النتائج 1 إلى 10 من 17
    الصورة الرمزية eyadmorsy
    رقم العضوية : 19136
    الاقامة : Maadi
    السيارة: لانوس 99
    السيارة[2]: صنى 2010
    دراجة بخارية: fasaka
    الحالة : eyadmorsy غير متواجد حالياً
    Smile Cd/dvd/vcd/mp3/mp4 receiver/usb/sd/mmc - Facebook Twitter whatsapp انشر الموضوع فى :
    على بركة الله للبيع:
    New Car ... DVD VCD MP3 AUX channel with front / rear power 60Wrms x4CH + AM / FM + USB / SD / MMC Card sound like every other low-cost delivery throughout Thailand. High quality products. New + Warranty: 1 year
    Overview:.
    NEW Model: TL-9081.
    DVD VCD MP3 player, keyboard design much more. Ease of connection to other audio systems. We have to play through the AUX 2 is the front to the rear is connected to the Notebook iPod can do it fast. The design is beautiful dark black lines can play. Almost every category. The disc copies. Plate - scratches. It can be played back. Excellent suspension system. No interruptions while driving. With the feature-rich USB / SD / MMC can be connected to a high-capacity HDD Computer radio receiver with Digital AM / FM growing up 60Wrms x 4CH.
    Feature:.
    <Disc to disc copy of the original CD or DVD format in time for all.
    <Crystal clear sound. With the decoding 24Bit/96Khz.
    <Growing Mosfet 60 Wrms x4Ch.
    <Aux jack on the front and rear.
    <DVI USB / SD / MMC Card.
    <Previous Pat removable glow.
    <Radio AM / FM.
    Speccification:.
    Playback mode = DVD, DiVX. SVCD, VCD, MP3, CD, HDD, CD, JPEG, CD-R, CD-RW, XVID, NERO.
    Growing out of the speakers = Mosfet 60 Wrms x 4 CH @ 4 ohm Max power output.
    Memory USB = USB 2.0 USB / SD / MMC Card.
    The image file = Viewing JPEG File function.
    Receiving Radio = AM / FM 30 preset stations.
    Audio input jack = 2 CH RCA input.
    Channel audio outputs = 2 CH RCA output.
    Input signal = 1 CH Video output.
    The screen lights = Colourful LCD display.
    Systems, vibration = Advance Electronics Shock Protection.
    Adjust the sound system = Preset EQ mode (Volume Bass Treble Fader Balance).
    The audio decoder = Dolby digital AC-3, 5.1 CH Support 24 Bit/96 KHz.
    Supported languages ​​= Supporting Multi languages ​​(Subtitle and Angles).
    Picture = PAL / NTSC.
    Scan rate = Max search 2X - 20X.
    Remote = Card Size Full Function Remote Control.
    Power = Supporting DC 12V Power Supply.
    Cooling = Aluminium Heat Sink.
    Dimensions = 1 DiN ISO Mounting Dimension.
    Size = ISO.
    Accessories:.
    > Remote.
    > The machine.
    > Manual.
    > Box.
    > Plaque on the machine.
    > The connector cables
    http://www.nileup.com//view.php?file=fe88ff7c06
    تايلندى أصلى جديد بالكرتونة وجميع محتوياته ، ريموت متعدد الوظائف
    للإتصال 0171384334 - إياد محمد
    الصورة الرمزية refa3y2
    رقم العضوية : 33213
    الاقامة : الزقازيق
    السيارة: Peugeot 405
    السيارة[2]: Peugeot 405
    الحالة : refa3y2 غير متواجد حالياً
    مطلوب كام
    رقم العضوية : 19136
    الاقامة : Maadi
    السيارة: لانوس 99
    اقتباس المشاركة الأصلية كتبت بواسطة refa3y2 مشاهدة المشاركة
    مطلوب كام
    هو بيتباع فى بلده حوالى 600 ..فى مصر بعد النقل....
