صفحة 1 من 4 1 2 3 4 الأخيرةالأخيرة
النتائج 1 إلى 10 من 34
    الصورة الرمزية أبو عبدالله
    رقم العضوية : 97
    الاقامة : ManSOuRa
    السيارة: coRoLLa 06
    السيارة[2]: siRiOn 07
    دراجة بخارية: ان شاء الله
    الحالة : أبو عبدالله غير متواجد حالياً
    افتراضي *^*^* --وعملوها اليابانيين ومشت بالميه خلاص -- *^*^* - Facebook Twitter whatsapp انشر الموضوع فى :
    Japanese Company Creates Car That Can Run On Water
    Wouldn’t it be nice if a car could use only water to run? And not necessarily potable water, but any kind of water, even from the sea? Well, Genepax, from Japan, claims to have invented a fuel cell system that uses water to obtain hydrogen. It has shown last week two devices, a 120 W fuel cell stack and a 300 W fuel cell system that powered a REVA based minicar. According to Genepax, the little car could run at 80 km/h using only a litre of water, no matter where it came from: sea, river, rain etc.
    If this is true, it would solve many problems at once. The first one is hydrogen storage. To be kept in liquid state, this gas has to be cooled down to -252.87ºC, or 20.27 K, which requires a storage tank that can maintain such low temperatures or, if they get higher, to withstand high levels of pressure. In any case, these tanks get expensive and heavy, two characteristics that do not help electric vehicles in anything.
    The second one is price. The alternative to hydrogen storage is to obtain the gas from common fuels, such as methanol or even gasoline, but the machines that extract it, called reformers, are also expensive, and depending on the source of hydrogen, produce polluting emissions, although less than a combustion engine.
    If hydrogen can be extracted from water, the only byproduct will be oxygen. Ozone damage could also be possible, but catalysts may prevent it. And water is an abundant substance, especially sea water, that can also be used in WES, or Water Energy System, as Genepax has named it. The secret WES hides is its membrane electrode assembly, or MEA, which contains a material capable of breaking water down into its basic components (H2O) through chemical reactions.
    Critics claim that this is impossible because it contradicts the First Law of Thermodynamics, which states that “the increase in the internal energy of a system is equal to the amount of energy added by heating the system, minus the amount lost as a result of the work done by the system on its surroundings”. In other words, the energy that would be necessary to break the water molecules would be higher than what WES would generate for the car’s electric engine, hence the energy would come from somewhere else. A battery, for example.
    Unfortunately, there is a good chance Genepax has committed some sort of mistake. If not, it will have created something mankind has been seeking for a long time: the perpetual motion engine. Since all the car needs to run is water, and since the product of hydrogen reactions in the fuel cells is also water, the WES system could refuel itself with what it generates and could run forever with the same quantity of water. We hope Genepax has had a major breakthrough, but that does not seem to be the case.
    عن أبي هريرة قال :
    قال رسول الله صلى الله عليه وسلم :
    إذا قال الرجل لأخيه :جزاك الله خيرا ، فقد أبلغ في الثناء
    الصورة الرمزية mohamed hatem
    رقم العضوية : 1960
    الاقامة : 6 October
    السيارة: Logan - AT - High Line
    السيارة[2]: Sunny EX 2010 - Aut
    الحالة : mohamed hatem غير متواجد حالياً
    عايز 10 عربيات .....بس اوعى تكون بمياه معدنيه ....يبقى معملناش حاجه
    ----- إلا رسول الله -----
    قالولي بتحب مصر أخدني صمت طويل
    وجت في بالي ابتسامة وانتهت بعويل
    الصورة الرمزية فادى
    رقم العضوية : 1834
    الاقامة : القاهرة-مصر
    السيارة: نصر شاهين
    السيارة[2]: نصر 128
    الحالة : فادى غير متواجد حالياً
    يادى النيييلة
    هو اللى نعيده نزيده,
    استاذ سبعاوى رد على الموضوع ده سابقا, و انا هعيد شرح الموضوع تانى,
    الطاقة لا تفنى و لا تستحدث متفقين على الكلام ده؟!!
    و المياه لا تحتوى على طاقة اذن متفقين انو مفيش حاجة اسمها "مشيت بالميه".
    الموضوع كله انو الكهرباء بتستخدم لتحليل المياه الى هيدروجين و اوكسوجين,
    و بعدين ندخل الهيدروجين لمحرك احتراق داخلى,
    فيتحول لمياه تانى مع الاحتراق,
    طبعا الطاقة اللى انا استخدمتها عشان احلل المياه - الفواقد و هى كبيرة = الطاقة اللى هخدها تانى من محرك الاحتراق الداخلى.
