النتائج 1 إلى 10 من 12
    الصورة الرمزية aymanshebl
    رقم العضوية : 47609
    السيارة: no
    السيارة[2]: no
    الحالة : aymanshebl غير متواجد حالياً
    افتراضي سالت موقع ليكوى مولى عن السيراتك و هذه الاجابة؟ - Facebook Twitter whatsapp انشر الموضوع فى :
    Dear Mr. Shebl,
    thank you very much for contacting us and your interest in our LIQUI MOLY
    products.
    The difference between LIQUI MOLY CERA TEC and LIQUI MOLY MOTORPROTECT is
    the composition of this products.
    LIQUI MOLY MOTORPROTECT .......s a chemical component that hardens the
    surfaces inside the engine under heat and pressure. So you can reduce wear
    inside the engine.
    LIQUI MOLY CERA TEC .......s also this chemical component and further a
    solid lubricant that reduces friction very good. With CERA TEC you have a
    ideal combination of these two active substances and we recommend you to
    use this product in your new car.
    Please see the attachement for more product informations :
    (See attached file: 3721 Cera Tec_EN.pdf)
    We hope we could help you with our informations. Should you have further
    questions regarding our products we would be very pleased to get contacted
    from you again.
    Best Regards
    i. A.
    Steffen Niemietz
    Anwendungstechniker
    application engineer
    Phone: +49 (0)731 / 14 20 - 658
    Mobile: +49 (0)162 / 2 81 50 64
    Fax: +49 (0)731 / 14 20 - 44658
    LIQUI MOLY GMBH
    F & E / Anwendungstechnik
    Jerg-Wieland-Straße 4
    D-89081 Ulm
    www.liqui-moly.de
    Amtsgericht Ulm HRB 1383 | Geschäftsführer: Ernst Prost
    Court of registration Ulm, HRB 1383 | Managing Director: Ernst Prost
    LIQUI MOLY ist Deutschlands beliebteste Motorenöl-Marke !
    LIQUI MOLY is Germanys most popular motor-oil-brand !
    Daten des Besuchers (englische Liqui Moly Webseite):
    Firma:
    Vorname: shebl
    Strasse:
    PLZ / Ort:
    Land: egypt
    Fax:
    Nachricht:
    i have a new car model 2011 elantra , and i ask which product to use to
    protect my motor against wear and friction, cera tec or motorprotect, both
    are nearly the same , but i want the best one, and more powerful one.
    thanks in advance
    الصورة الرمزية Ayman-Ahmed
    رقم العضوية : 62792
    الاقامة : Almaza/Nasr City
    السيارة: الحمد لله
    السيارة[2]: New Accent
    دراجة بخارية: None
    الحالة : Ayman-Ahmed غير متواجد حالياً
    كلام جميل وطبعا السيراتك هيكون افضل لانه بيقوم بوظيفتين والاتنين مهمين(لو محتاجهم لموتورك).
    [marq="3;right;3;scroll"]لا حول ولا قوة الا بالله العلى العظيم
    [/marq]
    الصورة الرمزية Elawany13
    رقم العضوية : 82537
    الاقامة : Egypt
    السيارة: الحمد لله رضااااااااا
    السيارة[2]: شاهين 2004
    دراجة بخارية: موتوسيكل صينى
    الحالة : Elawany13 غير متواجد حالياً
    انجليزى ده يامرسى
    طب متكمل جميلك وتنزل الترجمة علشان اللى اتعلموا فى المدارس الحكومية يفهموا
    نهارنا عسل ... الفنكوش وصل ولا لسه ؟؟؟
    قصدى السيراتيك وصل ولا لسه ؟؟
    رقم العضوية : 62792
    السيارة: الحمد لله
    دراجة بخارية: None
    ملخص الموضوع فى النقطتين دول يا علوانى.
    inside the engine
    فيه نوعين لنظام حماية الموتور والعضو بما انع معاه عربية موديل 2011 فكان بيسال عن افضل المنتجات لحماية الموتور وتقليل الاحتكاك وزيادة عمر الموتور.
    1- حماية الموتور (العادى) : وده مكون من مادة ما بتحمى الموتور وتقوى السطح الداخلى للموتور مع الضغط والحرارة وده لزيادة عمر الموتور داخليا.
    2- حمايه الموتور (بمادة السيراتك) : وبيستخدم المادة الاولى نفسها ويزيد عليها مادة ملينة قوية تساعد على تقليل الاحتكاك الداخلى ونصحوه باستخدام السيراتيك وخصوصا ان العربية جديدة.
