صغيرة هيونداي I10 تحصد اربع نجوم في اختبارات الأمان الأوروبية
http://www.postimage.org/aV1qAaOr.jpg
احدث سيارة هيونداي تختبر بواسطة اختبارات الأمان الأوروبية
هيونداي I10
موديل 2008
الأكثر قسوة
حصدت اربع نجوم
اللينك لمزيد من التفاصيل و الصور و الفيديو
http://www.euroncap.com/tests/Hyundai_i10_2008/323.aspx
Comments
Front impact
The passenger compartment remained stable in the impact. Protection of the driver's chest was rated as weak owing to the extent to which it was compressed during the test. Structures in the dashboard presented a risk of injury to the knees and femurs of the front seat passengers.
Side impact
A head-protecting airbag is not available for the i10 so no pole test was performed.
Child-protection
Based on the dummy response in the dynamic tests, the i10 scored maximum points for its protection of the 3 year dummy. The passenger airbag can be deactivated by means of a switch, allowing a rearward-facing child restraint to be used in that seating position. However, information provdided to the driver regarding the status of the airbag is not sufficiently clear. No clear warning is given of the dangers of using a rearward facing child seat in that seat without first disabling the airbag. The presence of ISOFIX and top-tether anchorages in the rear outboard seats was not clearly marked.
Pedestrian protection
The bumper scored maximum points for the protection it offered pedestrians' legs. However, the front edge of the bonnet offered poor protection.
