ممكن تدلونى ازاى اغير بطارية البروسسيسور ؟ هل محتاجة متخصص ولا ممكن اغيرها بنفسى ؟
لأ دة بيسطعبط, خصوصا ان فرق السعر بين ال green power و العادى اعتقد مش كبير.
انا واخد اقتباس من موضوع عن ال green power , يارت تشوفة :
الرابط: http://www.silentpcreview.com/article786-page1.htmlاقتباس:
It's quite simple, really. Most of a drive's power is consumed by the motor that spins the disk inside the drive. Reduce the speed of the disk, and you reduce the amount of power required. However, Western Digital doesn't want to say that they're selling 5,400 RPM drives — those became second class in the desktop market years ago. Instead, they rate the drive's speed as "IntelliPower" and take pains to emphasize that there are other factors that affect performance.
Western Digital has caught a lot of flak for withholding the rotation speed of the Green Power, especially when the product was first launched and the marketing material listed the rotation speed as 5,400-7,200 RPM. This led some to speculate that the rotation speed changed dynamically during use — which would have been an impressive engineering feat had it been true. The reality is revealed by a sentence that Western Digital added to the description of IntelliPower: "For each GreenPower™ drive model, WD may use a different, invariable RPM." In other words, Western Digital reserves the right to release both 5,400 RPM and 7,200 RPM drives under the Green Power name — without telling you which are which.
We were able to confirm that our 750 GB Green Power had a spindle speed of 5,400 RPM by doing frequency analysis on a sound recording of it. Why sound? Sound is vibration; the pitch of the sound corresponds to the frequency of the vibration. Hard drives vibrate at the speed of their motor, so they produce a noise at the same frequency as their rotation speed. Our sample had a sharp spike at exactly 90 Hz (cycles per second). Multiplying that number by 60 (to get cycles per minute) yielded a measured rotation speed of 5,400 RPM
أنا قريت اللينك يا أستاذ محمد و لقيت الآتى فى أخر صفحة :
اقتباس:
CONCLUSIONSIt's the quietest desktop drive we've ever tested. It's the most efficient drive we've ever tested. And it comes in capacities up to 1 TB. What more do you want? As far as SPCR is concerned, this could be the perfect drive — at least until flash media takes over.We didn't think we'd ever find a drive to replace our trusty Barracuda IV — but then, we never expected a manufacturer to release a mainstream 5,400 RPM drive either. We are pleased and surprised to discover we were wrong on both counts.The only real question mark hanging over the Green Power is how much the rotation speed affects performance. And, while no reports show it leading the pack, it doesn't seem to be far enough back to worry about. Its high capacity 250 GB platters help mitigate the lower spindle speed.We're not sure how green the Green Power actually is — we're pretty sure a 4W savings doesn't add up to much, especially given the environmental cost of manufacturing the drives in the first place. However, we're happy to see Western Digital pay attention to this market segment, if only because it means our own neglected segment — silent computing — gets such a fantastic product to play with. Western Digital has recognized that there's more than just performance and capacity. We hope they go far with it
و ده الإستنتاج اللى طلعوا بيه من الإختبارات دى .. و بيقول إن بالرغم من أن ال RPM قل ل 5400 و ده شىء غير متوقع من الشركات اللى المفروض بتبحث عن سرعة أعلى مش أبطأ .... لكن هما مش متأكدين إن ال RPM أثر على ال performance و لا لأ خصوصاً و إن Its high capacity 250 GB platters help mitigate the lower spindle speed.
هو أنا مش بدافع عن ال green power .. بس ده الكلام اللى لقيته ... لكن لو طلع فعلاً أبطأ من العادى هروح أرميه فى وشه ... بس لغاية دلوقتى أنا مش متأكد إنه أبطأ .... لأن على حسب اللى قريته إن ال RPM لما قل وفر فى الكهربا لكن مش على حساب سرعة نقل البيانات لأنهم عوضوا فى حاجات تانية بتأثر على سرعة النقل.
على العموم شكراً أستاذ محمد على إفادتك.
