انا شوفت الفيرجن من شوية لقته 3.50 يعني ينفع فيه لتعديل :d
لكن بصراحة انا مش عارف اعمله لأني ميح خالص والله يا ميدو :d :d طيب سؤال انتا جيبت الجيمز من فين من على النت ؟ يعني اوداماك الأوبشنز ايه ؟
نزل الملف دا
MEGAUPLOAD - The leading online storage and file delivery service
بس سيبك من gaia manager 2.01 اللى جوا الملف ونزل النسخة الجديدة من اللينك دا
http://psx-scene.com/forums/attachme...-gaia-2-07-rar
وامشى ورا التعليمات اللى تحت دى وان شاء الله هتعملها وهيبقى كله تمام
انا عملتها فى 3 بلاى ستيشن عندى وعند اصحابى وكله تمام
كود:Inside this zip you will find:
- OFW 3.55 Folder
- CFW 3.55 Folder
- Gaia Manager 2.01 Folder <-- Outdated look at bottom of first post for Gaia 2.07 download.
- readme.txt
#1. Create on the root of a USB (formatted FAT 32) the following folders: \PS3\UPDATE\
#2. Which firmware is currently installed on your PS3?
If you're on 3.55 Official Firmware jump to step #3.
If you're on 3.55 CFW reinstall OFW from recovery mode then jump to step #3 [ame="http://www.youtube.com/watch?v=_2YnGGUOJks"]YouTube - How to get the Recovery Menu on your PS3[/ame]
If you're on 3.50 or less keep reading.
Rename the PUP inside the OFW 3.55 SONY folder (OFW3.55.PUP) to PS3UPDAT.PUP
Then put the renamed PUP into the folder you just create inside your USB‚ example:
\PS3\UPDATE\PS3UPDAT.PUP
Install PUP into the PS3 from XMB (Settings > System Update > Update via Storage Media)
#3. Now you're on Official 3.55 firmware its time to install the kmeaw custom firmware.
#4.Rename the PUP inside CFW 3.55 Folder (CFWkmeaw.PUP) to PS3UPDAT.PUP
Then put the renamed PUP into the same folder you just create inside your USB‚ example:
\PS3\UPDATE\PS3UPDAT.PUP (if asked to overwrite say YES)
#5. Go to Settings > System Update > Update via Storage Media and install the kmeaw Custom Firmware
note - if a message appear saying you already got the latest version turn the PS3 on Recovery Mode and choose System Update from the menu
#6. After reboot you should see the install package file and the app_home/PS3_GAME/ inside the Game Folder
#7. Add the package UP0001-GAIA01985_00-7679866932773369-GAMEZ located inside the Gaia Manager 2.01 Folder to the root of any USB and install from the Install Package files option.
يعني مبدئيا الجيمز ها تكون من المحل عشان انا برضه لو ترنت ممكن اقعدلهم غير كده لا ممكن ابدا :d :d
وحوار التعديل ده بقى !! مدام هوة 5 دقائق وبيخلص :d
بكرة الصبح ورقة وقلم ها اجيبهم واقعدله بقى وحبة حبة وراه لحد ما اخلصه :d لو عجزت فيه ها اقول لحضرتك :d
لقيتها قفلت خالص ها اوديه للمحل وامري لله :d متشكر جدا لحضرتك يا فندم :d
وتعبت حضرتك معايا :d
متشكر يا ياسر بيه جدا جدا جدا جدا :d :d
انا ها اعمل داونلود للفايلين دول حالا وبكرة ها ابدأ الموقعة الحربية دي :d
دا لينك لصفحة فيها التعليمات عشان مش عارف هى مظهرتش كلها ليه هنا
CFW kmeaw + OFW 3.55 + GAIA 2.05 ready to install pack
انا نزلت الـ gaia2.07 وخلصتها بعمل داونلود للتاني وها اشوف الخطوات وعلى بكرة ها انفذ واللي يقف معايا ها تلاقيني بسأل حضرتك لأنه الخطوات انا شايفها سلسلة وسهلة مفيش فيها صعوبة بالنسبالي الحقيقة مدام الناس كلها بتقول الموضوع سعل :D
بص يا حجنا انا فهمت التالي !!
