طبعاً في منها الاسكترا. الي هيا كبينة ونص بتيجي بالشكل ده
وبيبقى الصالون او الكنبة الداخلية كدة
وممكن كمان بتيجي الفخاد الخلفية. زي فخاد العربيات الامريكي بهذا الشكل
رقم العضوية : 128488
الاقامة : ★ قسم تويوتا.★
السيارة: ♠ وشيخ الياباني حالياً ♠
السيارة[2]: ♥ عمدة تويوتا ♥ سابقاً
دراجة بخارية: ♥♥♥♥♥♥♥♥ ♡ ☜
جديد : تويوتا تاكوما
◣◥2012 Toyota Tacoma ◣◥
عملاق البيك أب !
Toyota released at the end of last week the details, images and a presentation video of the updated 2012 Tacoma pickup truck. The styling chages brought by the 2012 Toyota Tacoma are minimal, and include a slightly modified front bumper, a new grille and hood and re-styled headlamps. At the interior, the 2012 Tacoma features a center console, new instruments and a new steerign wheel. The 2012 Tacoma's center console now features air conditioning and heater controls together with power point locations. Toyota's 2012 Tacoma Access and Double Cab now come with a heavy-duty all-weather floor. The high performaqnce
version of the pick-up, the 2012 Tacoma TRD Sport, together with its Off-Road version, are now equipped with a water resistant upholstery. The 2012 Toyota Tacoma 2.7L is powered by a 2.7-liter inline 4-cylinder, DOHC 16-valve engine with VVT-i, which outputs 159 hp at 5,200 rpm and 180 lb-ft of torque at 3,800 rpm. The 2012 Tacoma 2.7L is available with either a 5-speed manual transmission or a 4-speed ECT automatic gearbox and it has a payload of 1,385 lbs in the PreRunner Access Cab version. It's maximum towing weight is rated at 3,500 lbs.
The more powerful version of the 2012 Toyota Tacoma, the 4.0-liter V6 powered one, has an output of
موصفات المحرك
Other novelties brought by the 2012 Toyota Tacoma include a larger, 3.3-inch higher-resolution display a new temperature gauge, a rear-view mirror with compass and HomeLink and additional storage compartments.
The 2012 Toyota Tacoma price list will be announced at a later date.
2012 Toyota Tacoma specifications:
ENGINE 2.7L-4CYL
Type, Materials 2.7-liter inline 4-cylinder, DOHC 16-valve cast iron block with aluminum alloy head with VVT-i
Displacement 2,694 cc
Bore x Stroke 3.74 x 3.74 in.
2012 Toyota Tacoma video:
Compression Ratio 9.6:1
Horsepower 159 hp @ 5,200 rpm
Torque 180 lb-ft @ 3,800 rpm
Ignition System DIS (Direct)
Fuel System EFI
Recommended Fuel 87 or higher
Emission Certification LEV II
EPA Estimated Fuel Economy*
(city/highway MPG)
21/25 (5-speed manual)
18/20 (5-speed manual 4x4)
19/24 (4-speed automatic)
18/21 (4-speed automatic 4x4)
ENGINE 4.0L-V6
Type, Materials 4.0-liter DOHC EFI V6, 24-valve aluminum block with aluminum alloy head with VVT-i
Displacement 3,956 cc
Bore x Stroke 3.70 x 3.74 in.
Compression Ratio 10.0:1
Horsepower 236 hp @ 5,200 rpm
Torque 266 lb-ft @ 4,000 rpm
Fuel System EFI
(city/highway MPG)
16/21 (6-speed manual 4x2/PreRunner)
15/19 (6-speed manual 4x4)
17/21 (5-speed automatic)
16/21 (5-speed automatic 4x4)
Suspension - Front Coil spring independent double wishbone with gas-filled shock absorbers (4x2 – low mount; 4x4/PreRunner – high mount)
- Rear Leaf spring rigid suspension
- Front Stabilizer Bar Diameter 1.18 in.