    [/marq]
    رقم العضوية : 47609
    السيارة: no
    السيارة[2]: no
    اقتباس المشاركة الأصلية كتبت بواسطة Elawany13 مشاهدة المشاركة
    انجليزى ده يامرسى
    هههههههه
    الحقيقة انا كان سوالى ليهم انى انا معايا عربية النترا 2011 جديدة و بسال على انهى منتج بيحافظ على الموتور من الاحتكاك و التاكل هل هو السيراتك وb موتوربروتكت لان الاثنين تقريبا نفس الشى فانا عاوز احسن واحد فيهم و شكرا
    و الاجابة من موقع ليكوى كولى كما dلى:
    بعد الشكر بخصوص الاتصال بهم و الاهتمام بمنتجات ليكوى مولى
    ان الموتوربروتكت فيه مكونات كيميائية بتحمى المحرك من الحرارة و الضغط و بالتالى تقلل من التاكل
    اما السيراتك ففيه هذه التركيبة بالاضافة الى مزيت عالى الكفائة يقلل من الاحتكاك و لذلك سيراتك فيه المزيج من الاضافتين و يوصى بيه فى سيارتى الجديدة و هذا ملخص الرسالة و شكرا
    الصورة الرمزية Sir_Mohd_Sabra
    رقم العضوية : 122031
    الاقامة : New Cairo - El tagmo3 el awel
    السيارة: Nissan Tida ISA
    السيارة[2]: KIA Picanto
    الحالة : Sir_Mohd_Sabra غير متواجد حالياً
    ايوه ياجماعه بس السيراتك سعره مبااااااااالغ فيه بطريقه غير طبيعيه 135 جنيه فى حين ان فيه منتجات امريكى برده تعمل كمعالج للزيت مثل السيراتك بالظبط وتكون نفس الطبقات وسعرها اقل النصف تقريبا بتدبدا من 30 الى 70 جنيه اخرها
    انا هغير زيت الايام دى وهجيب معالج الزيت الامريكى ده وهحط برده ليكوى مول 5ًw/40 هاى تك والمياكنيكى قالى انه الامريكى مجرب وممتاز جدااا جدااا
    رقم العضوية : 47609
    السيارة: no
    السيارة[2]: no
    اقتباس المشاركة الأصلية كتبت بواسطة ayman-ahmed مشاهدة المشاركة
    Liqui moly motorprotect .......s a chemical component that hardens the
    inside the engine
    liqui moly cera tec .......s also this chemical component and further a
    solid lubricant that reduces friction very good. With cera tec you have a
    انا لسه كاتب الرد حالا و حضرتك سبقتنى دايما سباق بالخير
    الصورة الرمزية fepsceasar
    رقم العضوية : 32627
    السيارة: اكسارا
    السيارة[2]: فيات 128
    دراجة بخارية: i hope
    الحالة : fepsceasar غير متواجد حالياً
    السيراتك انت بتحطه مع الزيت الجديد عادى وتسيبه لغاية ما تغير تانى
    ولا مع الزيت القديم كانه بيغسل الموتور
    يقول اللورد كرومر فى مذكراته: لم اجد فى مصر الا المصريين فقط.. بعضهم يصلى فى المسجد وبعضهم يصلى فى الكنيسة لكن كلهم مصريون.
    أبو كمال
    رقم العضوية : 82537
    الاقامة : Egypt
    هههههههه
    متشكرين يارجالة على الترجمة
    بس هوه فين الفنكوش ؟؟؟
    مستنينه بقالنا شهوووووووور !!!!!
    وايه هوه المنتج البديل الأمريكى ؟
    رقم العضوية : 62792
    السيارة: الحمد لله
    دراجة بخارية: None
    اقتباس المشاركة الأصلية كتبت بواسطة aymanshebl مشاهدة المشاركة
    الله يكرمك.وبالتوفيق بامر الله.
    [/marq]
  1. ليكوى مولى
    بواسطة MEKAWY2000 في المنتدى لادا
    مشاركات: 6
    آخر مشاركة: 14-11-2012, 11:32 PM
  2. تجربتى مع ليكوى مولى
    بواسطة DrMuHaMmAd في المنتدى المنتــــــدى العـــــــــــام للسيــارات
    مشاركات: 7
    آخر مشاركة: 08-09-2012, 04:29 PM
  3. زيت ليكوى مولى
    بواسطة Dr/ P.K.Sh في المنتدى شــيفـرولــيه
    آخر مشاركة: 12-03-2012, 11:36 PM
  4. أتصال من ليكوى مولى (شكرآ ليكوى مولى)
    بواسطة night_whisper في المنتدى نيـــــــــسان
    مشاركات: 21
    آخر مشاركة: 27-12-2011, 09:33 PM
  5. زيت ليكوى مولى
    بواسطة ghareeb في المنتدى بــروتـــون
    آخر مشاركة: 24-11-2011, 05:14 PM
