brake 4090 R Suzuki Vitara V6 1998 2003 pressure control valves gasoline line
Wagon R+ 2000 2003 gas through train
Wagon R+ 1,0, Wagon R+ 1,2 1997 2000 switching push pull cable
تويوتا
Avensis 06,2004 07,2004 chassis sensor
Avensis 15.01.2003 05.11.2003 steering element
Avensis 1,8 VVT i 01,2003 12,2005 steering column
Corolla 1,4 D-4D, Corolla 1,4 VVT i, Corolla 1,6 VVT i 07,2003 11,2005 steering column
Corolla 2,0 D-4D, Avensis 2,0 D-4D 02,2003 03,2005 pressure tubing brake booster
Corolla Verso 01,2004 05,2006 Passenger airbag
Hilux 07,2005 12,2005 exhaust hose
country Cruiser of 120 09,2002 06,2005 master brake cylinders
Landcruiser 90 04,1996 01,1999 drive shaft flange
country Cruiser 90 2001 2003 front axle
Mazda 6 MRZ-CD 03.10.2005 29.12.2005 screw connection cam shaft sensor plate
Prius 07,2003 11,2005 steering column Prius k.A. stop light switch
Prius, Yaris, Yaris Verso 02,2001 10,2001 crankshaft sensor
RAV4 06,2002 09,2004 s teel wheels
Yaris 11/2005 to 07/2006 rear seat head restraint
Yaris 11/2005 to 02/2006 front seat head restraint
Yaris 11/2005 to 02/2006 side airbags in front
Yaris, Yaris Verso, Celica 2000 2002 master brake cylinders
فولفو
C70 2007 left cable door handle
S40, V40 2003 fuel pipe
S40/V50 2003 2005 fuel pump
S40/V50 2004 2005 emergency brake
S60, S80, V70 2004 screw connection wishbone
S60, S80, V70, XC70 2000 2001 cooling regulation
V50 2007 spotwelds in the roof
XC90 2002 2005 ball joint tie rod
XC90 2004 wheel number of revolutions sensor
XC 90 all software 2,500 S Volvo XC90, S80 2005 2006 battery cables
فولكسفاجن
Beetle 05,2006 10,2005 combination instrument
Fox 06,2004 12,2007 hood bolting device
gulf 11,2006 01,2007 ground wire air additional heating system
trade wind 2005 2007 wiper engine, owner fuel radiator, vacuum piping
trade wind of 2006 s oftware faults
trade wind 08,2003 11,2003 screw at the shock absorber camp
trade wind 1996 1999 support arms front axle
trade wind 2,0 TDI 04,2005 05,2005 clutch
Polo 2006-2007 seat heating
Sharan 2003 2004 clutch
Sharan 2001 2005 xenon light,pressure pipe turbo
T5 California 2004 04,2005 camping gas plant
T5 Multivan to 08.06.2004 emergency brake
Taro 1989 1996 steering element
Touareg 01.10.2002 17.12.2003 rear seat harness releases Touareg wiring harness
أرجو أني أكون أفدتكم ..
