انا اول مرة اشوفه الصراحة
الواحد بيحتار لما بيجي يغير زيت
يا ريت يا جماعة الخبراء يفيدونا ازاي نعرف ان علامات ان الزيت كويس
يعنى مثلا من صوت الموتور ولا من حيث الجودة لان حركة اللزوجة بتاعت الصباع دي مش مقتنع بيها الصراحة
شباب
كاسترول GTX دة زيت عربيات مش موتوسيكلات
أنا هحاول أجمع اللينكات هنا:
Castrol
Castrol USA - 4-Stroke Motorcycle Engines
Valvoline
ATV & Motorcycle Oil | Find Motorcycle & ATV Oil Products at Valvoline
S H E L L
http://www.....l.com/home/content/pr...e_engine_oils/
Mobil
Motorcycle Oil | Mobil 1
Caltex
Motorcycle Oil - Havoline Power 2T & Havoline Super 4T - Caltex
Question:
Difference Between Car and Motorcycle Oils
What is the difference from motorcycle oil than car oil?
-- Matt Coffman, Attica, NY
Answer:
Motorcycle oils and passenger car oils are very similar, with the exception of a couple of areas that are key to motorcycle operation. The first area concerns common sumps, or the use of motor oil, to lubricate and cool the transmission. As you know, in a passenger car the transmission is lubricated by an ATF fluid, which has frictional properties required for transmission operation. In a motorcycle, where the transmission may be lubricated by the engine oil, an engine oil that does not have the same level of friction modification (for fuel economy) of a typical passenger car engine oil will provide better transmission performance in terms of transmission lock-up and slippage. So motorcycle engine oil does not contain the friction modifiers of a passenger car engine oil. The second area of concern for motorcycle engine oils is that they tend to shear (breakdown viscosity) more quickly than a typical passenger car.
A very good Wikipedia page
Motor oil - Wikipedia, the free encyclopedia
يعني الكاسترول الي انا نزلت صورته بتاع عربيات ومينفعش للموتسيكيلات؟
هيشتغل برضو بس يفضل تدور على نوع من الانواع اللي في اللنكات اللي فوق.
يمكن صعب في الشرق الاوسط عموماً بس أنا حاولت أجيب المعلومة الصح.
لو مضطر تستخدم زيت عربيات...يبقى جيب زيت معدني مش تخليقي
20W50
وأهم حاجة اوعى يكون Energy Conserving
وحاجة كمان اللي هي Service Category ودي مكتوبة في الكتالوج وشرحها في اللينك دة:
http://new.api.org/certifications/en...010_120210.pdf
SJ - SL - SM - SN
