Note that it only works for old MCS because the new one's are turbocharged
رقم العضوية : 1303
السيارة: Hyunai i10
السيارة[2]: BMW 325i E46
While MINI may have given Cooper "S" owners a literal boost over standard Coopers there is no reason to be comfortable with 163HP. One of the best ways to turn up the power is to turn up the boost.
Our 15% and 19% reduction supercharger pulleys do just that. ALTA Performance pioneered the use of taper fit pulleys on the MINI Cooper. Now the most widely used design in the industry, ALTA continues to manufacture the most popular pulley for the MINI Cooper S. With the simple installation of this pulley and no other modifications will raise boost 3-4 lbs. (NOTE: Some fluctuation in boost is normal and the actual gain will vary based on other factors including exhaust, intake etc.)
This rise in boost pressure will increase HP 12-20! No other modifications to ECU etc., required. Customers with other existing modifications or those seeking more HP the results can be even better with the addition of ECU, intake, intercooler and exhaust! Brand new for 1500LE
Horsepower is how fast you hit the wall....torque is how far you take the wall with you
رقم العضوية : 3971
الاقامة : Giza-Egypt
السيارة: 4G93T
السيارة[2]: Mitsubishi Lancer GSR CK1A
دراجة بخارية: n/a
VTEC: All of the lag...none of the BOOST l
رقم العضوية : 1303
السيارة: Hyunai i10
رقم العضوية : 1303
السيارة: Hyunai i10
upppppppppppppppppppppppppppppppppppppppppp
رقم العضوية : 1303
السيارة: Hyunai i10
Left only 2 and new very good sale price just 800
رقم العضوية : 1303
السيارة: Hyunai i10
رقم العضوية : 1303
السيارة: Hyunai i10
Both sold. Subject closed
