كاسيت البونتو قفل خالص
ياجماعة الكاسيت بتاعى كان طالب كود تفعيل وأنا دخلت أكتر من كود ودلوقتى الكاسيت عاطينى كلمة (wate) على طووووووووووول وفصلت البطارية يوم كامل ورجعتها تانى يوم ولقيت نفس الكلمة والكلام ده بقاله حوالى إسبوع ومفيش فايدة دلونى أعمل إيهوعلى فكرة أنا جبت الكود الأصلى بتاعه عن طريق برنامج لفك الشفرات بس المشكلة انى لما دخلت كذا رقم قفل خالص معايا وأنا من ساعتها مستنى يجبلى كلمة كود على الشاشة عشان أدخل الرقم اللى معايا ................. دلونى يا أهل الخير ملحوظة ---(أنا من إسكندرية)
If the display continually shows "WAIT" then the unit may be codelocked and will need to be left switched on up for up to two hours to reset before another code entry attempt is possible. If it does not reset after this time, or the display shows "CANCHECK" , then the unit will need to be sent to us to be reset and reprogrammed for use in your car, full details of this service can be found below.
If you have lost your radio code, the Security Code for this Radio is available NOW using our fully automated INSTANT RADIO CODE service. Once your Radio details have been submitted, your Code will be ready - Instantly !! - No Waiting !!
Removal of the radio is fairly straightforward. The removal tools are inserted into the four round holes at the sides of the fascia until a click is felt. The radio can then be withdrawn and the leads unplugged.
CANCHECK
This stereo is electronically paired to the engine management system of the vehicle it came out of using very sophisticated CAN-BUS system technology. When it is first powered up, it will communicate with the vehicle, and a message of "WAIT" will appear whilst this process is in operation. If communication has been successfull, it will prompt for the code number to be entered. However, if removed and refitted into a different vehicle other than the original one, it will not recognise the coded CANBUS signals of the new car, and will instead display an error message of "CANCHECK". Full details of our "CANCHECK" reset and reprogramming service can be found below.
كل مرة يتم ادخال الكود غير الصحيح يتطلب وقت انتظار اكبر على سبيل المثال ادخال الكود اول مرة خطا يتطلب انتظار دقيقة واحدة ثم اذا تم ادخال كود غير صيحيح مرة اخرى يتطلب انتظار فترة مضاعفة تى 2 دقيقة وهكذا حتى تصل فترة انتظار الى 24 ساعة اذا تم ادخال الكود اكثر من 12 مرة خطأ . واعتقد انه يتم عمل locked بعد ذلك . ممكن يتم ارساله الى التوكيل لاعادة برمجته من جديد
انا عندي الكاسيت مرة واحدة كتب cancheck بدون اي مقدمات و حاولت اعمل كل حاجة بدون جدوى .. شلت البطارية و حطيتها تاني - جبت كاسيت مستعمل من نفس موديل العربية - كشفت على كابل ال can و كشفت على الضفيرة - جربت الكاسيت المستعمل في عربية تانية اشتغل عادي . مش عارف اعمل ايه تاني؟
العربية فيات لينيا.
Content Relevant URLs by
vBSEO 3.6.0 PL2