1.10 in. (TRD Off-Road package only)
- Rear Stabilizer Bar Diameter 0.98 (X-Runner only)
Steering - Type Rack-and-pinion power steering
- Overall Ratio 17.4/17.3 (4x2/PreRunner and 4x4)
- Turns (lock to lock) 3.43 turns (4x2)
3.64 turns (PreRunner, and all 4x4)
- Turning Circle Diameter (curb to curb) 4x2/4x4 Reg. Cab: 36.8/36.0 ft.
4x2/4x4 and PreRunner Access Cab: 42.0/40.6 ft.
X-Runner: 42.7 ft
Double Cab and Double Cab Long Bed: 40.6/44.0 ft.
Brakes - Front - type/diameter
- Front Swept Area
(4x2/4x4)
- Rear - type/diameter
- Rear Swept Area
(4x2/4x4)
- Parking Ventilated disc/10.83 in. (4x2)
/12.56 in. (PreRunner and 4x4)
56.75/61.81 sq. in.
Leading-Trailing Drum /10.0 in.
65.51/61.81 sq. in.
Pedal Type (Automatic)
Stick Type (Manual)
Anti-lock Brake System (ABS) Brake Control System with Anti-lock Brake System (ABS), Electronic Braking Distribution (EBD), Brake Assist (BA), TRAC, VSC and Auto LSD
EXTERIOR FEATURES
Fiber-reinforced Sheet-Molded Composite (SMC) inner bed with steel outer panels, storage compartments, rail caps and removable tailgate
Deck rail system with 4 adjustable tie-down cleats
115V/400-watt deck-mounted Powerpoint
Dual rear-hinged access doors
Black grille insert/ Argent surround, black door handles, mirrors, front and rear bumpers
Black overfenders
Front skid plate
Engine skid plate
Fog lamps (V6 Only)
Power Outside Mirrors
Color-keyed hood scoop
Color-keyed front bumper, overfenders and chrome rear bumper
Front and rear mudguards
Rear mudguards only
Color-keyed bumpers, overfenders, grille surround & door handles
Color-keyed bumpers, overfenders, grille insert / surround, door handles, power mirrors and body kit
X-brace-tuned suspension with gas-filled Bilstein® shock absorbers and rear stabilizer bar
2-Speed windshield wipers
Variable-speed windshield wipers
Sliding rear window
Sliding rear window with privacy glass
2-Fixed cargo bed tie-down points
15-in. styled steel wheels with P215/70R15 tires
16-in. styled steel wheels with P245/75R16 tires
16-in. alloy wheels with P245/75R16 tires
16-in. alloy wheels with P265/70R16 tires
INTERIOR FEATURES
Air conditioning
Cruise control
Cloth-faced tilt-forward bench seat with adjustable headrests
Fabric-trimmed front bucket seats with passenger-side fold-flat seat, adjustable headrests and center console
Driver’s seat with adjustable lumbar support
Sport seats with Sport fabric trim and driver’s-seat adjustable lumbar support (passenger side fold flat feature delete)
Fold-up rear seats with under-seat storage
60/40 split rear bench seat with adjustable headrests and under-seat storage
Rear bulkhead storage
Overhead console with maplamps, sunglass holder
Full carpeting
Power windows and door locks
Remote keyless entry system
Leather-wrapped steering wheel and shift lever
LED-illuminated gauges with speedometer, tachometer, coolant temperature gauge, fuel gauge, digital clock and tripmeter
Tailgate-handle integrated backup camera linked with an auto-dimming mirror with monitor
Tilt/telescopic steering wheel
Rear-seat heater vents
Dual 12V auxiliary power outlets (one, plus cigarette lighter)
Sun visors with passenger-side vanity mirror
Fabric-trimmed sun visors with sliding extensions and vanity mirror
Sculpted door trim with two bottle holders
