نفسى المنتدى يرجع زى زمان و الناس لما يكون فيه حاجه مش عارفينها ندور على المعلومه عشان نستفيد و غيرنا يستفيد
البتاع ده اسمه مجفف (الترجمه من الانجلش) و بيكون فى داخله فلتر و بيتسد و لما بيتسد التكييف ميبردش
يسموه بالعربى اى حاجه تانيه مش مهم, المهم ان هو ده, و هى دى وظيفته
RECEIVER-DRIER
The receiver-drier is used on the high side of systems that use a thermal expansion valve. This type of metering valve requires liquid refrigerant. To ensure that the valve gets liquid refrigerant, a receiver is used. The primary function of the receiver-drier is to separate gas and liquid. The secondary purpose is to remove moisture and filter out dirt. The receiver-drier usually has a sight glass in the top. This sight glass is often used to charge the system. Under normal operating conditions, vapor bubbles should not be visible in the sight glass. The use of the sight glass to charge the system is not recommended in R-134a systems as cloudiness and oil that has separated from the refrigerant can be mistaken for bubbles. This type of mistake can lead to a dangerous overcharged condition. There are variations of receiver-driers and several different desiccant materials are in use. Some of the moisture removing desiccants found within are not compatible with R-134a. The desiccant type is usually identified on a sticker that is affixed to the receiver-drier. Newer receiver-driers use desiccant type XH-7 and are compatible with both R-12 and R-134a refrigerants.
Automotive Air Conditioning Systems
Drier or Accumulator: The drier, also known as the receiver-drier, is sort of the safety catch for your system. The compressor is only supposed to compress the gas form of your refrigerant. However, there's always a chance that some liquid could make it back that far. The drier catches this liquid before it can damage your compressor. Since even the tiniest leak or careless installation can introduce water moisture to the system, the drier absorbs this chemically, using what's called a dessicant (similar to that packet of "DO NOT EAT" that comes with electronics). The drier also has a filter that catches any gunk that might be in there.
Air Conditioning - How Does A/C Work - Automotive Air Conditioning Components De......ion
mohammedabdallh استاذ
عملت ايه؟؟
