النتائج 1 إلى 10 من 16
    الصورة الرمزية Nistelrooy
    رقم العضوية : 8617
    الاقامة : El-Haram
    السيارة: ........
    السيارة[2]: Gen 2 A/T 2010
    دراجة بخارية: yareet
    الحالة : Nistelrooy غير متواجد حالياً
    افتراضي معلومات عن اللانوس - Facebook Twitter whatsapp انشر الموضوع فى :
    Chevrolet Lanos
    Simplicity can be too smart, so Chevrolet introduced a new model Chevrolet Lanos, a simple and elegant solution for those who need a reliable car, no-nonsense, with a convenient and functional. This is a vehicle in which there are most needed and no feel. You will need only fill in time to fill a petrol tank and pumping water washing, as well as a maintenance service. Yes, and even a good idea-at least once every few months to check the tire pressure.
    Chevrolet Lanos
    Chevrolet Lanos created to bring you joy. Design, which does not enjoy sight. Running qualities that feed you in traction for active driving. The extensive range of standard equipment, which creates comfort, and comfort are all Chevrolet Lanos. Whatever version of the Chevrolet Lanos you may choose, your choice will be extremely reasonable.
    Chevrolet Lanos
    Chevrolet Lanos is one of the most inexpensive gasoline represented on the Russian car market. In the car Chevrolet Lanos installed engine volume 1.5 liters (86 hp) and only mechanical gearbox. In basic equipment is not included roof rudder, but there is a driving airbag. For additional value can be obtained servo power steering, air conditioning, central locking, power, radio and fog lamps.
    Chevrolet Lanos Interior
    Chevrolet Lanos
    In the saloon car Chevrolet Lanos compact and the driver will feel comfortable. Volume the luggage compartment is 322 liters., and the rear seats up the Chevrolet Lanos in the proportion 60:40, thereby can be increased to 958 liters trunk. Will this car Chevrolet Lanos at the Zaporozhye automobile (ZAZ) under license Korean GM Daewoo. Producer provides warranty for the car Chevrolet Lanos 2 years, with no mileage limitation.
    Chevrolet Lanos Engine
    This sedan S-class with mechanical gearbox 1,5-liter engine capacity of 86 HP, driver's airbag, and heating rear window distinguishes high reliability and advanced passive safety system: reinforced front and rear racks the body connected to the roof of the four strong bridles, security beams of steel pipes, which are placed in the front and rear doors and under frontal glass with a rigid body construction of the passenger cell.
    Chevrolet Lanos Basic equipment:
    . Body: 4-dr notch
    . Displacement: 1.5 / 86 hp
    . Box change Transmission: MT
    . Radio training
    . Bumpers colored body
    . Indicator driver's seat belt
    . Audio training
    . The console between the front seats for rear unit with passengers
    . Sun visors (with a mirror from the driver)
    . Front ashtrays
    . Rear glass
    . Rear mud-guards
    . Folding rear-view mirrors in black
    . Wheel drives in black
    . Full spare tire
    . The protective caps for wheels
    . Remote control lock luggage
    . Folding rear seat in the proportion 60/40
    . Acoustic system with 4 speaker
    . Steel drives 14
    . Driver Airbag
    . Power stearing
    المصدر
    http://chevrolet-review.blogspot.com...let-lanos.html
    اية رايكم يا جماعة ؟!
    الصورة الرمزية MMamdouh
    رقم العضوية : 102
    السيارة: Daewoo Lanos I 1999
    دراجة بخارية: N/A
    nice
    الصورة الرمزية ahmedsrs
    رقم العضوية : 2401
    الاقامة : الكوكب الازرق
    السيارة[2]: كيا بيكانتو 2011
    الحالة : ahmedsrs غير متواجد حالياً
    تسلم الأيادى على الموضوع
    http://imageshack.us/photo/my-images/545/6c6d1551112s.gif/
    الصورة الرمزية BomBom
    رقم العضوية : 8412
    الاقامة : Egypt - GIZA
    السيارة: Waiting For
    السيارة[2]: Daewoo - Lanos
    الحالة : BomBom غير متواجد حالياً
    بالرغم من عدم وضوح الجزء الخلفي من العربية ، بس انا متهيألي ان الفوانيس الخلفية شكلها مختلف شوية .. صحيح ؟
    الصورة الرمزية someone
    رقم العضوية : 4846
    السيارة: dawood
    السيارة[2]: fiat
    الحالة : someone غير متواجد حالياً
    بس معلشى انا عايز افهم ايه علاقه شيفورليه بدايو يا جماعه
    رقم العضوية : 8617
    الاقامة : El-Haram
    السيارة: ........
    thnx for all
    MMamdouh can explain Qu.N
    رقم العضوية : 102
    دراجة بخارية: N/A
    اقتباس المشاركة الأصلية كتبت بواسطة someone مشاهدة المشاركة
    دايو و شيفرولية و سوزوكى تابعين لجنرال موتورز و بالتالى عادى انك تلاقى العربية نازلة بكذا اسم زى كدة الشفرولية الاوبترا... حتلاقيها دايو نوبيرا و سوزوكى فورينزا
    الصورة الرمزية Defender
    رقم العضوية : 7939
    الاقامة : في الصحراء
    السيارة: Horse :D
    السيارة[2]: Camel
    الحالة : Defender غير متواجد حالياً
    خامات رديئه
    رجاي النظر للموضوع الاتي
    Nothing is better
    Than
    The wind to your back,
    The sun in front of you,
    .And your friends beside you
    رقم العضوية : 7939
    السيارة: Horse :D
    السيارة[2]: Camel
    Nothing is better
    Than
    الصورة الرمزية nanse
    رقم العضوية : 33193
    الحالة : nanse غير متواجد حالياً
    شكررررررررررررررررررررااا علي الموضوع الجميل دة
  1. معلومات Wii
    بواسطة asd7778 في المنتدى المنتــــــدى الاجتمــاعى
    آخر مشاركة: 05-05-2010, 02:02 AM
  2. مشاركات: 5
    آخر مشاركة: 10-11-2008, 10:25 AM
  3. معلومات عن فوجات اللانوس ارجو الافادة؟
    بواسطة adidas_vip2 في المنتدى دايــو+شيفرولية لانوس
    مشاركات: 10
    آخر مشاركة: 09-06-2008, 12:52 PM
  4. هل اللانوس الهاتشباك افضل من اللانوس السيدان؟
    بواسطة BomBom في المنتدى دايــو+شيفرولية لانوس
    مشاركات: 27
    آخر مشاركة: 28-04-2008, 02:43 PM
  5. معلومات
    بواسطة درش في المنتدى القــــسم التعلــــيمى
    آخر مشاركة: 08-01-2008, 10:18 AM
