اهداء والموضوع موضوعك طبعاً
عبد الرحمن الحاكم
شايف انك مولع جداً وانا معاك الصراحه ب اوف روود
خد عندك
2012 KTM 250SX-Fhttp://www.mediafire.com/convkey/9a1...vhh4f8ma5g.jpg
http://www.mediafire.com/convkey/744...7wjn3kvy5g.jpg
http://www.mediafire.com/convkey/3f6...anxbh3e05g.jpg
http://www.mediafire.com/convkey/063...k89dngvf5g.jpg
http://www.mediafire.com/convkey/9d8...89ar3c2u5g.jpg
Engine
Engine type Single cylinder, 4-stroke
Displacement 248.6 cc
Bore/stroke 76/54.8 mm
Compression ratio 13.2:1
Starter/battery Electric starter / 12V 3Ah
Transmission 6 gears
Carburetor Keihin EFI, throttle body 42 mm
Control 4 V / DOHC with finger followers
Lubrication Pressure lubrication with 2 oil pumps
Gear ratios 13:32 15:30 17:28 19:26 21:25 22:24
Primary ratio 22:68
Final drive 13:48
Cooling Liquid cooling
Clutch Wet multi-disc clutch, Brembo hydraulics
Ignition Keihin EMS
2012 KTM 350SX-F
http://www.mediafire.com/convkey/ca7...79a1q9wq5g.jpg
http://www.mediafire.com/convkey/fdf...rg460s505g.jpg
Engine
Displacement 349.7 cc
Bore/stroke 88/57.5 mm
Compression ratio 13.5:1
Transmission 5 gears
Gear ratios 14:28 16:26 18:24 21:24 22:21 -
Primary ratio 24:73
Final drive 14:50
Ignition Keihin EMS
2012 KTM 450SX-F
http://www.mediafire.com/convkey/ed3...w205l8105g.jpg
http://www.mediafire.com/convkey/166...dshoyibq5g.jpg
Engine
Displacement 449.3 ccm
Bore/stroke 97/60.8 mm
Compression ratio 12.5:1
Carburetor Keihin FCR-MX 41
Lubrication Pressure lubrication with 3 oil pumps
Gear ratios 16:34 19:31 20:26 23:25 26:24 -
Primary ratio 29:74
Final drive 14:52
Clutch Wet multi-disc clutch, Magura hydraulics
Ignition Kokusan
اتمنى الموضوع يعجبك يا غالى