أنا لقيت جزء آخر خاص بال performance
.اقتباس:
A WORD ON PERFORMANCE
In real terms, the performance difference is minimal. The vast majority of laptops use 5,400 RPM drives, and few people complain that this isn't fast enough. We've been recommending 5,400 RPM notebook drives as a quiet storage alternative for years now. Besides, the large 250 GB platters in the Green Power go a long way to mitigating the performance penalty of the slower rotation speed
واحدة واحدة كده
البروسيسور ممتاز جدا و سعره حوالي 960 جنيه
الماذربورد ممتازة بس معنديش معلومات تفصيلية عنها و تمنها 820 تقريبا
الرامات تمام جدا سعرها 240 جنيه و في المستقبل ممكن تزود تاني
الكيسة هات دولفين برو احسن من الدولفين العادية و اغلي حوالي 100 جنيه و فيها تهوية و مرواح احسن من العادية او ممكن تبص علي كيسة جاما بالباور HEC و حتلاقيهم تلات انواع اختار اللي يناسبك و يكون الباور اللي فيها مناسب ليك بس طبعا الجاما اغلي من الدولفين
الباور سبلاي مبالغ فيه شوية انت يكفي معاك تمام 500-550 وات برضوا خلي الماركة HEC علشان ده انضف حاجة و برضوا سعره معفول و احسن من الصيني
الهارد 250 اول المساحة المعقولة لو عايز تزود براحتك و انا شابف ان الشباب غطوا النقطة دي تمام
لو عايز اداء اعلي ممكن تجيب 2 هارد و تشبكهم علي منظومة ريد بس ده موضوع اعقد من الهارد السينجل و حتحقق بيه مكسب من 5-10% سرعة في تحميل الخرائط الكبيرة حتحس بيه اكتر مع الالعاب اللي ومن التحميل بتاعها كبير
كارت الشاشة اللي اختارته احسن كارت بالنسبة للسعر زائد اداء عالي جدا لو لقيت نسخة منه 1 جيجا حيكون الطف لكنه مش ضروري للدرجة
و للاسف الاسعار في مصر مغالي فيها جدا في كروت الشاشة فنتكلم من ناحية الاداء
عائلة8xxx انساها خالص دي انقرضت مفيش فيها غير 8800gt و ادائه اقل من كارتك المقترح لكنه كارت مش بطال و سعره بقي معقول نسبيا
عائلة9xxx بالنسبة 9600gt ادائه متواضع و بره الحسبة
الكلام علي 9800gtx و بنوعيه ابو معالج واحد و النسخة x2
ده كارت منافس للكارت بتاعك او يقل عنه حاجة بسيطة بس شوف تمنه كام في مصر -غالي جدا -
العائلة الافضل هي x2xx و كبيرهم 280 و دوول اسعارهم اكتر من 3000 جنيه و مش منتشرين في كل المحلات و دول بس اللي ادائهم يتفوق علي كارتك بحاجة بسيطة لا تبرر فرق السعر
و الجهاز ده مش تلاقي جهاز لابتوب يقدر يشد lعاه او يجيب حتي نص الاداء بتاعه في الجيميز و هنا اقصد
Assassin's Creed /Devil May Cry 4 /Crysis
علي اعلي اعدادت الجرافيك
و مبروك مقدما
الف شكر يا باشا والله طمنت قلبى لأنى الصراحه كنت متردد فى البروسيسور اذا كنت اجيب intel or Amd و برده كنت محتار فى motherboard بين Msi or gigabyte or asus
أ meza احب اوضح لحضرتك حاجة بس, انا ساعت لما عقبت على الرد بتاعك كان على نقطة معينة وهى السرعة و الاداء.
و حضرتك قلت :
اقتباس:
الراجل قاللى إنه أسرع مش أبطأ من العادى
ودة طبعا باى حال من الأحوال البياع بيقولك كلام مش صح, فهو دة كان تعقيبى.اقتباس:
لأنه قاللى ده أسرع من العادى الضعف
انا اللى فهمتوا من الاقتباس اللى حضرتك كنت واخدة ان هو فعلا من اهدى (هادئ) و اقل استهلاك للكهربا وان فى حاجات تانية اهم من الاداء. و هو دة الكلام اللى حضرتك قلتة مسبقا و اللى ان وافقتك علية.
يعنى الأولوية لل Green Power مش السرعة و الأداء, و هوة دة اللى بحاول اوضحولك.
اقتباس اخر من الموضوع:
اقتباس:
As a general rule, our reviews ignore performance in favor of noise and power. In a world where most drives are just dumping places for data, we believe that noise and power (and reliability) are more important than speed. Our specialty is testing noise, not performance..
That said, we can't ignore the fact that our Green Power is a 5,400 RPM drive competing in a 7,200 RPM field. Rotation speed does affect performance, and we'd be remiss if we glossed over this entirely. Performance reviews around the web have been mixed, with the Green Power lagging behind the performance leaders.Reviews at Storage Review and The Tech Report both acknowledged that the performance isn't record-breaking, and — let's be fair — it's not really meant to be . Western Digital is betting that there are people out there that value low power more than performance. We're solidly behind them on that one; we make a similar value judgment every time we recommend a slower, quieter part over a faster, noisier one
شكراً جزيلاً ... أستاذ محمد .. أنا كده فهمت حضرتك عاوز تقوللى إيه ... معلش تعبتك معايا :)
و من منطلق إن أنا بحب أحافظ على البيئة :clover:.... فأنا هستخدم ال Green Power .. :D