1- اجيب فلاشة تكون معملها فورمات بنظام الـ Fat32 ودي مفهومة وقضيت !!
2- اعمل فولدر على الفلاشة واحد بإسم PS3 والتاني UPDATE
خطة 2 دي انا مخلصها والجهاز طلع 3.50 على ما اذكر وها اتأكد لما اشوفه بكرة تمام التأكيد
3- بعد ما اتأكد انه السيستم عندي 3.55 ولو مش عندي 3.55 ها اعمل خطوة 2
انا دي مش فاهمها !! لأنه كده معنا الإختصار ده انه المفروض ها يكون عندي فولدر اسمه PS3 جواه فولدر اب ديت !!وجواهم الـ pup دي !! انا من هنا الموضوع ساقط مني بصراحة !! مش عارف العيب فيا ولا فيه !!
بس عشان اقطع الشك باليقين بكرة ها اتأكد من الفيرجن بتاعه وها اقول لحضرتك
لا انت فى خطوة سقطت منك
عشان السوفتوير عندك 3.50 لازم تعمل install للسوفتوير الاصلى باردوا بس نسخة 3.55 قبل ما تعمل install للسوفتوير المعدل.
يعنى هتاخد الملف اللى هو OFW3.55.PUP اللى جوا الفولدر اللى اسمه OFW 3.55 SONY وتعمله rename لـ PS3UPDAT.PUP وتحطه على الفلاشة جوا فولدر UPDATE ودا اللى جوا فولدر PS3 طبعا
وبعدين عشان تعمل Install .. هتروح على Settings > System Update > Update via Storage Media
وبعد لما تخلص كل حاجة وكله تمام .. تاخد الملف اللى هو CFWkmeaw.PUP من جوا الفلولدر اللى اسمه CFW 3.55 kmeaw وتعمله rename لـ PS3UPDAT.PUP وتعمله copy للفلاشة فى نفس المكان زى المرة اللى فاتت وطبعا ساعتها هيقولك ان فيه ملف بنفس الاسم فا هتدوس ok
وتعمل الخطوات تانى بتاعت الـ install
وبعد ما تخلص ان شاء الله لما تفتح الجهاز وتروح على games هتلاقى فيه فولدرين جمبهم نجمة .. يبقى كدا السوفتوير المعدل نزل بنجاح.
نيجى بقى للـ install بتاع gaia manager ودا الى برنامج اللى انت بتشوف منه الالعاب وتشغلها من عليه .. ممكن تسيب الخطوة دى للرجل اللى هينزلك الالعاب او تعملها بنفسك زى ما تحب بس هى سهلة جدا
هتاخد الملف اللى جوا فولدر gaia manager .. واسمه UP0001-GAIA01985_00-7679866932773369-V2.07-GAMEZ.pkg وخلى بالك يكون كلمة gamez بالـ z مش الـ s
هتلاخد الملف وتعمله copy للـ root بتاع الفلاشة .. يعنى متحطهوش فى فولدر وبعدين تدخل على فولدر من الفولدرات اللى ظهرتلك فى playstation بعد السوفتوير الجديد وهو فولدر Install Package files وهتلاقى الملف اللى انت لسه كنت حطه على الفلاشة ظهرلك وهتروح عمله Install وخلاص كدا هتكون خلصت.
على فكرة انا عندى العاب كتير لو انت عايز
دول شوية منهم:
red dead redemption
siren
killzone 2
motor storm
heavenly sword
GT5 prologue
GT5
little big planet
RaC quest for booty
wipeout hd
virtua fighter 5
burnout
juiced 2
fifa street 3
GTA 4
midnight club
just cause 2
mafia 2
smack down
inferno
blur
prince of persia
dead rising 2
WRC
PES 2011
call of duty 7
fifa 11
superbike world championship
dirt 3
....l gear solid 4
nfs undercover
batman arkham asylum
fight night 4
nfs shift 2
crysis 2