    طبعا مع ملحوظة مهمة جدا انو مفيش محرك احتراق داخلى ممكن تتعدى كفاءته ال30% فى احسن الأحوال.
    طب انا استفدت ايه من اللفة دى كلها,
    مانا اخد الكهربا و ادخلها على محرك كهربا علطول و اخد كفاءة اعلى حوالى 90% كفاءة محرك الكهرباء ده طبعا الى جانب انو عمر محرك الكهرباء أطول من محرك الاحتراق الداخلى و سرعته متغيرة و مشاكله اقل!!
    يعنى نتفق على حاجة : السيارة مش بتمشى بالمياه هى بتمشى بالكهرباء, و التسمية اصلا "بتمشى بالمياه" غير علمية لأن المياه مجرد وسيط لنقل الطاقة لكن الطاقة جاية من الكهرباء الى هتتخزن فى شكل بطارية اذن انا خدت كل مساوىء محرك الكهرباء من ثقل وزن البطارية و احتياجها لوقت كبير للشحن و قدرتها الضعيفة على تخزين الطاقة و ضفت عليها كل مساوىء محرك الاحتراق الداخلى من قلة الكفاءة و السرعات المحدودة و العمر القصير و مشاكل الصيانة و دورانه فى اتجاه واحد.
    فبكده انا حصلت على اسوأ سيارة ممكنة فيها كل عيوب سيارات الكهرباء و الاحتراق الداخلى على بعض و فوق كده و كده كفاءة اقل من سيارة الاحتراق الداخلى التقليدية!!
    الموضوع نصب فى نصب سواء من امريكا او اليابان او غيرهم.
    مصر فوق الجميع
    الصقر سوف يحلق عاليا رغم أنف قانون المرور الجديد.
    http://www.postimage.org/aVfbhTi.jpg
    رقم العضوية : 97
    الاقامة : ManSOuRa
    السيارة: coRoLLa 06
    ولما هو الموضوع بالبساطة دي والنصب ده
    الموقع او المواقع اللي بتنقل الخبر واخدين فلوس ولا داخلين في النصبايه برضه
    انت حضرتك ليس عندك اي خبره باليابانيين تقريبا
    لأن صفة الكذب دي ابعد ما يكون ان ينتج شئ باسم الياباني ويكون كذب للعالم
    ساعتها انا اؤكدلك انهم كلهم هينتحروااااااااا
    وانا نفسي اعرف هو ايه اللي ممكن حضرتك تصدقه او ايه اللي انت صدقته قبل كده
    لما كل حاجه كذب حتى لو مش اصحابها هما اللي قالو عليها
    يعني الموقع اللي انا ناقل منه
    كاتب الخبر في تصنيف السيارات الاختبارية والسيارات الخضراء اي النقيه التي ليس لها تلوث
    ممكن تقولي الناس اللي قائمين على هذا الموقع على اقل تقدير مبيفهموش ولا ايه بالظبط لأني احترت
    عن أبي هريرة قال :
    الصورة الرمزية فادى
    رقم العضوية : 1834
    السيارة: نصر شاهين
    السيارة[2]: نصر 128
    اقتباس المشاركة الأصلية كتبت بواسطة أبو عبدالله مشاهدة المشاركة
    ولما هو المضووع بالبساطة دي والنصب ده
    يا استاذ ابو عبدالله دلوقتى انا مش بتكلم عن اليابانيين و غيرهم,
    يعنى هى اليابان مفيهاش نصابين مثلا؟!! و لا حرامية و لا قتالين قتلة؟!! ليه ناس جاية من كوكب تانى؟!!
    المهم حضرتك مسكت فى جملة واحدة و سبت كل اللى انا كاتبه فى الأول, حضرتك لو عندك رد اتفضل و قولى ازاى العربية تمشى بالمياه, و أكيد حضرتك تعرف انو المياه مفيهاش طاقة,
    البترول مثلا فيه طاقة تكونت بفضل تفاعلات كيميائية على مر السنين فى ظروف نادرة للكرة الأرضية, هذه التفاعلات خزنت حرارة الأرض و الطاقة الشمسية لقرون, ثم نأتى نحن لنستخدم هذه الطاقة, أما الماء فلا يحتوى على طاقة و حضرتك على ما اعتقد مهندس و عارف الكلام ده.
