النتائج 1 إلى 10 من 10
الموضوع: Tires Safety & Maintenance
    الصورة الرمزية superhano
    رقم العضوية : 29806
    الاقامة : Cairo - Nasr City
    السيارة: NA
    السيارة[2]: Nissan Sunny 2011 EX Salon
    دراجة بخارية: NA
    الحالة : superhano غير متواجد حالياً
    افتراضي Tires Safety & Maintenance - Facebook Twitter whatsapp انشر الموضوع فى :
    Considering how important tyres are for a smooth and safe drive, it is surprising just how quick and it is easy to care for your tyres. By following our tyre care tips, and conducting simple regular checks, you will not just save time and money, but more importantly, stay safe on the road
    Do A Daily Visual Check
    1. Check that all tyres have about the same inflation pressure.
    2. Check the sidewalls for cracks or unusual bulges.
    3. Check for and remove any foreign objects (e.g. stones or nails) that could puncture you tyre.
    Do A Monthly Tyre Pressure Check
    1. Use a proper tyre guage to measure tyre pressure.
    2. Check pressure and inflate only when the tyres are cold. (a hot tyre will show inaccurate reading due to inflation)
    3. It takes as long as 4 hours for a tyre to cool down so it's best to check tyre pressure first thing in the morning.
    4. Your vehicle tyre pressure chart can usually be found on the driver's door frame or in your owner’s handbook.
    5. Don't forget to also inflate your spare tyre.
    Check for Irregular Wear
    This is when one section of the tyre is more worn than the rest and occurs when:
    1. Tyres are not uniformly inflated.
    2. Tyres are not balanced.
    3. Wheels are out of alignment.
    Rotate Tyres Every 5,000km
    1. Visit a reputable tyre shop or garage for tyre rotation.
    2. Check your owner's handbook for rotating sequence.
    3. Have your tyres balanced at the same time.
    Check the Tread Depth Indicator
    1. All tyres come with a tread depth indicator. (see diagram)
    2. When the indicator is flushed with the rest of the tread (usually about 1.6mm), it is time to change the tyre.
    Check the Wheel Alignment
    1. Misaligned wheels cause tyres to wear more quickly and irregularly, and prevents the vehicle from running or braking in a straight line. The suspension and steering components will also be subjected to extra stress.
    2. 2. It is a good idea to have your wheels aligned by a computerised alignment machine. A reputable workshop should have the wheel alignment specifications of your vehicle model.
    -=superhano=-
    ARRIVE ALIVE
    mem
    الصورة الرمزية mem
    رقم العضوية : 41774
    الاقامة : egypt
    السيارة: nassin
    السيارة[2]: opel
    الحالة : mem غير متواجد حالياً
    شكرا على النصائح الهامه اخى العزيز وعلى التذكره باهمية الاطارات
    وفعلا الاطارات من العوامل المهمة فى السياره
    وكثيير منا يهملها ولا يعتنى بها بانتظام مع العلم ان معظم الحوادث تكون بسبب انفجار الاطار المفاجى
    او عدم تماسكة بالارض جيدا عند الفرامل المفاجئة
    فيجب المتابعة الدورية للاطاات حتى يتثنى اخذ التدابيراللازمة عند وجود اى خلل او شى غير طبيعى بالاطار
    الصورة الرمزية Sehsss
    رقم العضوية : 108530
    السيارة: NON
    السيارة[2]: نيسان صني
    الحالة : Sehsss غير متواجد حالياً
    شكرا على المعلومات
    الصورة الرمزية Dr'AhmZZong
    رقم العضوية : 72112
    الاقامة : الجيزة ... المنوفية
    السيارة: Duster E2-Terios
    السيارة[2]: Nissan Sunny-Tiida
    دراجة بخارية: هوندا اليت
    الحالة : Dr'AhmZZong غير متواجد حالياً
    ربنا يجزيك خيييييييييييير ..
