[edit] first generation (2002–2008)
first generation
http://upload.wikimedia.org/wikipedi...edan_front.jpg
the european daewoo nubira, also called lacetti also called hatchback:
buick excelle hrv chevrolet lacetti chevrolet optra5
daewoo lacetti
holden viva suzuki reno
sedan:
buick excelle chevrolet lacetti chevrolet optra daewoo nubira holden viva suzuki forenza chevrolet optra magnum
wagon:
buick excelle chevrolet lacetti chevrolet optra chevrolet optra xl
chevrolet nubira
chevrolet estate (
indonesia)
daewoo nubira holden viva suzuki forenza production 2002–2008
uzbekistan: 2008–present
russia: 2007–present assembly
bupyong,
south korea bogota,
colombia valencia,
venezuela rayong,
thailand ha noi,
vietnam ust-kamenogorsk,
kazakhstan miaoli,
republic of china asaka,
uzbekistan
halol, india
body style 4-door
sedan
5-door
hatchback
5-door
wagon engine 1.4 l 93 bhp (69 kw) petrol
i4
1.6 l 106 bhp (79 kw) petrol
i4
1.8 l 120 bhp (89 kw) petrol
i4
2.0 l 126 hp (94 kw)
i4
2.0 l 127 hp (95 kw)
i4 transmission 4-speed
automatic
5-speed
manual wheelbase 102.4 in (2,601 mm) length 177.2 in (4,501 mm) (sedan)
169.1 in (4,295 mm) (hatchback)
179.7 in (4,564 mm) (forenza station wagon)
180.3 in (4,580 mm) (optra station wagon) width 67.9 in (1,725 mm) height 56.9 in (1,445 mm) (sedan & hatchback)
59.1 in (1,501 mm) (station wagon)
curb weight 2756 - 2855 lbs (1220 - 1290 kg)
designer giorgetto giugiaro pininfarina [edit] market [edit] south korea
in south korea, the 4-door
daewoo lacetti was released in 2002. The 5-door hatchback showed off only after the 2004 facelift of the sedan, which mainly included a new front grill, switching from a three-part corporate daewoo grill to a simpler, chevrolet-style grill. The hatchback name was
lacetti5, offering a specific design for the front, rear and dashboard.
The wagon version, called simply
lacetti wagon, was introduced in late 2007 - strangely as it was already sold in many other countries. It had the same dashboard than the hatchback, with the sedan front end. At the same time, gm daewoo introduced the
vm motori diesel engines on the lacetti range.
When the
lacetti premiere was introduced in november 2008, the sedan and wagon version sales were discontinued, leaving the only hatchback in the range, renamed
lacetti ex. The lacetti ex was discontinued in october 2009.
[edit] australia
in
australia and
new zealand, the daewoo lacetti was briefly sold between 2003 and 2004 as a four-door sedan. During the 'asian economic crisis', daewoo became technically insolvent and the company withdrew from the australian market.
http://upload.wikimedia.org/wikipedi...1-01-05%29.jpg http://bits.wikimedia.org/skins-1.18...gnify-clip.png
holden viva (jf) sedan
from 2005, the lacetti (sedan and wagon) and lacetti5 were sold together as the
holden viva. It was introduced at around the same time as the
daewoo gentra-based
holden barina. Unlike the current barina, however, the viva was meant to be below the premium
holden astra as a budget alternative.
Despite the viva's lower price compared to the astra (a$17,990 compared to
a$21,990), the astra continued to outsell the viva by a factor of about two-to-one.
[1]
with the release of the all new
holden cruze in mid 2009 the viva ceased to be sold in australia.
[edit] canada
the lacetti was available in
canada as the
chevrolet optra in two models, a four-door hatchback (the
optra5), and an optra wagon, all in ls or lt trim levels (2005 wagon only had base or ls trim levels) . The sedan was available in 2004 and 2005, but was removed in 2006. All are powered by the 2.0 l inline-4 d-tec engine, rated at 119 hp (89 kw) at 5400 rpmand 126 ft·lbs (171 n·m) of torque at 4000 rpm, driving the front wheels through either a 5-speed
manual transmission or a 4-speed
automatic. Despite its compact size and the 2.0l engine, fuel economy was poor rated at 10.7l/ 100 km for city and 7.4 for highway driving which was worse than midsize cars like the
toyota camry or
honda accord, considering that the optra was a compact car.
[2]
the car was positioned as a versatile and fun to drive but affordable budget compact family car. Brakes are disc, front and rear. The optra slotted between the
cobalt and the
aveo, and it replaced the
daewoo nubira.
http://upload.wikimedia.org/wikipedi...%28rear%29.jpg http://bits.wikimedia.org/skins-1.18...gnify-clip.png
chevrolet optra5 (canada)
independent suspension, 15-inch wheels, and
cd player were standard on the ls sedan, with optional
abs and air conditioning; the lt adds standard air conditioning and cruise control, standard fog lamps on both ls & lt, and an optional sunroof. Length is 177.7 in (4515 mm) on a 102.4 in (2600 mm) wheelbase; width is 67.9 in (1725 mm), height 56.9 in (1445 mm) and weight 2756 lb (1250 kg). The sedan is rated as an ultra low emissions vehicle.
