Does anyone have the specification of both cars.
Dimensions
Overall length 3335 mm
Overall width 1440 mm
Overall height 1405 mm
Wheelbase 2175 mm
Minimum turning radius 4.4 m
Ground clearance 170 mm
Seating Capacity 4 persons
Weight
Unladen weight 665 kg (AC BS III), 650 kg (Std. BS III)
Laden weight 1000 kg
Engine
Type 4 stroke cycle, water cooled SOHC (1C2V)
No. of cylinders 3
Piston displacement 796 cc
Maximum output (Std.,AC) 37 bhp at 5000 rpm
Maximum torque (Std.,AC) 59 Nm at 2500 rpm
Power Transmission
Std., AC 4-forward, all synchromesh,
1 reverse
Steering
Steering Rack & pinion
Suspension
Front McPherson strut & coil spring
Rear Coil spring with gas filled shock absorbers
Brakes
Front Disc
Rear Drum
Tyres
Tyre size (Radial) 145/70 R-12
Capacity
Fuel tank capacity 28 liters (BS III)
Kerb weight ALTO 720 kg
ALTO LX/ALTO LXi 735 kg
Gross vehicle weight 1165 kg
ENGINE
Swept volume 796cc
Engine type FC engine, 4 valves
Per cylinder MPFI
No. of cylinders 3
Engine control 32 bit computer
Maximum power 47 ps @ 6200 rpm
Maximum torque 62 Nm @ 3000 rpm
Transmission 5 speed, all
synchromesh, manual
SUSPENSION SYSTEM
Front McPherson Strut with torsion type roll control device
Rear
Coil spring gas filled shock absorbers with three link rigid axle and isolated trailing arms
SEATING
Capacity 5 persons
TYRES
Tyre size 145 / 80 R12
DIMENSIONS
Overall length 3495 mm
Overall width 1475 mm
Overall height 1460 mm
Wheelbase 2360 mm
Tread Front 1295 mm
Rear 1290 mm
Minimum turning radius 4.6 m
Ground clearance 160 mm
