رقم العضوية : 57
الاقامة : مدينة نصر
السيارة: هيونداي فيرنا
السيارة[2]: هيونداي فيرنا
دراجة بخارية: -
INSTRUMENT & CONTROLS
Power steering STD
Tilt adjustable steering wheel STD
Telescopic/reach adjust steering wheel STD
Cruise control STD
Programmable overspeed alert STD
Trip computer STD
Power exterior mirrors STD
Left hand convex mirror STD
Interior Day/Night mirror STD
Intermittent windscreen wipers STD
- Variable intermittent windscreen wipers STD
- Auto on headlights STD
Optitron combimeter STD
Transmission gear indicator in dash STD
Tachometer STD
Low fuel warning lamp STD
Expand FEATURES
Air conditioning STD
- Auto/Climate control air cond. STD
- Dual front zone air cond. STD
Push button heater controls STD
Sunroof O/PAK
- Electric sunroof operation O/PAK
- See-thru sunroof O/PAK
Power windows STD
- Front and rear power windows STD
Driver's vanity mirror STD
- Illuminated drivers vanity mirror O/PAK
Passenger's vanity mirror STD
- Illuminated passenger vanity mirror O/PAK
Expand DIMENSIONS
(Note: Some figures are approximate only and may vary due to options/accessories fitted.)
Length (mm) 4825
Width (mm) 1820
Height (mm) 1470
Wheelbase (mm) 2775
Ground clearance (mm) 105
Expand STORAGE
Glovebox STD
Storage pocket/tray STD
- Sunglass holder STD
Centre console STD
- Full centre console STD
Map pocket - Passenger seat STD
Map pocket - Driver's seat STD
Door pockets - Front STD
Door pockets - Rear STD
Cup holder/s STD
- Number of cup holder/s 4
Expand SAFETY
Anti-Skid Brakes (ABS) STD
- Electronic Brake-force Distribution (EBD) STD
- Brake Assist (BA) STD
Traction control STD
Vehicle Stability/Swerve Control (VSC) STD
Driver's SRS airbag STD
Front passenger SRS airbag STD
Front seat side airbags STD
- Seat mounted front seat side airbags STD
- Front seat side curtain airbags STD
Rear/2nd row airbags STD
- Rear/2nd row seat side curtain airbags STD
Driver's pre-tensioner seatbelt STD
Driver's forcelimiter seatbelt STD
Front passenger pre-tensioner seatbelt STD
Front passenger forcelimiter seatbelt STD
Height adjustable front seatbelts STD
2nd row/rear seat centre position lap/sash seatbelt STD
2nd row/rear seat ALR outboard seatbelts for child seats STD
2nd row/rear seat ALR centre seatbelt for child seat STD
Expand TYRES & RIMS
Front Tyre size 215/60 R16 95V
Rear Tyre size 215/60 R16 95V
Front Rim size 6.5Jx16
Rear Rim size 6.5Jx16
Rim type Alloy
Spare wheel - steel STD
Expand SOUND SYSTEM
AM/FM Radio STD
CD player STD
- CD changer in cabin STD
- 6 Disc CD changer STD
Number of speaker locations (excludes speaker elements) 6
Audio controls on steering wheel STD
Aerial - Mounted in glass STD
Expand DRIVETRAIN
Driven Wheels Front
Transmission description Six speed automatic, electronically controlled with lock-up torque converter and Artificial Intelligence shift control.
Expand WEIGHTS & CAPACITIES
(Note: Kerb, tare & payload weights are nominal and will vary depending on options and tray/body type.)
Kerb Weight (kg) 1610
Gross Vehicle Mass (kg) 2110
Maximum roof load (kg -Includes roof rack weight) N/A
Seating capacity (includes driver) 5
Luggage capacity (litres) 504
Cargo volume N/A
Fuel Tank Capacity (litres) 70 litres
Vehicle Towing capacity - with trailer brakes (kg) 1600
- Without trailer brakes (kg) 500
Genuine Towbar D/F
(Note: Genuine Towbar Capacity - Refer to Genuine Accessory Guide, as it may differ from Vehicle Towing Capacity in some circumstances.
Towing capacity - Subject to state regulations, towbar design and towing equipment.)
