محتاج اعدل طقم الصوت عندى وعاوز خبرتك
كنت حابب استشيركم بالنسبة لنظام الصوت عندى
العربية بولو 99 والحمد لله تمام
انا منزل فيها كاسيت pioneer 5250 ومركب سماعتين 300 وات بايونير
[aldl]http://www.xxxcaraudio.co.za/data/products/PIONEER%205250SD%20BIG.jpg[/aldl]
الصوت كل الى يسمعه يفتكر ان العدة كاملة ومركب جى ام وكدا :)
طبعا هما بس السماعتين :)
انا دلوقتى عاوز اركب الكاسيت صح
بمعنى ان الكاسيت فيه 6 مخارج للسماعات
2 - rare speaker
2- front speaker
2 - subwoofr
[aldl]http://img408.imageshack.us/img408/3269/95901421.jpg[/aldl]
وفيه تحكم من الكاسيت نفسه للصب واوبشنات كتير زى الـ Retrive
وده اوبشن الكاسيت
• Your iPod, iPhone via optional CD-IU50 cable
• Your USB device via a front USB input
• Other music devices via a front auxiliary input
Front Panel Removeable
Display Illumination Blue OEL (showing 3 lines with 160x48 dots)
Button Illumination Blue
Rotary Commander (-) Yes
You can control all functions with the Rotary Commander single dial.
The Rotary Commander works like a joystick, giving you speedy control over the receiver.
Turn it left or right , push it up or down, left or right, or press it to navigate joystick-style throughout different radio stations, access folders and files.
Remote Control Optional CD-R320 remote control available
Multi-Language Display Yes (English, French, German, Italian, Spanish, Dutch and Russian)
Cellular telephone auto muting (-) Yes
This feature automatically reduces the volume of your system when an incoming call is detected or you dial an outgoing call on a cellular phone installed in your car.
Advanced Sound Retriever (-) Yes
ASR stands for Advanced Sound Retriever.
Our ASR sound technology automatically restores the harmonics which were lost during the audio compression process.
ASR adjusts frequency response and sound pressure, especially in the high and low frequency ranges, to revitalise the density and presence of the compressed signal.
The result is an improved sound quality with its staging, density and feeling restored to the level of the original recording.
ASL (Automatic Sound Leveliser) (-) Yes
Compensating for additional outside noise, the automatic sound leveliser uses signal processing to automatically and electronically adjust the internal volume so that your music always sounds right.
Balance Yes
D/A Converter Digital-direct signal transmission
Fader Yes
Graphic Equaliser 5-band with 7 pre-set EQ curves
High Pass Filter (-) Yes
When the subwoofer is connected and you do not want low sound to play from the front or rear speakers, turn the high pass filter on. Only fre-quencies higher than those in the selected range will be output from the front or rear speakers.
Low Pass Filter Yes
Loudness (-) Yes
At low volume levels, low and high frequency sounds in music can be overpowered by ambient noise levels in the vehicle. Loudness control provides a one-button way to boost these frequencies and provide better overall sound at low volume levels.
Source Level Adjuster (SLA) (-) Yes
Source Level Adjuster (SLA):Allows you to independently adjust the volume ratio between all of the headunit's sources (using the FM volume level as a reference), so the start-up volume between sources will always be the same.
استفسارى من حضراتكم اعمل ايه علشان اظبط الكلام ده
اركب سماعات ايه ؟ هل ازود 2 سماعات ابواب ؟ هل اركب 2 صب ؟ هل اركب 2 سماعات امامية و2 خلفية بايونير ؟ هل محتاج GM ؟
مش عارف بصراحة
ارجو الى يفيدنى يكون عن تجربة ويقولى افضل المتاح وانسب سعر
ويكون مثلا لو هيرشح لى سيستم يوفق مثلا قدرة الجى ام مع الصب او قدرة الجى ام مع البازوكا وكدا
واركب فين بردوا يكون اسعاره كويسة ويركب صح يكون متخصص
مع الشكر مقدما لكل الاخوة الكرام .
