المشاركة الأصلية كتبت بواسطة mody3on
Focus has an advanced braking system to provide total reassurance, whatever the conditions. Fitted as standard, the Electronic Stability Programme (ESP) with Traction Assist (TA) helps combat problems that may occur during sudden manoeuvres, helping you to maintain full control of the vehicle. It reacts automatically if needed, by reducing power or applying a braking force to any wheel that is losing grip.
Emergency Brake Assist (EBA) is also there to ensure full braking force is available whenever necessary, helping reduce stopping distances in an emergency.
Meanwhile, an anti-lock braking system (ABS) and electronic brake-force distribution (EBD) are also fitted as standard, and these combine to ensure that your braking is more controlled.
من موقع فورد ايجبت
