Nubira head (stock) with "bumps" removed in exhaust ports for better flow.
EGR port blocked off.
Custom built intake plennum with 71mm throttle body.
700cc injectors fed by a custom built fuel rail.
External adjustable fuel pressure regulator
255LPH Wallbro intank fuel pump feeding Bosch 10bar fuel pump up front
Steel Opel headgasket
ARP headbolt set
Engine bottom end:
Opel 2l 8V block with standard crank and modified oil pump
Wossner forged pistons - 86.5mm
Forged Chrome molly standard length conrods - shortened with 1mm to further drop compression
ARP conrod bolts
ARP flywheel bolts
6 x button copper clutch - solid
Opel TS pressure plate
Standard flywheel.
Turbo and accessories:
Ballbearing thick shaft turbo as follows -
T3/0.63 exhaust housing machines to fit dash 2.5/T4 exhaust wheel, T61 compressor wheel married to a AR50 compressor housing.
63mm boost pipes throughout.
Tial(copy) dumpvalve - 50mm.
LARGE front mount intercooler.
Custom built turbo branch
38mm Turbonetics Evolution wastegate
76mm exhaust system front exit at bumper
Adjustable electronic HI/LO boost controller
Additional goodies/odds:
Opel TS big brake upgrade on front with slotted rotors
Front mount Oil cooler
Opel superboss alluminium sump
Opel Coupe F23 gearbox - NO LSD
Solid cast polyurethane engine mounts
Front control arm modifications - removed soft rubber bushing and replaced with spherical bearing.
Standard CV`s and side shafts
Standard Nubira cooling system
Electronics:
Dicktator stand alone engine management system
2.5bar boost gauge
Fuel pressure gauge
Air Fuel ratio gauge
Accessories/body:
Reclinable racing seats
Sport steering wheel.
1/2 roll-cage - powder coated
5 point safety harness
Custom made front bumper
