彡彡彡. دلوووعة تويوتا ... وفخر الصناعة اليابانية ( تويوتا ديانا ) تقرير彡彡彡
Engine
Engine Type 4-Cylinder In-Line 16V 3.0 DOHC Turbo
Displacement (cc) 2982
Ecology Level Euro 4
Maximum output (kW [PS] / rpm) 80 (109) / 3000
Maximum torque (Nm / rpm) 286 / 1200 - 1600
Fuel System Common rail
Fuel Tank Capacity (litres) 60
Transmission 5 speed manual
Dimensions (mm)
Wheel Base 2545 2300
Vehicle Length / Width / Height 4690 / 1695 / 1985 4430 / 1695 / 1985
Deck length / width / height 3110 / 1600 / 380 2850 / 1600 / 380
Min. Ground clearance 165
Weight (kg)
Kerb weight 1735 - 1905 1705 - 1875
Payload 3500 3000
Gross vehicle weight 1765 1295
Performance (mm)
Min. Turning Radius 4900 4500
