البومة ال 1600 بس اللي CVT
انما ال 1300 أوتو عادي 4 غيار
ال CVT اللي في الامبريزا مافيهوش نقلات مانيوال
انما فيه Low Gear بس
ممكن توضح أكتر يعني ايه مافيهوش نقلات مانيول , لكن فيه low gear بس
كل ال lineartronic بتاع subaru سواء ال 2000 أو ال 1600 فيه مانيوال
ممكن حضرتك تبص على ال brochure بتاعها
http://www.subaruegypt.com/ajax/down...386&height=210
دخل بياناتك بس و هم هيبعتهولك
و دي صورة تؤكد الكلام ده
بص حضرتك على ال + وال - في الشمال
http://3.bp.blogspot.com/-9knLduzazM...llpaper_38.jpg
الصور دي مش اللي بتنزل في مصر على فكرة , العدادات مختلفة و الكسيت و الشاشة كمان مختلفين
ده اللي مكتب على موقع subaru
http://www.subaru.com/engineering/transmission.html
Transmission
From high performance to low maintenance, Subaru transmissions offer you excellent efficiency in an all-wheel drive vehicle.
Lineartronic® CVT
It stands for Continuously Variable Transmission, and this innovative technology has been engineered to work seamlessly with the SUBARU BOXER® engine and Symmetrical All-Wheel Drive to help reduce fuel consumption. The stepless gear ratio allows the engine to run within its optimal power range for improved fuel economy, while its lightweight, compact design helps the vehicle stay as agile as it can be.
In Automatic Mode, it adjusts instantly to match your acceleration, eliminating the need to shift and preserving the vehicle's momentum often lost with conventional automatic transmissions.
In 6-Speed Manual Mode, paddle shifters are mounted for fingertip control, giving you the power to select the gear ratio that best suits your driving situation. The result is a sharper and sportier driving experience.
Available on: Outback, Legacy, Impreza
Automatic Transmission with Manual Shift Mode
Refine the performance of your automatic transmission with smooth-shifting Manual Shift Mode technology. Working with 4-speed and 5-speed automatic transmissions, you can take control of the gears when you need greater precision, like climbing hills or passing vehicles, and then settle back into automatic when you don't. Easy. Efficient. Brilliant.
Available on: All Vehicles
http://www.subaru.com/content/engine...t_mode_282.jpg
Manual Transmission
Dependable and lightweight manual transmissions give passionate drivers a range to express their personal driving style. The coated synchromesh gears of the 5- or 6-speed manual transmissions make every shift smooth and efficient for fluid and exciting acceleration.
Available on: Outback, Legacy, Impreza, WRX, Forester
http://www.subaru.com/content/engine...ission_282.jpg
من الكلام اللي فوق ال lineartronic بينزل مع ال AWD
يبقى كده اللي هنا في مصر lieartronic
و مكتوب إن فيه manual mode
ده لينك لل brochure
http://sdrv.ms/UuoJKy
لو بصيتوا في صفحة 19
هتلاقوا صورة لل lineartronic و فيه + و -
يا ريت اللي شاف العربية على الحقيقة يوضحلنا الموضوع ده
و يا سلام لو صورة بقى للفتيس :)
ياريت فعلا لو في حد معاه العربية يوضحلنا أكتر
مش المفروض ان الى بتنزل هنا cvt 6 نقلات
lineartronic
