Ahmed i want a clearing from you on one main Point that you mentioned which is washing the air filter cause what i understand that if i am to wash it the fibers in it would go bad so for how long you have been doing that ?
Hi Mr. Ayman
I wash the filter element every 10,000 to 15000 kms. I do this in my Daewoo lanos & in my dad's Nissan Sunny
I think you can do this 4 or 5 times then it is advisable to throw the element because the element could get cut & in that case dirt could come inside your engine while you are unaware of that & in that case some damage could happen - you can add 1 drop of downy to make the fabric soft & in that case you can at least double the age of the filter element.
The cleaning process takes 5 minutes & then you leave the element to dry over night but offcourse you have to seal the air filter withe the element embedded there the correct way
I hope I have clarified every thing
Thanks for your inquiry
Ahmed Samy
ايه نظام جلد الذات ده
وبعدين ده انت معاك مرسيديس يعنى "زبون" تقيل :)
مبرووووووووووووووك على غبور الزبون المصري المحترم
Thank you for clearing that point and i did tried that last night after i read your post here and i left the filter to dry out till now but i need a clearing on one thing here when you say seal the filter with the element embedded so the element is what ?
Salamo aleko ostaz Ayman Ana asdy tetaked en el klepsat beta3et filter el hawa beta3ak tekoon makfoola kowayes 3alashan matedakhalshy torab
gowa el motor we kaman etaked en el filter nashef kowayes kabl ma tehotto
Ana asef 3alashan ma3andeesh 3araby 3ala el key board beta3y - 3alashan keda bakteb bel tareeka dee
ghaseel filter el hawa zay ma hadretak shoft benefsak akeed nazel teena we el filter akenno gedeed we el haraka dee betfawak el arabeya keteer we momken beykoon leeha ta2theer3ala estehlak el banzeen we el sa7b beta3 el 3arabeya
:C_laugh[1]::C_laugh[1]::C_laugh[1]::C_laugh[1]::C_laugh[1]::C_laugh[1]:
i agree with you ...
i hope all people be like you & not to be a (ZOBON)
يقول ال ليها و ال عليها
لكن مش علشان اشتراها يتحول ويبقي كانو شغال في توكيلها :satelite:
مش ساعات دا كتير اوي
في الحته دي بالذات الشعب المصري كلو بلا استثناء زبون عند التوكيل و الحكومه
Not to worry if you are writing in English or Franco Arabic.
I just wanted to make sure that we are on the same page here and thanks again for clearing that point to me and when i washed the filter it had dirt and it was badly black.
and no it's better and cleaner for sure and that's my second filter as i changed the first one at the dealer but actually after your post here i don't think i would need to change it again.:satelite:
