just try to buy a known brand
I only know the price of a 14 inch contnintal, its about 420/450 LE or so
رقم العضوية : 48840
السيارة: Chevorlet Lanos
السيارة[2]: Hyundai Excel
My car has completed 41000 km a week ago and here are the outcome:
Dead battery and was changed by a dry one
The four tires are in a bad condition and the front was replaced by the spare one
?The question is what are the most reasonable brands and their prices
[fot1][fot1]A life lived in fear is a half-lived life[/fot1][/fot1]
رقم العضوية : 82426
الاقامة : Maadi
السيارة: __
السيارة[2]: lanos 2007
دراجة بخارية: __
رقم العضوية : 102
السيارة: Daewoo Lanos I 1999
دراجة بخارية: N/A
stick with reputable manufacturers
check Kumho and Pirelli (P3000 not P400) also GT is a decent manufacturer
Bridgstone and Michelin are excelent but they are expensive compared to the above brands
since you are at a tire change process... consider 14" rims, it will give you better grip and handling and you will be ready for brakes upgrade if you got that in future plans
رقم العضوية : 48840
Good idea so concerning the 14'' rims,do you recommend brand new ones or used?and how about the size of the tires?would they remain the same size or should I buy bigger ones?
رقم العضوية : 82426
الاقامة : Maadi
السيارة: __
دراجة بخارية: __
the new ones is better for sure, but you can buy a used nubira rims
....l or aloy it wont make a big diff
tiers will be 14/60/185
رقم العضوية : 102
دراجة بخارية: N/A
it depends on your budget
you can buy a set of Nubira OEM ....l rims for 300LE or so and buy the tires... you will get the benefits of the tires without the extra cost of the alloy rims which you can buy later on
if you can spare some 1400LE for the rims then go ahead... but whatever you buy don't get chinese rims... those are not that strong... go for rims made in Taiwan or Thiland... one of the famous new brands is SSW (Stamford Sports Wheels)... those are nice looking, well built and not very expensive
as for tire size, the correct tire size for the lanos with 14" rims is 185/60/14... Kumho Ecsta MX and GT champiro 60 tires is recommended