Expand INTERIOR TRIM AND SEATING
Leather seat trim STD
- Full seat face leather trim STD
Leather bound gear knob STD
Leather bound steering wheel STD
Wood/Woodgrain-look trim STD
- Wood/woodgrain-look on dash STD
- Wood/woodgrain-look on door trims STD
Floor carpet STD
Assist grip/s STD
- Number of assist grips 4
Front bucket seats STD
Driver's seat - Power operated STD
- Driver's seat power slide adjustment STD
- Driver's seat power tilt backrest STD
- Driver's seat power height adjustment STD
- Driver's seat power 2 way cushion tilt STD
- Driver's seat power lumbar adjustment STD
Front passenger's seat - Power operated STD
- Front passenger seat power slide adjustment STD
- Front passenger seat power tilt backrest STD
- Front passenger seat power lumbar adjustment STD
Front seat head restraints STD
Second Row/Rear seat STD
Expand LIGHTING
Interior dome light/s STD
- Map light/s STD
- Front seat map light/s STD
- 2nd row/rear map light/s O/PAK
Glovebox light STD
Luggage/cargo light STD
Expand SECURITY
Engine immobiliser STD
Alarm system STD
- Boot, bonnet and door alarm monitoring STD
Central locking / Power door locks STD
- Remote/Keyless central locking STD
Remote boot/tailgate release/unlock STD
- Boot/tailgate release on ignition key/fob STD
Lockable glovebox STD
Remote fuel lid release STD
Expand EXTERIOR
Bodycoloured bumper/s STD
Dual headlights STD
Projector low beam headlights STD
Multi-reflector headlights STD
Bonnet gas strut/s STD
Bodyside protection mouldings STD
Alloy wheels STD
- 16" alloy wheels STD
Metallic paint OPT
Mica paint OPT
Expand VEHICLE COMMUNICATIONS
Power accessory socket STD
Satellite navigation system D/F
(Note: Satellite Navigation coverage are major capitals, primary national roads & some regional areas.)
- DVD satellite navigation system D/F
Expand BRAKES
Front Brakes Ventilated discs
Rear Brakes Solid Discs
- Electronic Brake-force Distribution STD
- Brake Assist STD
Traction Control STD
Expand WARRANTY / SERVICE
(Note: Warranties here are in addition to implied warranties under the Trade Practices Act. Conditions apply. See warranty booklet for details.)
Vehicle in years/kilometres 3yrs or 100,000kms (whichever occurs first)
Paint in years 3
Perforation in years 5
Expand ENGINE
Engine type Petrol
Engine capacity (cc) 3456
Engine description V6/DOHC/4v
Maximum Power 200kW @ 6200rpm
Maximum Torque 336Nm @ 4700rpm
(Note: Power and Torque test standards differ. Ensure comparisons use same test standard.)
Configuration V-formation
Valvetrain DOHC
- Variable valve timing Dual VVT-i
Fuel system EFI
- Fuel type 91 RON ULP
Fuel economy ADR 81/01 Test standard
- Combined (L/100km) 9.9
(Note: Fuel economy varies with driving conditions/style, vehicle conditions, options and accessories.)
Expand STEERING
Steering type Rack and pinion
Steering operation Power
Turning Circle at Kerb 11
Expand SUSPENSION
Front Suspension Independent, MacPherson struts, coil springs and ball-joint mounted anti-roll bar.
Rear Suspension Independent, strut-type coil spring/damper units, dual lower transverse links, lower trailing arm, gas dampers and ball joint- mounted anti-roll bar.
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
انا كدة نفسيتي تعبت :D انت حر لو عاوز باقي الصور انزل تحت
واسعة جداً :shock:
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
كفاية كدة :D
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
رقم العضوية : 55
السيارة: Gol
السيارة[2]: Corrolla
والله العظيم لسه امبارح بس شايف واحده فى الميدان اللى عند سور الكليه الحربيه مع نهاية المترو
لونها ابيض وملاكى القاهره
نزلت بصيت عليها والبواب قاللى يابيه كل 5 دقايق واحد يقف ويتفرج عليها
اوعدنا يارب
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
يا رب :Dالبواب قاللى يابيه كل 5 دقايق واحد يقف ويتفرج عليها
اوعدنا يارب
لأي استفسار أو شكوى بخصوص الإدارة والإشراف والدعم الفني، يرجى المراسلة على:
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
معلش انا كررت الموضوع مرتين "مش عارف ازاي" يا ريت حد من المشرفين يمسح واحد منهم
رقم العضوية : 843
الاقامة : maddi
السيارة: kokoko
السيارة[2]: kokok
العربية دي ممتازة جدا و أنا شفت الأعلان بتاعها من أكتر من 3شهور و فتحت فمي و دلدل لساني
يا رب أوعدنا
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
:D :Dفتحت فمي و دلدل لساني
