رقم العضوية : 102
السيارة: Daewoo Lanos I 1999
دراجة بخارية: N/A
رقم العضوية : 102
دراجة بخارية: N/A
رقم العضوية : 102
دراجة بخارية: N/A
the Nubira servo is 9" just like the lanos one... they both provide the same mechanical assistance so it is pointless to swap the servo...
moreover the mounting bracket of the servo in the lanos is very different and if you tried this the servo will be located much further to the front and you will have to fabricate a new push rod to operate the brakes and relocate all 4 oil pipes... and in the end you will get the same assistance so it is totally pointless (i know that because i have tried it while replacing my faulty servo and thought a nubira servo is a good idea)
the nubira brakes are better because it has bigger rotors and calipers... the lanos brake upgrade will get you same diameter rotors and similar calipers and the same brake pads
رقم العضوية : 48840
السيارة: Chevorlet Lanos
السيارة[2]: Hyundai Excel
رقم العضوية : 102
دراجة بخارية: N/A
well... it is not THE good idea for you right now since you haven't upgraded anything in your braking system... for me it might be interesting since i have already upgraded everything and i have nothing else to upgrade but the servo... will let you know if i got any positive feedback from this project
رقم العضوية : 48840
