المفيد في دائرة صوت الاكسنت ار بي
مواصفات الكاسيت والساماعات
Specification
Audio
Item
Specification
Model
RADIO/CD/MP3(PA710RB)
Power supply
DC 14.4V
Rated output
43W x 4
Tuning type
PLL synthesized type
Antenna
80PF 75Ω
Frequency range / Channel space
FM
87.5~107.9 MHz / 200 KHz
AM
530~1710 KHz / 10 KHz
Speaker
Item
PA710RB
Input power(W)
Front
Max. 25
Rear
Max. 25
Tweeter
Max. 25
Speaker impedance(Ω)
Front
4.0 ± 0.6
Rear
4.0 ± 0.6
Tweeter
3.5 ± 0.6
Speaker number
6
أماكن السماعات والاريال
http://www.hyactech.com/images/books...srbbe1031n.gif
1. الكاسيت
2. سماعات التويترات
3. اريال السقف
4. كابل توصيل الاريال ونقطة توصيل
5. سماعات امام
6. سماعات خلف
7. كابل مد آخر للأريال (تطويله)
الكاسيت و الفيش
http://www.hyactech.com/images/books...srbbe1071n.gif
Connector ANo
Terminal De......ion
Condition
Specified Condition
A1
Loudspeaker Rear Left+
Needed connection to the car
Analog output
A2
Loudspeaker Front Left+
Analog output
A3
Loudspeaker Front Right+
Analog output
A4
Loudspeaker Rear Right+
Analog output
A5
A6
A7
A8
Rheostat from vehicle +
A9
A10
Loudspeaker Rear Left-
Analog output
A11
Loudspeaker Front Left-
Analog output
A12
Loudspeaker Front Right-
Analog output
A13
Loudspeaker Rear Right-
Analog output
A14
A15
A16
A17
Rheostat from vehicle -
A18
Remote supply for motorised antenna
Acc on
9V ~ 18V
Connector B
No
Condition
Specified Condition
B1
B2
B3
B4
Steering Wheel Remote Control
Steering Wheel switch pushed
0.5V ~ 3V
B5
B6
USB D+
USB device is inserted
3.2V ~ 3.45
B7
USB /iPod power
USB/iPod device is inserted
4.9V ~ 5.1V
B8
AUX Right Sound Signal
External Auxiliary device is Audio playing
A waveform synchronized with sound is output
(At time of Aux jack use)
B9
AUX Reference Ground
Always
Below 1 ohm
B10
Bluetooth MIC+
Input the Voice Signal via MIC
A waveform synchronized with Voice data via MIC
B11
Accessory
Engine switch on(ACC)
11 ~ 14 V
B12
Battery
Always
11 ~ 14 V
B13
B14
B15
B16
Speed Sensor Signal
Engine switch on(IGN), car is moved slowly
Approx. 5V Level Pulse Generation
B17
Steering Wheel Remote Control Gnd
Always
Below 1 ohm
B18
USB data line
3.2V ~ 3.45
B19
iPod detection line
GND
B20
AUX Signal Input Detect
Auxiliary device is inserted
0V(Low) → 5V(High)
B21
AUX Left Sound Signal
B22
Bluetooth MIC-
B23
B24
Ground
Always
Below 1 ohm
الاريال في السقف
http://www.hyactech.com/images/books...srbbe1001n.gif
http://www.hyactech.com/images/books...srbbe1004c.gif
دائرة الدريكسون
http://www.hyactech.com/images/books...srbbe1003l.gif
http://www.hyactech.com/images/books...srbbe1135l.gif