Three front cup holders (Two front cup holders on bench seat models)
Dual rear cup holders
AUDIO SYSTEM
AM/FM CD with MP3/WMA playback capability, six speakers (including two ceiling-mounted speakers on Access Cab, four speakers on Regular Cab), & auxiliary audio jack
AM/FM CD with MP3/WMA playback capability, seven speakers including two ceiling-mounted speakers and subwoofer, & auxiliary audio jack
AM/FM CD, MP3/WMA playback capability, seven speakers including two ceiling-mounted speakers and subwoofer (only for C-Cab), auxiliary audio jack, & XM Radio (includes 90-day trial sub......ion), Bluetooth
JBL® Audio with AM/FM CD, MP3/WMA playback capability, six speakers and subwoofer, auxiliary audio jack, Bluetooth®, & XM Radio (includes 90-day trial sub......ion), Entune, USB
MATRIX SIENNA STANDARD MECHANICAL FEATURES
- Coil Spring Double Wishbone Suspension
- Rear leaf spring suspension with staggered outboard-mounted gas shock absorbers
- Automatic Limited Slip Differential (Auto LSD)
- Variable Assist Power Rack & Pinion Steering
- Gated automatic transmission shifter (automatic transmission only)
- Clutch-start cancel (4x4 manual transmission only)
STANDARD SAFETY AND SECURITY
- Star Safety System - includes Vehicle Stability Control (VSC), Traction Control (TRAC), Anti-lock Brake System (ABS) with Electronic Brake-force Distribution (EBD), & Brake Assist
- Driver and front passenger Advanced Airbag System
- Driver and front passenger seat-mounted side airbags, front and rear side curtain airbags
- Driver and front passenger active headrests
- Driver and front passenger seatbelts with pretensioner, force limiters and adjustable shoulder anchors
- 3-point seatbelts for all seating positions; Driver-side Emergency Locking Retractor (ELR) and Automatic/Emergency Locking Retractor (ALR/ELR) on all passenger belts
- Side-impact door beams in all doors
- LATCH (Lower Anchors and Tethers for Children) includes lower anchors for front passenger seat on Regular Cab 4X4 Automatic, Access Cab and rear outboard seats on Double Cab and Access Cab
- LATCH (Lower Anchors and Tethers for Children) includes top tether anchor for passenger and center front seat on Regular Cab with bench seat, front passenger seat on Regular Cab 4X4 Automatic, Access Cab, and all rear seating positions on Double Cab and Access Cab
- Child protector rear door locks – Double Cab models
- Tire Pressure Monitor System
لمحة على الصالون الداخلي
امكانية طي المقاعد الخلفية
مسجل يشبه المسجلات الامريكية
جمال لوحة العدادات
جمال التابلوة بالكامل
في الختام. ( أي خدمة ). أيه رأيك بقه في العربية
وتحياتي
صور منقولة
سقوط سماوات فوق رأس تجار روبابيكيا امين يارب
في منها ايضاً التكوما السينجل
الي هيا كبينة وحدة. 4x4
ياجمالوووو
معيار الفخامة لدى تويوتا
رقم العضوية : 113094
الاقامة : suez
السيارة: BAIC SENOVA
السيارة[2]: -kia sephia 2002
عربيه وهم
ماشاء الله
[shfaf2]https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQiZz5qFtKnd2BEvbAUpUb7-hU-RJQavswzOiBfx61bEqrmegeu[/shfaf2]
رقم العضوية : 122422
السيارة: ابعت يا رب
السيارة[2]: Nubira2004
دراجة بخارية: توكتوك فيرارى :P
روووووعه يا حاج تلسم الايادى
رقم العضوية : 71514
الاقامة : EgYpT-ⵍⵎⵖⵔⵉⴱ-
السيارة: -- -- all FiaT ---
دراجة بخارية: - - - - - - -
ما شاء الله موضوع جميل
وفعلا جميلة وعدادت روعة في راي
تحياتي ..