    مصر فوق الجميع
    الصورة الرمزية misho2mimy
    رقم العضوية : 13056
    الاقامة : alexandriaِAl
    الحالة : misho2mimy غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة فادى مشاهدة المشاركة
    يادى النيييلة
    الله ينور عليك يا فادي كلامك منطقي وصحيح 100% من الناحية العلمية ...كما ان هناك وسائل اكثر فاعلية مثل استخدام محولات شمسية تعمل تخزين الطاقة واعادة استعمالها و هذه الطريقة تم تجربتها ونجحت ولا ادري ان كان تم تطبيقها ام لا ...
    اللهم اضرب الظالمين بالظالمين واخرجنا من بينهم سالمين غانمين......... امين يا رب العالمين
    http://s2.ae.gladiatus.com/game/c.php?uid=73216
    رقم العضوية : 13056
    اسف اني اقول لك ان ما لكش حق يا ابو عبد الله لانك للاسف كمن توقف عند " ولاتقربوا الصلاة " ... وبعدين ليه يكون الكذب ابعد مايكون عن اليابانيين ؟؟؟
    يا تري ده تاثير البراكين اللي عندهم ولاده اساسا من ايام قنبلة هيروشيما؟؟؟
    يا سيدي الفاضل الناس كلهم من طينة واحدة لا اظن انهم مختلفين عن البشر لان " كل بن ادم خطاء " واكرر اسفي مرة اخري ....!!
    الصورة الرمزية AboMaro
    رقم العضوية : 10319
    الاقامة : Ismailia
    السيارة: لما نحل مشكلة الاولى
    السيارة[2]: اكسنت 2010جايه بايظه
    الحالة : AboMaro غير متواجد حالياً
    ياه حاجه جميله بقى احنا هنا اللي بنحلل وننقد اليابانيين
    ونقول لأ دول نصابين ولا لأ دول حلوين ومؤدبين
    طب بأمارة ايه
    معلش اوعى حد يزعل ومحدش يرد عليا ويقولي ده احنا اولاد الفراعنه
    لان احنا لا عملنا ولا حنعمل اللي هما بيعملوه
    ولا احنا دخلنا مدارس تعلمنا كل يوم ازاي نخترع ونطور مخنا
    احنا اتعلمنا ازاي نتفرج عليهم وبس
    فاهمييييييين و بسسسسسسسسسسس
    و بقولها تاني اوعى حد يزعل انتوا احرار
    وبرده عشان محدش يزعل ...احنا برده حلويين اوي ........ ده احنا اللي دهنا الهوا دوكو ......ولا ايه
    الصورة الرمزية mohamed2002
    رقم العضوية : 12396
    الاقامة : Alexandria
    السيارة: lada
    السيارة[2]: Lada 2105
    الحالة : mohamed2002 غير متواجد حالياً
    نقدر نقول ان الشعب الياباني يتصف بحب العمل والاتقان الشديد ,قارن كدة بين تلفزيون ياباني وتلفزيون صيني وشوف مين الافضل (انا مرتضش اقول تويوتا وشيري عشان محدش يزعل:))لكن برضة مش كل اليابانين ناس a1 اكيد فيهم اللي بيكذب واللي.. واللي..., لكن في النهاية نقدر نقول الغالبية منهم شعب عملي ومحب للعمل
    ams
    الصورة الرمزية ams
    رقم العضوية : 3867
    الاقامة : عين الشمس
    السيارة: N/A
    السيارة[2]: N/A
    دراجة بخارية: N/A
    الحالة : ams غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة AboMaro مشاهدة المشاركة
    ....لأ....
    أحمد محمد صبرى
    يا رب تفهم يا تتح
    ماشى فى نور الله بدعى و اقول .... يا رب
  1. سر تفوق اليابانيين
    بواسطة horas3000 في المنتدى المنتــــــدى الاجتمــاعى
    مشاركات: 10
    آخر مشاركة: 15-11-2009, 10:07 AM
  2. فيديو تمااااااااااااااااااام عن الفيات 126 مخلوش حاجه الا وعملوها فيها
    بواسطة mazagngi2010 في المنتدى مقــاطـع الفيــديـو و الكليبات و صـور للسيارات
    آخر مشاركة: 11-11-2009, 09:18 PM
  3. دلوقتى تقدر تشغل عربيتك بالميه ب 70 $0
    بواسطة mahamedaraby في المنتدى المنتــــــدى العـــــــــــام للسيــارات
    آخر مشاركة: 29-02-2008, 01:49 PM
  4. والله وعملوها الرجاله
    بواسطة kamatchodj في المنتدى سبـــيرانزا
    آخر مشاركة: 23-04-2007, 01:08 AM
