شكرا جزيلا
رقم العضوية : 4703
الاقامة : alex
السيارة: none
السيارة[2]: lada samara 1990
دراجة بخارية: none
الحل في تغيير رقم ال dns الخاص بيك
ودي الطريقه لويندوز 7
ودي للناس اللي بيستعملوا ويندوز xp1. Open the Control Panel.
2. Open up Network and Internet and go to the Network and Sharing Center.3. Click on Change adapter settings on the left hand panel.4. This will bring up a list of adapters present on your computer. Most people will have a Local Area Connection while laptop users will add a Wireless Network Connection and possibly a Bluetooth Network Connection...go ahead and right click on Local Area Connection and click on Properties.
NOTE: These steps do not change if you are modifying the Wireless Network Connection instead 5. If prompted by UAC, click on Yes.
6. Highlight Internet Protocol Version 4 (TCP/IPv4) and click on properties.7. In the properties window you will see a few radio boxes with both of them saying Obtain an IP/DNS Address Automatically....we will leave the IP address alone and will change the Obtain DNS....to use the following:In the Preferred DNS server boxes enter this sequence: 208.67.222.2228. Check the validate settings upon exit (Optional) check box, click OK, and then Close to finish. (See screenshot above)
In the Alternate DNS server boxes enter this sequence: 208.67.220.220
9. Windows will check your settings (if you checked the option above) and you will be finished! Now start surfing to feel the effects of a quicker and more secure browsing experience!
Go to Control Panel>Network Connections and select your local network.Click Properties, then select Internet Protocol (TCP/IP).Click Properties. You will see a window like the one below - this is the Internet Protocol window. Select "Use the following DNS server addresses" and enter the desired DNS server(s) in the space(s) provided.
انا نقلت الخطوات بدل ما اقعد اخد سكرين شوت اولا
وثانيا لاني شغال اكس بي
حنحط الدي ان اس الجديد
8.8.8.8
8.8.4.4
عملت الموضوع في المنتدي العام علشان يظهر في شريط المواضيع
واللي يعرف حد عنده مشكله في دخول المنتدي يقوله علي طريقه الحل
لا تحزن إذا فاتك قطار الزواج، فلأن يفوتك القطار خير من أن يدهسك..
رقم العضوية : 108530
السيارة: NON
السيارة[2]: نيسان صني
شكرا جزيلا
رقم العضوية : 45939
الاقامة : الباجور/ منوفيه
السيارة: لانسر كرستاله
السيارة[2]: بيجو 504 +شاهين
دراجة بخارية: نعم صينى
طب ده للى مش بيفتح عنده
طب والى بيفتح عنده
اقوى واغلى 10 اسلحه بالعالم
http://technology-mmm.blogspot.com/
http://imageshack.com/a/img850/6764/4fdl.jpg
رقم العضوية : 82537
الاقامة : Egypt
السيارة: الحمد لله رضااااااااا
السيارة[2]: شاهين 2004
دراجة بخارية: موتوسيكل صينى
انا حاطط دى ان اس جوجل اللى حضرتك ذكرته ورغم ذلك المنتدى بيقفل معايا كل فترة وبيحصل مشاكل
الحل حذف الكوكيز
هتلاقيه اشتغل فى ثانية
رقم العضوية : 80280
الاقامة : Maadi
السيارة: ربنا يبعت :D
السيارة[2]: Nissan Sunny Super Salon H.L
رقم العضوية : 35815
النوع : انثى
الاقامة : Haram _ Giza
السيارة: KIA Rio Auto 2011
السيارة[2]: كانت هيونداي I10
شكرا يا شنوري
"لا إله إلا انت سبحانك إني كنت من الظالمين"
رقم العضوية : 79261
الاقامة : kSA
السيارة: No cars
السيارة[2]: No cars
دراجة بخارية: ................
الف الف شكر يا فندم
رقم العضوية : 111654
السيارة: lanos
السيارة[2]: Ford focus
المشكله ان اللى ميفتحش معاهم مش حيقرا موضوعك :)
م/محمد الكردى.
رقم العضوية : 7360
الاقامة : EGYPT - TANTA
السيارة: LOGAN 2011
السيارة[2]: nothing now
رقم العضوية : 4703
الاقامة : alex
السيارة: none
دراجة بخارية: none