The optra5 hatchback was added to the lineup in 2004 and was more contemporary in styling and equipment, with projector type headlights and fog lamps, clear taillight lenses, blackout grille, and minimal front and rear overhang with length only 169 in (4295 mm) on the same wheelbase, height, and width. Weight is 2765 lb (1254 kg). In addition to the same options available on the sedan ls and lt models, an options package containing alloy wheels, sunroof, spoiler, leather steering wheel and shift knob, and steering wheel mounted controls for the 8 speaker audio system was in keeping with the younger enthusiast market.
The optra wagon was also added to the lineup in 2005 but shares styling with the sedan. While wheelbase and width are also shared with the sedan, the wagon is taller at 59.1 in (1500 mm) and slightly longer at 179.7 in (4565 mm), and heavier at 2855 lb (1295 kg). The wagon has standard alloy roof rails, 60/40 folding rear seat, and a 12-volt power outlet in the rear compartment, in addition to the same options available on the sedan ls and lt models.
general motors canada discontinued the importation of optra for 2008.
[2] [edit] china http://upload.wikimedia.org/wikipedi..._excelle_2.jpg http://bits.wikimedia.org/skins-1.18...gnify-clip.png
2008 buick excelle hrv
in
china, the cars are marketed as the
buick excelle sedan or wagon and
excelle hrv (hatchback). The sedan, which is also assembled in china, features an updated exterior. Gm confirmed the excelle's successor at its extended product review in august 2009. The car will be based on the chevy cruze and will also be sold in the u.s. The second generation hatchback (excelle xt) made its debut in 2009 while the sedan (excelle gt) made its debut in 2010.
Main article:
buick excelle xt [edit] europe
in
europe, the car was initially sold as the
daewoo nubira, with the production model being introduced at the
frankfurt motor show in september 2003. However, by the end of 2004, it was rebadged
chevrolet lacetti throughout the continent. As with its home market, in some european markets, the
lacetti name is also used for the entire range of sedan, station wagon and hatchback models on the same j-series platform. In finland and germany, for example, only the hatchback is sold under the lacetti name.
http://upload.wikimedia.org/wikipedi...i_cdx_rear.jpg http://bits.wikimedia.org/skins-1.18...gnify-clip.png
euro-spec chevrolet nubira cdx kombi
the european models were initially only available with the following
gasoline-powered
4-cylinder engines:
- 1.4 l e-tec ii — 93 hp (69 kw) at 6300 rpm
- 1.6 l e-tec ii — 109 hp (80 kw) at 5800 rpm
- 1.6l dohc engine sedan (4-door) 109 bhp (81 kw) 0–100 km/h: 10.9 sec., top speed: 186 km/h (116 mph) mt 10–12 km/lite in the city. 13–15 km/lite on the highway.
- 1.6l dohc engine hatch (5-door) 109 bhp (81 kw) 0–100 km/h: 10.6 sec., top speed: 184 km/h (114 mph) mt
- 1.8 l e-tec ii — 120 hp (90 kw) at 5800 rpm
8.5-9.5 km/lite in the city. 12–14 km/lite on highway.
- 2.0 l e-tec ii — 132 hp (101 kw) at 5800 rpm
8.5–9 km/lite in the city. 12-13.5 km/lite on the highway.
- 2.0 l dohc engine sedan (4-door) 132 bhp (98 kw) 0–100 km/h: 9 sec., top speed: 202 km/h (126 mph) mt
a
diesel-powered version was later added to the line-up with these specifications:
- 2.0 l sohc turbo diesel engine, under vm motori licence of ra 420sohc (see list of vm motori engines), 121 bhp (90 kw), 280 nm torque from 2000 rpm, 0–100 km/h in 9 sec, 200 km/h top speed. This engine is available with 5-speed manual gear box and 5-speed automatic gear box. Consumption was declared between 5 and 7 l/ 100 km.
in
europe, the sedan version was initially sold as the
daewoo nubira. However, in late 2003, it was announced that daewoo will be rebranded chevrolet in some european markets. The
chevrolet nubira went on sale in early 2004, initially only in
eastern europe. When daewoo was rebranded chevrolet across europe by the end of 2004, the chevrolet nubira was renamed
chevrolet lacetti in some markets for the 2005 model year, which expanded the lacetti line-up to include both the sedan and station wagon versions in addition to the 5-door hatchback version, in line with korea.
The engines built for the nubira and its
badge-engineered twins are the same as in the lacetti hatchback and its badge-engineered versions. The 1.8l
4-cylinder engine is sourced from the australian car maker
holden and is identical to the engine used in the 2004
astra. It is commonly known as the "family 2 unit". All of them are
gasoline-powered 4-cylinder engines.
[edit] india
in 2002, the lacetti is manufactured in india and sold as the optra and the
hatchback version is sold as the
chevrolet optra srv (formerly known/sold as
chevrolet srv), which they plan to get out with a 2l diesel engine in the near future.