    الصورة الرمزية S O P H O S
    رقم العضوية : 71514
    الاقامة : EgYpT-ⵍⵎⵖⵔⵉⴱ-
    السيارة: -- -- all FiaT ---
    دراجة بخارية: - - - - - - -
    الحالة : S O P H O S غير متواجد حالياً
    مشكورررررررررررررررر ....
    الصورة الرمزية _hema
    رقم العضوية : 80280
    الاقامة : Maadi
    السيارة: ربنا يبعت :D
    السيارة[2]: Nissan Sunny Super Salon H.L
    الحالة : _hema غير متواجد حالياً
    اخى الكريم
    السلام عليكم ورحمه الله تعالى وبركاته
    حضرتك ذكرت ان الكاوتش لابد ان يترك 4 ساعات عشان الفرده تبرد واللى شغال فى الكاوتش قال يكفى نصف ساعه او ساعه
    نصدق المعلومه ولا بتاع الكاوتش اللى ايديه فى الشغل
    وكما ذكرت حضرتك فى المعلومه ايضاً ان يتم تدوير ( استبدال ) الاطارات كل 5000 كلم والتوكيل وبتاع الكاوتش قالوا كل 10000 كم
    برضوا نصدق مين
    طبعاً وردت معلومات بالموضوع جايز يجانبها الصواب او الخطا ولكن احببت ان اركز على شيئين مهمين سمعت عنهم فقط وسألت
    فيهم للتأكد منهم وهو ماأشرت اليه بعاليه
    واسمح لى بتعليق ارجو ان يتسع صدرك له
    لوا كان هذا منقولاً فما الداعى ان تنقله لنا
    بالانجليزيه
    هل حضرتك بتفترض ان لغتنا الاساسيه هى الانجليزى ام كلنا نجيد الانجليزيه
    ولو حضرتك كتبتبه بيديك فقد بذلت مجهودا فوق العاده
    ولكن بعد هذا المجهود كم سيقراء ماكتبت
    فالهدف من المعلومه هو سهوله وصولها للمتلقى وليس زياده عنائه فى الحصول عليها حتى يستوعبها
    اشكر حضرتك على سعه صدرك
    تقبل منى كل تحيه واحترام
    لك كل الود
    الصورة الرمزية Ahmed.TV
    رقم العضوية : 18439
    الاقامة : حدائق الاهرام
    السيارة: بولو 99
    السيارة[2]: تيدا 2009
    دراجة بخارية: honda
    الحالة : Ahmed.TV غير متواجد حالياً
    تسلم ايدك على الموضوع المفيد ده
    بس الشعب يريد الترجمة
    وجزاك الله خيرا على الافادة
    محرر فى دعم اتخاذ القرار بوزارة الاعلام
    قليل المشاركة فى الموضوعات والرسائل الخاصة لانشغالى بالعمل
    برجاء الاتصال بى : 01288814049
    الصورة الرمزية Bishoy.Girgis
    رقم العضوية : 30571
    الاقامة : EGYPT
    السيارة: Toyota Corolla 1996
    السيارة[2]: Nissan Sunny 2OO9
    دراجة بخارية: I Don't Like It
    الحالة : Bishoy.Girgis غير متواجد حالياً
    دي ترجمة جوجل :
    النظر في مدى أهمية الإطارات هي لمحرك سلس وآمن، ومن المدهش كيف فقط سريع وأنه من السهل لرعاية الاطارات الخاصة بك. وذلك باتباع النصائح رعاية الإطارات، وإجراء عمليات الفحص المنتظمة بسيط، فلن حفظ الوقت والمال فقط، ولكن الأهم من ذلك، البقاء آمنة على الطريق
    القيام فحص اليومي المرئي
    تأكد من أن جميع الإطارات لديها عن ضغوط التضخم نفسه.
    التحقق من الجوانب عن شقوق او انتفاخات غير عادي.
