النتائج 1 إلى 7 من 7
    الصورة الرمزية corsair
    رقم العضوية : 37729
    السيارة: Logan 2014
    السيارة[2]: Verna GLS 2009
    دراجة بخارية: أحبوش
    الحالة : corsair غير متواجد حالياً
    افتراضي حد يعرف حاجه عن كابسولات prolab caffeine 200 mg - Facebook Twitter whatsapp انشر الموضوع فى :
    مسئول الجيم عندي جابلي المنتج ده وقالي تاخد منه قرص قبل التمرين وقالي هيساعدك جدا وده شكل العلبة اللي مخليني مقلق موضوع ان نسبة الكافيين في الكابس الواحده 200 mg والكالسيم 75 mg هل ده هيكون في ضرر عليا ولا ايه وسعر العلبة 150 جنيه
    Caffeine is an alkaloid; of which there are numerous compounds such as the methylxanthines, with three distinguished compounds: caffeine, theophylline, and theobromine, found in guarana, kola nuts, coffee, tea, cocoa beans, mate and other plants. These compounds have different biochemical effects, and are present in different ratios in the different plant sources. Caffeine is the most popular drug on the globe. It is a powerful stimulant to the Central Nervous System. Moderate use seems to be desireable by all, male and female; although excessive use can produce undesireable effects. Caffeine was discovered in 1820. In 1838, it was found that theine, a substance in tea, was identical to caffeine. Six or so caffeine containing plants are used more worldwide as a beverage than any other plants and herbal materials put together. The many caffeinated natural plants are are: Coffee, Tea, Kola, Cocoa, and Guarana.
    Supplement Facts:
    Serving Size: 1 Tablet
    Servings Per Container: 100
    Amount Per Serving:
    Calcium (as Dicalcium Phosphate): 75 mg
    Caffeine Anhydrous: 200 mg
    Other Ingredients:
    Silica, Magnesium Stearate, Cellulose Gum, Stearic Acid.
    Directions: Adults 18 years of age and over: 100 to 200 mgs not more often than every 3 to 4 hours.
    Warnings: The recommended dose of this product contains about as much caffeine as 1 or 2 cups of coffee. Limit the use of caffeine-containing medications, foods, or beverages while taking this product because too much caffeine may cause nervousness, irritablilty, sleeplessness and occasionally rapid heartbeat. For ocassional use only. Not intended for use as a substitute for sleep. If fatigue or drowsiness persists or continues to occur, consult a physician. Do not use if you are diabetic. As with any dietary supplement, if you are pregnant or nursing a baby, seek the advice of a health professional before using this product.
    These statements have not been evaluated by the Food and Drug Administration. This product is not intended to diagnose, treat, cure, or prevent any disease
    Best Car
    [img3]http://www7.0zz0.com/2014/12/14/14/320011745.jpg[/img3]
    رقم العضوية : 37729
    السيارة: Logan 2014
    دراجة بخارية: أحبوش
    محدش هنا بيخس غيري ولا ايه الرجالة فين
    Best Car
    الصورة الرمزية hani945
    رقم العضوية : 9455
    الاقامة : مصر
    السيارة: لا يوجد
    السيارة[2]: لا يوجد
    الحالة : hani945 غير متواجد حالياً
    اللى اعرفه والله اعلم ان النسب العالية دى فيها ضرر على الكلى والكبد
    احسن حل للتخسيس :
    برنامج للتخسيس تلتزم بيه مع دكتور متخصص + الرياضة
    سبحانك اللهم وبحمدك ، أشهد أن لا إله إلا أنت أستغفرك وأتوب إليك
    رقم العضوية : 37729
    السيارة: Logan 2014
    دراجة بخارية: أحبوش
    والله من ناحية البرنامج الغذائي موجود والرياضة موجوده بس الدكتور مش موجود لاني ماشي مع نفسي بدون دكاتره لان الحقيقة انا اتعقدت منهم بس هل فعلا الكافيين والكالسيوم في ضرر علي الكبد والكلي
    Best Car
    رقم العضوية : 9455
    الاقامة : مصر
    السيارة: لا يوجد
    السيارة[2]: لا يوجد
    المنتجات الرياضية اللى بتتباع فى صالات الجيم بتحتوى على نسب عالية ، علشان كده لازم تكون تحت اشراف طبيب
    حضرتك لازم تروح لدكتور متخصص ، يعملك برنامج تخسيس تلتزم بيه
    الصورة الرمزية ashouhdy
    رقم العضوية : 36989
    الاقامة : Alexandria
    السيارة: كروز 2014
    السيارة[2]: Car Enthusiaset
    دراجة بخارية: :))
    الحالة : ashouhdy غير متواجد حالياً
    بص هو ال 200 جرام كأنك شربت 3 قهوة ورا بعض
    بس العلاقة بين الكافيين والجرى انها احتمال تديك طاقة تخليك قادر تلعب من غير كسل
    فى حاجات اقوى لكدة بس مضرة ولازم رياضة عنيفة لكن ليها مفعول السحر !
    اللى حيضيع بلدنا : الفهلوة و كلمة باشا و معلش و أصل
    الصورة الرمزية micromoud
    رقم العضوية : 35609
    الاقامة : Giza
    السيارة: Hyundai Verna
    السيارة[2]: Suzuki Maruti
    دراجة بخارية: N/A
    الحالة : micromoud غير متواجد حالياً
    المنتجات اللى بتحتوى على كافايين بتزود النشاط وبتزود ضربات القلب وبتجيب ارق زى القهوة كده فبتحتاج مجهود كبير اوى تمارسه عشان يشتغل معاك ويبتدى جسمك يكون فيه طاقة + رياضه شاقه = حرق للدهون ... وطبيعى لو تناولت المنتج فترة كبيرة هيكون فى عبىء على الكلى
    وفى معلومة تانية مش متأكد منها ان الكافيين بيكسر بعض الفيتامينات الموجوده فى الجسم زى فيتامين ب
    المنتج دا محفز للتمرين ولا يعتبر حارق للدهون
  1. حد يعرف حاجه عن ال c3
    بواسطة wehdo في المنتدى ستـــرويـن
    آخر مشاركة: 28-11-2011, 08:14 PM
  2. حد يعرف حاجه عن المركز ده
    بواسطة Magdyahassan في المنتدى مــــــازدا
    آخر مشاركة: 11-08-2010, 06:47 PM
  3. حد يعرف حاجه عن i 20
    بواسطة lolamtm في المنتدى هيــونــداى
    آخر مشاركة: 02-06-2009, 11:38 PM
  4. حد يعرف حاجه عن لمبة ال Epc
    بواسطة martinella في المنتدى سبـــيرانزا
    آخر مشاركة: 15-05-2008, 01:11 AM