    الصورة الرمزية taswos
    رقم العضوية : 2094
    الاقامة : Sinai
    السيارة: lancer+Golf4
    السيارة[2]: Lanos+504
    دراجة بخارية: لا املك يابشر
    الحالة : taswos غير متواجد حالياً
    يعنى بتبيعه بكام ؟ ب٦٠٠!!
    كل ما امتلكته فى حياتى ,ومازال البحث مستمرا
    [rmade]http://i52.tinypic.com/2uhwwwg.jpg[/rmade]
    الصورة الرمزية shokri99
    رقم العضوية : 90164
    الاقامة : ismailia
    السيارة: Lancer
    السيارة[2]: brilliance
    الحالة : shokri99 غير متواجد حالياً
    يا جماعه حد عارف بعد النقل كام......... ولا كرمبو هيحلها ههههههههههه
    الصورة الرمزية mhbcas
    رقم العضوية : 89655
    الاقامة : Tanta
    السيارة: Opel Vectra 2003 2000/cc
    السيارة[2]: Nissan Murano 2007 3500/cc
    دراجة بخارية: kjnk
    الحالة : mhbcas غير متواجد حالياً
    متابع
    لا اله الا انت سبحانك انى كنت من الظالمين
    [sor2]http://store1.up-00.com/Jun11/Xfj00854.jpg[/sor2]
    رقم العضوية : 19136
    الاقامة : Maadi
    السيارة: لانوس 99
    اقتباس المشاركة الأصلية كتبت بواسطة shokri99 مشاهدة المشاركة
    مش محتاجة كرومبو شايلينه لوقت عوزة ، يعنى بعد ارتفاع اسعار وقود الطائرات والذى منه
    الصورة الرمزية ahmad--ezzat
    رقم العضوية : 6201
    السيارة: nissan sunny ex 2008
    السيارة[2]: Sonata 2013
    الحالة : ahmad--ezzat غير متواجد حالياً
    انا مش فاهم دة ايه باظبط؟
    الاستخدام قد ايه
    بيشغل دى فى دى على ايه
    قوته قد ايه
    مكان حضرتك فين
    السعر المطلوب كام
    حضرتك جبته منين
    ياريت لو تقولنا صوته اخباره ايه
    م/ احمـد عـزت
    رقم العضوية : 2094
    الاقامة : Sinai
    يعني نقول وزنه وضرايبه وجماركه ١٠٠ يبقي ٧٠٠
    الصورة الرمزية tananybasha
    رقم العضوية : 23085
    الاقامة : Giza
    السيارة: لايوجد حالياً
    السيارة[2]: Opel Vectra A Sport 2.0L M/T
    دراجة بخارية: هوندا 1000
    الحالة : tananybasha غير متواجد حالياً
    لو أن ابن آدم هرب من رزقه كما يهرب من الموت لأدركه رزقه كما يدركه الموت
    محمد الطنانى
  1. Cd/dvd/vcd/mp3/mp4 receiver/usb/sd/mmc
    بواسطة eyadmorsy في المنتدى قســم خاص لبيع السيارات فقـــط
    آخر مشاركة: 23-01-2012, 01:57 AM
  2. Communications Receiver
    بواسطة Mina-Magdy في المنتدى نايل موتورز مول
    مشاركات: 1
    آخر مشاركة: 05-09-2011, 09:28 AM
  3. GPS Receiver and HTC Mobile
    بواسطة abou_ruqi في المنتدى نايل موتورز مول
    آخر مشاركة: 31-03-2011, 07:19 PM
  4. Bluetooth GPS Receiver
    بواسطة amr5500 في المنتدى ساحة الملاحه البرية وتحديد المواقع GPS اجهزة وخرائط
    مشاركات: 21
    آخر مشاركة: 27-02-2011, 02:08 PM
  5. ال Receiver و ال DSL
    بواسطة ali1spc في المنتدى المنتــــــدى الاجتمــاعى
    آخر مشاركة: 23-11-2008, 03:56 PM
