There has always been a huge debate over what to do if your car oversteers or understeers. The first thing people go to is always the swaybar when someone always asks how to "loosen" or "tighten" their car. However, there is a lot more to making your car handle to your liking, and everything will do a little something different depending on speed, turn-in rate, braking percentage, weight distribution and a number of other factors. To help everyone out, here is a list of things you can do to your car to get it how you want. You might even want to print it out and bring it to the track with you. Here goes:
TO REDUCE UNDERSTEER or INCREASE OVERSTEER:
Front tires:
- Increase tire pressure in 2.5psi increments
- Increase Section Width
- Lower the Aspect Ratio
- Reduce front tread depth
Rear Tires:
- Reduce tire pressure in 2.5psi increments
- Reduce section width
- Install higher aspect ratio tires
- Increase rear tread depth
Front Wheels:
- Install wider wheels
- Install lighter wheels
Rear Wheels:
- Install narrower wheels
- Install heavier wheels
Front Alignment settings:
- Dial in more negative camber
- Dial in More toe-out
- Dial in more positive caster
Rear Alignment settings:
- Dial in more positive camber
- Dial in more toe-out (Same as front)
Anti-Sway bars:
- Soften the Front
- Stiffen the Rear
Spring rates:
- Soften the Front
- Stiffen the Rear
Shock absorbers:
- Soften the Front
- Stiffen the Rear
Suspension Bushings:
- Soften the Front
- Stiffen the Rear
Brake Proportioning
- Reduce Front brake pressure
- Increase rear pressure
Weight Distribution
- Reduce front weight
- Increase rear weight
Aerodynamics:
- Increase Front Downforce
- Reduce rear downforce
TO REDUCE OVERSTEER or INCREASE UNDERSTEER: Front tires:
- Decrease tire pressure in 2.5psi increments
- Decrease Section Width
- Install higher Aspect Ratio tires
- Increase front tread depth
Rear Tires:
- Increase section width
- Reduce aspect ratio
- Decrease rear tread depth
Front Wheels:
Rear Wheels:
- Dial in less negative camber
- Dial in less toe-out (to toe-in if needed)
- Dial in less positive caster
- Dial in less positive camber
- Dial in less toe-out (Same as front)
Anti-Sway bars:
- Stiffen the Front
- Soften the Rear
Spring rates:
- Stiffen the Front
- Soften the Rear
Shock absorbers:
- Stiffen the Front
- Soften the Rear
- Stiffen the Front
- Soften the Rear
Brake Proportioning
- Increase Front brake pressure
- Reduce rear brake pressure
Weight Distribution
- Increase front weight
- Decrease rear weight
Aerodynamics:
- Reduce Front Downforce
- Increase rear downforce
Well there you go. Keep in mind that any adjustment you do will affect the car so
do not do more than 2 adjustments at one time. If those don't work or you still want more, keep trying but don;t do to many adjustments at one time. Any question, feel free to ask
المصدر:
Make your car handle how you like it! - NASIOC
معلش يا رجاله بس معرفتش اترجمه لان فيه بعض المصطلحات مش معناها بالعربى ممكن فورميولاتور يدخل يوضح و يترجم و يفهم اكتر و يسهل المعلومه للاعضاء.
بس بصراحه مقاله مفيده جدا جدا جدا .
