speaking of honda
i have a friend who had a honda with a special-ordered racing engine that cost 10,000 le 7 years ago, and he makes it to hurgada on only 20 litres of gasoline
رقم العضوية : 2087
الاقامة : Nasr City, Cairo
السيارة: ميتسوبيشي لانسر 2006
السيارة[2]: شيفرولية فرونتيرا 3200 V6 (ايسوزو روديو)
i insist
no way
a 600 kilos for 37 litres of fuel
its not even for a honda
but the way you calculate the fuel is not accurate
saying the pointer was on half of the gauge is not an exact figure, you should had refuled the car, sure it would take more than 50 litres if not 60
man its a 6 cyl 4000 cc engine draging a 2 tons of steel
رقم العضوية : 12256
الاقامة : h0me
السيارة: the l0new0lfm0bile2
السيارة[2]: the l0new0lfm0bile1
دراجة بخارية: Ducati
speaking of honda
رقم العضوية : 2087
seems that you guys are using a different type of gasoline than the ones we use in our cars
hahahahhahahaha
the best fuel consumption in my previous honda civic was about 340 km/ 20 lites
not 600, are you sure that the car was not draged by another car :p
رقم العضوية : 12256
الاقامة : h0me
[quote=Adham;362641]i insist
no way
its not even for a honda]
[quote=Adham;362393]no way, the best fuel consumption for it is 190km/h in case of continous driving on 90 km/h for looooong distance
no driver and tires filled with Hydrogin hahahah, not even in a fiat 128
what do U mean by fuel consumption is 190 km/h??
unlike you, sarcasm was never my best field of interest
you are still not reading what I type
the same trip that you dont like with the same car took 90 litres of gasoline when driving 140-180km/hr most of the way eccept for the radar point near to alamein. not passomg 90 km/hr did only half a tank, tank is standard 20 gal. capacity
was your honda equipped with a special-ordered race engine and trany that cost 10,000 le in the year of 2001? i doubt it
رقم العضوية : 2087
ops not 190km/h , its a typing mistake, i meant 190 km/ 20 litre (safee7a
i am not sarcasming, i was just kidding with you,
for sure no 4000 cc 6 cyl car would do 300km/20 litre, no manifacturer ever indicated such low fuel consumption, it would be a spec they would put in every advertizing for marketing
i am talking of a standard honda civic engine
and i think a RACE engine would be higher fuel consumption as it gives higher performance and more torque
what you think ?? i guess you would agree on that, strictly speaking
رقم العضوية : 12256
الاقامة : h0me
if you noticed I stated that it was odd because same car did the same trip and consumed±90 litres when drove140+km/hr. also race engines technologies are not fully revealed and yuo can enhance motor performance by changing the ECU, in australia they call it performance chip, and i've seen it there they swap to race and performance engines and trany and fuel consumption does reduce
enhancing a car engine performance is not only by modifying engine dimensions but also by enhancing engine electronics
check out these links
http://www.dansdata.com/hotchips.htm
http://sydney.gumtree.com.au/c-Cars-...QAdIdZ56754341
http://cgi.ebay.com.au/Holden-Commod...80802101a22030
رقم العضوية : 2087
not really to swap the IC of ECU, some times they just change the software,
i am a member also in the holden frontera forum,
they stated that the best consumption of it (3200 cc V6) were 190 km/ 20 litres, i am thinking there were a mis mesurement of the consumed litres during that trip
because the consumption can not simply be changed from 90 litres to 35 litres only by reducing the spped from 90 to 140 km/h
رقم العضوية : 12256
الاقامة : h0me
it seems you did not even bother to check the links i sent
BTW i checked the tank and its standard 20 gal
I told about what happened with me-which i stated to be ODD- and this would be the end of discussion for me regarding this subject
رقم العضوية : 7889
الاقامة : Egypt
السيارة: Peugeot 405
السيارة[2]: Skoda mini Fabia
thnx ya ostaz lonewolf 2wiiiiiiiiiii we 2aseif 3l ta25eeyr bs kont mash3'ooool 2wiii 2el 2yam dey we 2na 2aseif le tany mara
