would you like to hear the long version??
the servo looks bigger on the Aveo... i can't confirm that as i didn't research it but on looks alone it looks bigger
the master cylinder is smaller in size... again not sure about the inner diameter but i suppose it is the same as the lanos but still the length of the master cylinder is shorter and the proportional valves are smaller... also its mounting bracket on the servo got a different design than the lanos
the brake pads are different in shape... not much difference in size if any at all but the shape is indeed different and you can't swap the lanos with the aveo pads
the rotors are the same... this is the only common item between both systems
calipers are different in design... again the size of the piston is the same but the mounting bracket is different... it is more like the one found on the nubira so their is no way it will fit a lanos
