Audio System:
دة اللى بينزل مصر
http://nileup.com/up/uploads/nilemotors_13794781311.jpg
http://nileup.com/up/uploads/nilemotors_13794781312.jpg
ودى مواصفاتة:
Advanced Audio System
The standard AM/FM/CD/MP3/WMA audio system includes an auxiliary audio input, steering wheel audio controls, .... display and automatic vehicle-speed sensitive volume adjustment. All models also feature iPod®/USB audio integration, Bluetooth® mobile phone connectivity and Bluetooth streaming audio to ensure your favourite music is always close at hand and you’re always in touch. The final word: There’s really nothing standard about this audio system, which will deliver countless miles of musical satisfaction.
دة اللى بينزل برة
http://nileup.com/up/uploads/nilemotors_13794781313.jpg
http://nileup.com/up/uploads/nilemotors_13794781314.jpg
ودى مواصفاتة :
Multimedia System
This available multimedia system features a 6.1-inch, high-resolution touch screen that operates the AM/FM/CD/MP3/WMA audio system, GPS navigation and rear-view camera. The navigation system includes XM® NAVTraffic updates (sub......ion required) to help ease commuting time, while a free 3-month trial sub......ion to XM Satellite Radio and digital media support are also part of the equation. In terms of communications, the system features Bluetooth® connectivity with voice recognition (in English and in French), smartphone† integration and email/SMS .... messaging capability.
اللى بينزل برة ممكن التوكيل يركبو وسعرة 6200 بالكاميرا و ال GPS وعلية خرائط مصر
الفتيس :
دة اللى بينزل مصر
http://nileup.com/up/uploads/nilemotors_13794788351.jpg
model has 'L-D' CVT control. L is basically like 2nd gear.
ودة اللى بينزل برة و بيكون فية شيفتات فى الدريكسيون
http://nileup.com/up/uploads/nilemotors_13794788352.jpg
http://nileup.com/up/uploads/nilemotors_13794788353.jpg
http://nileup.com/up/uploads/nilemotors_13794788354.jpg
models have 'M-D' CVT controls for manual or automatic Drive controls. When in M mode, use the Paddle Shifters to for up/down transmission control.
نيجى بقة لاشكال الجنوط
الشكل دة اللى بينزل فى ال full option
http://nileup.com/up/uploads/nilemotors_13794812241.jpg
15" steel wheel with plastic wheel cover
ودة فى الhigh line و ال Special Edition
http://nileup.com/up/uploads/nilemotors_13794812242.jpg
16" alloy
ودة اللى بينزل فى ال 2000 سي سي
http://nileup.com/up/uploads/nilemotors_13794812243.jpg
17" alloy
ودة اللى بينزل فى ال sport model
http://nileup.com/up/uploads/nilemotors_13794812244.jpg
17" gun....l gray alloy
انظمة الامان فى الامبريزا :
- فى الهاى لاين 2 اير باج
- فى الاسبيشيال ايديشن 8 ايرباج
http://nileup.com/up/uploads/nilemotors_13794992251.jpg
- دة بقى اختراع جديد من سوبارو Rear Door Engagement Pins standard
دة بيمنع ان الباب يدخل فى الصالون فى الحوادث اللى من الجنب لاقدر الله علشان ال PIN دة بيبات فى القايم
http://nileup.com/up/uploads/nilemotors_13794995611.jpg
Rear Door Engagement Pins standard*
Subaru's feature this pin on the rear door that locks in with a receiver in the door frame, creating an impact-resistant barrier across the width of the door.
- دة بقى دعامه مصنوعة من مادة قوية ولفة من بين الباب اللى ورا واللى قدام ومن الارض للسقف
This is a B-Pillar from a Subaru. (The B-Pillar is the column between the front and rear doors that runs from the floorpan to the roof). That middle rod is made of boron, an exotic high strength steel that sounds like it was named after a superhero's birth planet. Even if you're not an engineer or a ....llurgist, you can tell just by looking that this is a VERY strong column.
http://nileup.com/up/uploads/nilemotors_13795001811.jpg
Extensive Use of Boron standard
Boron is an expensive, light-weight, Ultra High Strength Steel (UHSS). It comprises much of the Subaru safety frame.
- من احدى المميزات الجميله فى السوبارو ال Break away Engin
وديه فى الحوادث الجامده لاقدر الله اللى من الامام بتخلى الماتور ينزل لتحت علشان يمنع دخوله على كابينة القياده و يسبب أذى للركاب الاماميين
http://nileup.com/up/uploads/nilemotors_13795010171.jpg
دة فيديو بيوضح بعض نقاط السيفتى اللى اتكلمنا عليها
[youtube]http://www.youtube.com/watch?v=ucyK-17yA2s[/youtube]
Content Relevant URLs by
vBSEO 3.6.0 PL2
