دى مواصفات هوندا الاليت
Displacement: 108.00 ccm (6.59 cubic inches)
Engine type: Single cylinder, four-stroke
Compression: 11.0:1
Bore x stroke: 50.0 x 55.0 mm (2.0 x 2.2 inches)
Fuel system: Injection. Programmed Fuel Injection (PGM-FI) with automatic enrichment
Fuel control: SOHC
Ignition: Digital transistorized with electronic advance
Lubrication system: Dry sump
Cooling system: Liquid
Gearbox: Automatic
Transmission type,
final drive: Belt
Fuel consumption: 2.20 litres/100 km (45.5 km/l or 106.92 mpg)
Greenhouse gases: 51.0 CO2 g/km. (CO2 - Carbon dioxide emission)
Emission details: Meets current EPA standards.
Chassis, suspension, brakes and wheels
Rake (fork angle): 26.5°
Trail: 74 mm (2.9 inches)
Front suspension: 33mm hydraulic fork
Front suspension travel: 79 mm (3.1 inches)
Rear suspension: Swingarm with single hydraulic shock
Rear suspension travel: 71 mm (2.8 inches)
Front tyre dimensions: 90/90-12
Rear tyre dimensions: 100/90-10
Front brakes: Single disc. CBS two-piston caliper
Front brakes diameter: 190 mm (7.5 inches)
Rear brakes: Expanding brake (drum brake)
Rear brakes diameter: 130 mm (5.1 inches)
Physical measures and capacities
Weight incl. oil, gas, etc: 115.2 kg (254.0 pounds)
Seat height: 739 mm (29.1 inches) If adjustable, lowest setting.
Wheelbase: 1,275 mm (50.2 inches)
Fuel capacity: 6.06 litres (1.60 gallons)
Other specifications
Starter: Electric
