ios 6.1, 6.0, 6.0.1 untethered jailbreak for all idevices
evasi0n jailbreak works for both mac and windows,
and is considered to be one of the most reliable jailbreaks by the whole community.
download evasi0n jailbreak from dircet high speed links according to your device.
you can use evad3rs jailbreak for jailbreak, recovery fix and many more functions.
evasi0n jailbreak can jialbreak your iphone, ipad and ipod touch.
evad3rs jailbreak is 100% risk free if you use it correctly
jailbreak – supported devices:
* iphone 5
* iphone 4s
* iphone 4
* iphone 3gs
* ipad mini
* ipad 4
* ipad 3
* ipad 2
* ipod touch 4g
* ipod touch 5g
* appletv 2g
jailbreak – supported ios versions:
* ios 6.1
* ios 6.0.2
* ios 6.0.1
* ios 6.0
requirements
- 5 minutes of your time!
- a computer, running windows (xp minimum), mac os x (10.5 minimum) or linux (x86 / x86_64)
- an iphone, ipad or ipod running ios 6.0 through 6.1 (you may check in settings / general / about => version)
- a usb cable to connect the device to the computer
important! Read me!
1 - make “backup” for your ios device using itunes or icloud before use the tool of evasion jailbreak. through this advices, you will absolutely sure that your data will not be untouched by any damage.
2 - remove password lock screen, do not put any protection foundations in your ios so that evasion jailbreak will work without any defects or problems.
3 - be patient when you do the jailbreak process. Don’t run itunes or xcode during the jailbreak process.
4 - the best thing for jailbreak free from errors is not touching the computer in any way, so as to ensure the best results.