    التحقق من وجود وإزالة أي أجسام غريبة (مثل الحجارة أو الأظافر) والتي قد ثقب الاطارات لك.
    فعل ضغط صور شهري تحقق
    استخدام guage الاطارات المناسبة لقياس ضغط الهواء في الإطارات.
    فحص ضغط وتضخيم فقط عندما تكون الإطارات باردة.
    (أ الإطارات الساخنة سوف تظهر قراءة غير دقيقة بسبب التضخم)
    فإنه يأخذ ما دام 4 ساعات للإطارات ليبرد لذلك فمن الأفضل للتحقق من الاطارات شيء الضغط الأول في الفترة الصباحية.
    ويمكن عادة لديك ضغط الهواء في الإطارات مخطط مركبة يمكن العثور عليها في إطار باب السائق أو في كتيب المالك الخاص بك.
    ولا ننسى أيضا لتضخيم الاطارات فراغك.
    التحقق من وجود ملابس غير النظامية
    هذا هو عندما مقطع واحد من الإطارات البالية أكثر من بقية ويحدث في الحالات التالية:
    لا إطارات تضخم بشكل موحد.
    إطارات ليست متوازنة.
    العجلات هي خارج المحاذاة.
    تدوير الاطارات كل 5000 كلم
    زيارة متجر الاطارات والسمعة أو مرآب للدوران الاطارات.
    مراجعة كتيب المالك لتسلسل الدورية.
    وقد الاطارات الخاصة بك متوازنة في الوقت نفسه.
    تحقق من المؤشر العمق قاعدة العجلة
    جميع الإطارات تأتي مع فقي مؤشر عمق.
    (انظر الرسم البياني)
    عندما يتم مسح مؤشر مع بقية فقي (عادة حوالي 1.6mm)، فقد حان الوقت لتغيير الاطارات.
    تحقق موازنة العجلات
    عجلات المنحرفة تسبب الإطارات على ارتداء بسرعة أكبر وبشكل غير منتظم، ويمنع السيارة من تشغيل أو الكبح في خط مستقيم.
    وسيتم أيضا مكونات التعليق والتوجيه يتعرض لضغوط اضافية.
    2. انها فكرة جيدة ان يكون لديك محاذاة العجلات بواسطة آلة المحاذاة المحوسبة. وينبغي أن يكون حسن السمعة ورشة عمل لديها مواصفات موازنة العجلات من طراز سيارتك.
    السيارة: NON
    اقتباس المشاركة الأصلية كتبت بواسطة peaceman مشاهدة المشاركة
    دي ترجمة جوجل :
    تحقق موازنة العجلات
    الله عليك يا بيشو، طول عمرك جاهز
    الصورة الرمزية FBIAhmed
    رقم العضوية : 43360
    الاقامة : egypt cairo
    السيارة: nissan sunny manual 2011
    السيارة[2]: skoda felicia 1997
    الحالة : FBIAhmed غير متواجد حالياً
    Thanks Very Much Hoping For More About Wheel Alignment And Car Balance
  1. Do It Yourself Car Maintenance Videos
    بواسطة Mohamed_Rashad في المنتدى القــــسم التعلــــيمى
    آخر مشاركة: 27-12-2009, 04:49 PM
  2. VW receives Top Safety Pick Awards from the Insurance Institute for Highway Safety
    بواسطة hanady في المنتدى فــــولكـــس
    آخر مشاركة: 30-11-2009, 02:46 PM
  3. 5000 Km maintenance
    بواسطة eng_mido في المنتدى بــروتـــون
    مشاركات: 10
    آخر مشاركة: 16-04-2009, 08:44 PM
  4. mazda 3 maintenance
    بواسطة devil في المنتدى مــــــازدا
    آخر مشاركة: 17-02-2009, 03:51 AM
  5. 1000 km maintenance
    آخر مشاركة: 31-12-2008, 01:21 PM
