جميع موديلات أستون مارتن الحالية
1- DB9 :
Engine
- All alloy, quad overhead camshaft, 48-valve, 5935cc V12
- Compression ratio 10.3:1
- Visteon engine management controlling fuel injection, ignition, diagnostics and misfire detection system.
- Stainless steel by-pass valve exhaust system
- Maximum power 335 kW (450 bhp) at 6000 rpm
- Maximum torque 570 Nm (420 lb ft) at 5000 rpm
- Acceleration 0-60 mph in 4.9 seconds
- Maximum speed 186 mph (300 km/h)
http://www2.0zz0.com/2007/06/09/08/91501425.jpg
http://www2.0zz0.com/2007/06/09/08/83011162.jpg
http://www2.0zz0.com/2007/06/09/08/28944470.jpg
http://www2.0zz0.com/2007/06/09/08/13250005.jpg
2-V8 Vantage:
Engine:
- All alloy quad overhead camshaft 32 valve, 4.3 litre V8
- Variable inlet camshaft timing
- Dry sump lubrication system
- Fully catalysed stainless steel exhaust system with active bypass valves
- Front-mid mounted engine
- Rear wheel drive
Projected Performance figures:
- Maximum power: 283kW (380 bhp) @ 7300 rpm
- Maximum torque: 410Nm (302 lb.ft) @ 5000 rpm
- Maximum speed: 175 mph
- 0-60 mph in 4.9 seconds
- 0-100 km/h in 5.0 seconds
http://www4.0zz0.com/2007/06/09/08/77730889.jpg
http://www4.0zz0.com/2007/06/09/08/45442732.jpg
http://www2.0zz0.com/2007/06/09/08/94881395.jpg
http://www4.0zz0.com/2007/06/09/08/64508923.jpg
3-Vanquish S:
Engine
All alloy, quad overhead camshaft, 48-valve, 5935cc 60° V12. Front engine, rear-wheel drive.
Twin PTEC engine management system controlling fuel-injection, ignition and diagnostics.
Fully catalysed stainless steel exhaust system with active by-pass valves.
Compression ratio: 10.8:1.
Maximum power: 388 kW (520 bhp) at 7000 rpm
Maximum torque: 577 Nm (425 lb.ft) at 5800 rpm
Acceleration: 0-100 km/h (62 mph) in 4.8 seconds
Maximum speed: Over 200 mph
http://www4.0zz0.com/2007/06/09/08/25246284.jpg
http://www4.0zz0.com/2007/06/09/08/10053949.jpg
http://www4.0zz0.com/2007/06/09/08/46897090.jpg
تم التثبيت من قبل الإدارة