The optra is sold with two engine options, 1.6 l and 1.8 l. In the first option it is available in three trim levels, the elite, the elite ls, and lt royale. In the second engine option it is available in two levels, the lt and the lt at, the latter coming with automatic transmission.
In 2007 gm india came out with a diesel-engined optra called the
optra magnum. The magnum had a different nose, and interiors as compared to the petrol version. Subsequently the petrol version got the new nose treatment(like that of the optra srv but with a slightly different front grill) and tail lights, and are sold as optra magnum petrol/diesel.
[edit] pakistan
in pakistan, the car comes in three trim levels, 1.6l se, 1.6l ls and 1.8l cdx. Se trim comes in manual transmission only, while ls and cdx trim come in 5-speed manual or 4-speed automatic transmission.
[edit] japan
in japan, suzuki briefly distributed the lacetti as the
chevrolet optra wagon. It was available in two trim levels, the ls and the lt. Both came with either a 5-speed
manual or 4-speed
automatic transmission with a
console shift. The optra wagon was powered by a 1.6 l or 1.8 l engine.
[edit] mexico http://upload.wikimedia.org/wikipedi...olet_optra.jpg http://bits.wikimedia.org/skins-1.18...gnify-clip.png
chevrolet optra (mexico)
in
mexico, the lacetti came to the market in 2006 as optra to replace the
chevrolet cavalier, and it was sold only as a sedan. The optra was phased out after the 2009 model year in favour of the
chevrolet cruze, although for now, the mexican cruze is an imported model from
south korea. As the
united states and
canada got the lacetti for the 2004 model year, mexico got the car 2 years later, making mexico the last
north american country to get the car.
[edit] colombia
in
colombia, under the chevrolet brand, was launched in 2004 with the sedan version of the following engine:
- 1.4 l gm family 1 engine e-tec ii - 94 hp (69 kw) at 6300 rpm
- 1.8 l gm family ii engine e-tec ii - 121 hp (90 kw) at 5800 rpm
- optra 1800 cc 2007 in colombia, optra co
in 2006 it introduced the hatchback version, with the aforementioned 1.8-liter-engine-only option.
By the end of 2007, replaces the 1.4-liter engine with the following:
1.6 l gm family 1 engine e-tec ii - 109 hp (80 kw) at 5800 rpm in addition, updated the design of wheels for all models offered.
In 2008, the saloon version got a facelift, with a sportier interior and a front styling similar to the hatchback version.
Can be worth from $ 43,290,000 to $ 51,990,000 pesos.
[edit] southeast asia http://upload.wikimedia.org/wikipedi...optra_2004.jpg http://bits.wikimedia.org/skins-1.18...gnify-clip.png
2004 philippine market chevrolet optra
http://upload.wikimedia.org/wikipedi...2c_serdang.jpg http://bits.wikimedia.org/skins-1.18...gnify-clip.png
2004 malaysian chevrolet optra
in singapore, chevrolet replaced the daewoo nameplate after gm bought daewoo. It still offers the same line-up than gm daewoo, naming the optra sedan, optra station wagon and optra5 hatchback in
malaysia,
thailand, and the
philippines. In
indonesia, the sedan is simply called optra or
optra magnum for the facelift model, and
estate for the station wagon. The vehicles use the 1.6 l or 1.8 l engine with an automatic transmission available for selected models.
As of 2011,
vidamco of vietnam produces the j200 sedan as the "chevrolet lacetti" in
complete knock-down (ckd) form at its
hanoi production facility.
[3] production in hanoi began in 2004.
[4] [edit] united states suzuki marketed a rebadged lacetti as the
forenza and
reno beginning in the united states in 2004 — following the end of daewoo's
north american operations in 2002 and replacing the
daewoo nubira station wagon and
sedan. The forenza/reno falls between the
aerio (later
sx4) and the now-discontinued
verona. In the territories of
guam and
northern mariana islands, it was sold as a chevrolet optra, but it was only available as a sedan.
The us model line features the 2.0 l 4-cylinder
e-tec ii made by holden, developing a maximum power of 126 horsepower (94 kw) at 5600
rpm.
automotive news says the forenza and reno will be discontinued within the 2008 model year, and the reno has been replaced by the
suzuki sx4 sedan after the 2008 model year. The 2010
suzuki kizashi, a large
compact sedan, replaced the forenza.
[edit] iraq
the chevrolet optra entered the iraqi market in 2004 with the 1.6 engine; a few years later the ls term version was used as a traffic police patrol.
[edit] russia
it is sold as the chevrolet lacetti and includes 5-door
hatchback, sedan and station wagon models. The entire line of models are produced at the
avtotor plant in
kaliningrad with full cycle of manufacturing.
The russian models are available with the following
gasoline-powered
4-cylinder engines:
- 1.4 l — 95 hp; mt; not available for station wagon
- 1.6 l — 110 hp; at(4) and mt; for station wagon mt only
- 1.8 l — 122 hp; at(4) and mt; for station wagon mt only
