جرب تعمل idle learn للريموت
Learning Code Steps:
press the foot brake pad.
turn the car key from OFF to ON repeatedly for 8 times within 10 seconds.
stop to ON position, the flash lights would be on for a long time and entering into code learning mode.
press any button on the transmitter, the siren would chirp once, the flash lights would be off.
code learning finished.
press any button on the other transmitter, code learning again.
this way can finish max.4 remote transmitters.
Note:
When entering into new code learning, clear all the codes learned, therefore old and new remotes have to learn the code at the same time
